Question about Dishwashers
Water in the bottom of dishwasher and no power. I checked the circuit.
There is 3 inches of water in the bottom and there does not seem to be an power.
  • Anonymous Apr 15, 2009
    i have power but will not drain
  • 116 Answers
Check breaker and if power isnt it then let me know
Posted on Apr 15, 2009
I have a GE quiet power 3 dishwasher and water is in the bottom a the power will not work now what should I do?
This seems to be that the Anti Flood system has triggered. This device detects water leaks / spills to the bottom of the washer and automatically puts the washer in pump out mode and shuts off the water inlet. The device is made up of a pollystireene float and micro switch that activates once the float detects any leaks / spillage. Dry water and check for leaks and this should solve the problem
Jan 23, 2010 | Dishwashers
Same problem. 2-3 inches of water left in the dishwasher at end.
Inspect for plugged drain screen. Sometimes you have to take apart the bottom area for access...
Sep 18, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Bosch dishwasher continues to run (Model SHX46A02UC)
This is too common a problem with these units. I have written a guide to help folks out with it. Find it here.
Jul 11, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
GE dishwaher leaks with standing water in bottom
Check to make sure regular dish soap did not end up getting inside the dishwasher. This will create a lot of suds that will overflow onto the kitchen floor. Standing water from not draining can mean the drain hose is clogged somewhere or the check valve has something caught in it. If you remove the front kick plate, you will be able to check those.
http://tclaundryrepair.com/
Feb 26, 2009 | GE 24 in. Profile PDW7800 Built-in...
No power
Hi lushman001
I'm Harvey the Master Plunber.
Your question is: your 3-yr-old dishwasher (Whirlpool 24-inch ) stopped in mid-cycle. A small amount standing water in the bottom of the washer. None of the control panel buttons were lit up and none of them will work. NO POWER
First check all the breakers (or fuses).
Second check the electrical connections. If you're not a qualified electrician or service tech then call one. It"s under the unit behind the kickplate.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 11, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Dishwasher
  This dishwasher does not feed water to top and bottom arms at same time.  It starts with bottom and then after awhile it switches to top and then cycles.  If water comes out arms but arms won't turn,  check all holes in arms.  It's the water spraying out these that causes arms to turn.   If arms spin freely by hand,  it's a plugged arm or holes in arm or insufficient water in tank.
  Being that it only sprays 4 inches suggests a water level problem or possible mineral build up restricting flow.
Oct 11, 2007 | Frigidaire 24 in. PLD2850 Built-in...
Meale dishwashers
check that you have water supply to the pipe that connects the dishwasher to the wall, when you switch the dishwasher on, dose it buzz quietly, if so there is no water coming to the machine, the fault is with the plumbing, if there is no quiet buzz when switched on then check the water solenoid for open circuit if i have helped please rate me
Sep 27, 2007 | Miele 24 in. G646SC Plus Free-Standing...
Dishwashers Logo
79 people viewed this question
Top Dishwashers Experts
