FixYa.com
Tags:
Panasonic PT-50DL54 50 in. Rear Projection HDTV-Ready Television
PT54DL50 (by 2 users)
posted by joker12345 on Sep 13, 2007
Woke up truned on no picture power button blinlking 3 red blinks?
replaced lamp....needed it anyway. Stilll 3 red blinks?
Help
Chip
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by disbederyk, posted on Nov 21, 2007
Same thing .....I replaced the lamp on the PT50DL54 tv and it still blinks
and I lost the user manual which doesn't help ......what do I do to stop it?
Solution #1
posted on Dec 01, 2007
Not Rated (0)
premtech
Rank:Guru Guru
Rating: 89%, 770 votes
There is a problem in your 3.3v main line and until corrected it will not power the lamp. This isn't usually an expensive repair but one that a shop will need to do since most of the work will be in trace testing voltage and signal using a scope.
For future information only here are the blink codes for this unit:
1 | Load Shortage
2 | Over Volage
3 | Fan Sos
4 | Main 3.3v
5 | Lamp Disable
6 | Gc3fm-Iic
7 | Gc3fs-Iic
8 | Gc3i-Iic
9 | Color Wheel Stop
Hope this helps!
Bill
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Projection Televisions problems?
Panasonic PT-50DL54 50 in. Rear Projection...
Panasonic HD TV
Turns off by itself. Answer This...
Panasonic PT-50DL54 problems
Hi you seem real helpful and... Answer This...
GREEN SCREEN
left lower portion of screen is... Answer This...
LEFT LOWER PORTION OF SCREEN IS...
I have Panasonic PT-47WX54 and...
I have Panasonic PT-47WX54 and... Answer This...
Repair Service
Find Projection TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
