Need a new fuser
What is the cost of a fuser for a sharp ar-162s. and where can we purchase one. thank you for your help uaw local 2901
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 133 Answers
Olsonbros.com...fuser unit for a ar-162s=$164.40
Posted on Apr 15, 2009
How do i enter the service mode on a sharp ar-162s
Hi:
Press in quick succession # * Clr *
Andrew
Sep 28, 2011 | Sharp AR-162S Copier
Persistent error code on Sharp AR-162S copier
I see the user manual says contact your SHARP service center immediately and is no further help. But a bit of websearching revealed
Error Codes Starting with "H" are fuser faults.
H2-00 Fusing unit temperature error
H3-00 Overheated fusing unit
H4-00 The fusing unit doesn't heat up
If you haven't got the user manual it is here:- http://www.sharpusa.com/files/cop_man_AR162S.pdf
Importantly it shows how to release the fusing unit. If you cant see an obvious problem then you may need to get a new fusing unit.
You may need to reset the copier to clear the error so it can try starting again when you switch on.
Oct 21, 2007 | Office Equipment & Supplies
When you run a copy it leaves a couple thick dark lines on the paper that you copied too.
If you lighten the exposure do the lines fade away ? It most likly needs a drum or a drum cleaning blade. Good luck.
Jul 14, 2011 | Sharp AR-162S Copier
I have a white stripe on the copies. I just installed a new toner cartridge, and cleaned the transfer charger. I have a Sharp AR-162S copier that is 3 - 5 years old. Thanks.
Hi check the developer unit make sure it is coated end to end some times the blade on the developer gets foreig matter stuck and prevents the developer/toner to go onto areas of the developer mag roller also check and make sure the transfer corona wires are in good condition no black marks on the corona wire if there is replace the wires
Feb 15, 2011 | Office Equipment & Supplies
Sharp AR-235 shows error H4-00, would like to know how to fix without costing me.
Noy likely you can fix this without replacing the fuser lamp H4 means the fuser lamp is not getting to temp. It cold be a fuse on the fuser unit,too. Checking with an ohm meter is only way to know which,
Feb 07, 2011 | Sharp AR-235 Copier
Sharp AR-168D H2-00 error code
Check
http://www.copier-help.com/copier-help/ecs/sharp/ecsar161.html
Thanks.
Jun 11, 2009 | Sharp AR-168D Black and White Copier
H4-00 error on Sharp AR-168D
the code needs to be reset even if you replace the fuser.
Press clear, press *, press #, press * your display should go blank press 14 then press print,
I'm doing this from long term memory I may have the # and * symbols swapped
Apr 09, 2009 | Sharp AR-168D Black and White Copier
"machine gun clicking" sound - fuser drive/motor gear area
Sometimes the clicking noise can come for the developer cartridge or the drum. you can carefully take them out and see if they turn freely.
Aug 12, 2008 | Sharp AR-M205 Copier
H4 error message
Heat roller low detection error. The thermistor and lamp need to be checked. It could need a new fuser assembly.
Jun 12, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-BC260
I would inspect the fuser unit for abraising on the roller or missing and/or broken pauls.
Jun 06, 2008 | Sharp AR-BC260 Color Copier
48 people viewed this question
k24674
jasbo
jasbo
