Question about Microsoft Wireless Notebook Optical Mouse VSBX300008
Receiver not recognized by computer
When I first got the mouse it worked great (once). The next time I tried to connect the reciver my computer all the sudden doesn't recognize the device. The mouse is fine, it's just the receiver that will not light up, no green light at all.
The green LED on this reciever is also a button. Press the LED on the reciever with a small blunt object (pencil will work) and then press the "connect" button on the bottom of the mouse. The green LED should come on, and restore the connection between the reciever and the mouse.
Posted on Jun 03, 2009
Onn Wireless Mouse has stopped working. What do I do?
Mine would work fine until I turned on my wireless headphones...then the mouse would move a little stop.....move a little....then stop.
I made sure my headphones were on.
I turned off the mouse, moved the mouse reciver to a USB port on the front of my computer (the mouse reciver and the headphone receivers were next to each other on the back of the computer). I turned the mouse back on.
The computer imediately gave me the "installing USB driver" notification.
When it was complete....both played nicely together...no more problems.
Jun 28, 2012 | Computers & Internet
I have a Dynex Wireless Optical Mouse (Model No. DX=PWLMSE) and it works when I plug it into my netbook. When I try to use it with my laptop (Gateway), the cursor does not move. I have tried to use the...
On some computers, the mouse will work as soon as it is plugged in, while on others you'll need to manually set the connection. To do this, plug the USB receiver into the computer, then press the Connect button on the receiver. Once the lights start flashing, press the Connect button on the bottom of the mouse. (Make sure the mouse is turned on first.) It should now make the connection.
Hope that helps!
Sep 09, 2010 | Dynex Wireless Optical Mouse
Spyder mouse won't work
I had a similar problem. I corrected by performing a manual connect as listed in the manual that came with the mouse.
Manual reconnect:
1. Plug in the receiver.
2. Turn on the mouse.
3. Press the button on the receiver.
4. Press the connect button on the mouse once within five seconds of pressing the button on the receiver.
This worked for me, and the mouse has worked fine since.
If this doesn't work. The manual suggested taking the batteries out of the mouse for 20 seconds and unplugging the receiver, then repeat the steps above.
If that doesn't work. reboot the computer and repeat the steps above.
Hope this helps.
Jul 21, 2009 | AVENUES The SPYDER SwissGear Wireless...
I have a dell wireless mouse and it used to connect with my computer and work fine. I've had it almost a year but now it will not connect to my dell laptop. The light on my laptop and on the mouse will...
Most wireless keyboards and mice have their own wireless receivers (one that should be connected to the computer). The wireless receiver usually has a connect button that you need to press in order for you to connect the keyboard or the mouse. Try holding down the connect button on the receiver and on the keyboard at the same time for five seconds and release them both after five minutes.
If that work, do the same for the mouse.
Hope this helps and have a great day!
Jul 06, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Targus mouse not recognized
What is the OS of your computer? This Targus mouse would work with Win 98, Win 2000 and Win XP. Vista was not mentioned. And if you are running Windows Vista for you laptop, then that could be the reason why it was not recognized by the computer.
Is this the wireless optical mouse? If yes, you need to follow the steps below to isolate the problem:
1. Connect the USB receiver into different USB ports of the computer.
2. Replace the batteries with the fresh ones.
3. Try connecting the mouse into different computer to see if you've got a defective mouse.
If you've tried everything and got the same problem, you may need to refer to the manufacturer, because I'm not sure if this mouse is a Plug-n-Play device or if it needs a driver.
Have a great day!
May 26, 2009 | Targus PAWM001U Mouse
Microsoft Wireless Notebook Optical Mouse Model 1023
Had the same problem. There are 2 reset/ connect buttons: 1 on the mouse, and 1 on the usb device. Press the button on the usb device, and it should start right up. Good luck.
Aug 19, 2008 | Microsoft Wireless Notebook Optical Mouse...
Laptop does not recognize wireless mouse
Most wireless mouse are not plug and play.
Try this:
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
May 28, 2008 | Bluetake (bt500+bt009x) Mouse
Cordless Desktop EX 90 Mouse Not Working
have you checked that it is the USB port if it is not in the USB port it will not respond
Feb 22, 2008 | Computers & Internet
It's not working right....
The BenQ M310 mouse needs to "sync" with the USB receiver. Need to push the two buttons at the same time, or maybe the one in the mouse first then push the button in the USB receive so the two can "sync" to each other. This may solve this problem. Good luck!
Feb 16, 2008 | BenQ M310 Wireless Mini Optical Mouse
Microsoft Wireless Notebook Optical Mouse VSBX300008 Logo
350 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
