Question about Whirlpool GU2400XTP Built-in Dishwasher
Kenmore Dishwasher Holding Water
I have a 7 year old Kenmore dishwasher. Lately, I have noticed the top rack is not cleaning well. Now, it is holding water in the bottom.
  • varunkej Apr 27, 2009
    My DIshwasher has been holding water at the bottom rack for the past ten days. Does anyone know the solution to this?
  • 116 Answers
Lost your tube that supplies water to upper spin rack? look in your strainer
Posted on Apr 15, 2009
We have a Kenmore Elite 630.16304401 dishwasher, lately we are getting small black greasy spots on the plastic dishes, also same spots on the plastic parts in the sump where you clean the filter? We h
A couple of thoughts:
1) It could be a gasket somewhere starting to break down. Check your door seal.
2) Food particles could have gotten caught somewhere in the drain hose, or something, and then turned black with mold and bacteria, then when you wash, they get siphoned back into the dishwasher if the flap which composes the anti-siphon check valve on the drain hose is starting to stick open.
Try putting a cup of bleach in the top rack and run a complete cycle with no other dishes in it. Then, load up some plastic dishes and wash them as normal. See if that helps. If it does, replace your check valve.
Also, insure that your drain hose is looped up above the bottom of your sink to prevent debris from your garbage disposal backing up into your dishwasher.
Good luck and keep us posted!
Oct 22, 2014 | Kenmore Dishwashers
I have a Kenmore model 1374 (ultrawash quiet guard). Recently I've noticed a lot of dirty residue left on the top rack dishes. I looked in the back of the dishwasher and noticed something with the little...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Dec 26, 2010 | Kenmore 13742 / 13744 / 13749 Built-in...
My GE Triton XL dishwasher (6-7 years old) doesn't seem to be spraying water. Is this a fixable issue or is it time to replace it?
When my wife started complaining about her dishwasher not getting the top rack clean this is what I found and I wrote a tip about it...
Dishwasher Spray Arms not Spinning
heatman101
Sep 06, 2010 | Dishwashers
I noticed water coming from underneath my dishwasher so I pulled it out from the wall and found that underneath the factory installed installation there was a screw missing that holds the top dishwasher...
Speak with who you purchased the dishwasher from. They will be able to point you in the direction to get a replacement and file a complaint. All of this is provided you bought the machine in the last year.
Mar 14, 2010 | Kenmore Dishwashers
Kenmore Dishwasher not cleaning dishes - especially top rack.
put a pump kit in the dishwasher..and the water coming up is a house drain problem
Aug 06, 2009 | Kenmore Elite 45986 Front Load Washer
Top rack not getting clean
you may have a bad chopper. put a couple of coffee mugs upright on the top rack turn the dishwasher on and see if the mugs are filling with water give it about 1 minute. if they are mot filling up you have a problem with either the recurculation pump or the chopper. it's usually the chopper
Mar 24, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
My dishwasher is not washing dishes on the top rack...
HI,
The top rack is not cleaning because of low water pressure from the wash motor to the upper spray arm.
Assuming the top spray arms are clear of debris, remove the lower spray arm to access the wash motor. Remove the 4 torx screws and the filter (accumulator assembly). Remove the torx screw and the inlet protector that covers the chopper assembly. Make sure the chopper is not broken (broken chopper will fill with debris and block water flow). While holding the chopper blade, reach inside the "D" shaped opening on top of the motor and spin the wheel/motor by hand in each direction to make sure either the chopper gear or the motor gear that drives the chopper is not broken. Replace the chopper if necessary . If the motor gear is broken, replace the sump and motor assembly . Remove any debris from the sump area in the process.
You don't have to shut the power off to the dishwasher because the door will be open, but if you feel more comfortable, do so.
thanks,
Mar 18, 2009 | Frigidaire 24 in. FDB1050RE Built-in...
The top rack is not getting clean.
This is one common possibility
It may be the food chopper assembly. Mine broke last year from a toothpick,
the food doesn't get chopped because the blades are broken, then the filter clogs and water wont spray high enough.
Heres a test--turn on the dishwasher and wait until you can hear water running then open the door really fast and look at how high the water is spraying--there should be alot of water all over the top rack running down
Jan 31, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Top Rack of Kenmore doesn't clean
the chances are the water pipes are blocking in the base. check all the hoses are clear of debris then check things like the spray arm holes are clear and also check on the water level in the cavity.
Jan 20, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool GU2400XTP Built-in Dishwasher Logo
592 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
