FixYa.com
Tags:
Jensen LXA300 Car Audio Amplifier
Car Audio System Drwing too much power with 2...
posted by MarkG_ShebWI on Sep 13, 2007
I have a System in my trunk. Pretty Simple 1 Dual 8 ohm Voice Coil Sub(1000W RMS) with a 300 Wat RMS Amp. I idid this to make sure i nevver blow my sub. I have a FAT Plus Minus to battery, but all the sudden my amp would start kicking out at half volume. I looked in back and the protect light comes on at half power. So i bowwowed my sisters 1200 Watt Amp and hooked it up. I had it bridged off the amp both times. Anyways, Her amp worked great for a day, then i smelled smoke in my trunk. I felt her amp and it was pretty warm. Not her amp does the same thing? Is my car wiring bad or is it my sub or what? I had been using the same wiring setup for the last 3 years, so i cant imagine that would just go bad. Please let me know as soon as possible, I NEED BASS.
Comment by MarkG_ShebWI, posted on Sep 15, 2007
I have the sub wired in series, so 8 ohms, on the amp bridged. I had it that way both times. Ant thing wlse? I also noticed that the amp got reeally hot before starting the on off crap. any more info would be great. THANK YOU SO MUCH!
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Sep 14, 2007
Helpful (85)
Duncan
Rank:Wiz Wiz
Rating: 85%, 165 votes
A dual voice coil speaker can be wired to be a 2 ohm speaker or an 8 ohm speaker depending on whether you wire it in series (8 ohm) or parallel (2 ohm). When you bridge your amp then the two channels will share the load from your speaker. If the speaker is wired as 8 ohm then each channel of the amp is driving a 4 ohm load which is fine. If you are bridged into a 2 ohm speaker then each channel will be driving a 1 ohm load, which is a very very heavy load. Is your amp designed to drive a 1 ohm load? If not then that would explain why you are having a problem.
Comment by Duncan, posted on Sep 14, 2007
A post script from my post above. If you have been driving a 1 ohm load on each channel then you may now have two blown amplifiers. Sorry.
Rating Locked! (?) MarkG_ShebWI has rated this solution as Helpful
Can you Help with these Car Amplifiers problems?
Car Amplifiers
genon avr1601
Hi gud day i have genov avr1601... Answer This...
Car Amplifiers
i need a code for a universal...
code for a remote control... Answer This...
Car Amplifiers
schematic for washburn pg 65 c
need schematic Answer This...
Car Amplifiers
NASHVILLE DAB35
CONECTARE Answer This...
Car Amplifiers
code for kenwood cd player
I just bought this car... Answer This...
Repair Service
Find Car Amplifier Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
