Question about Sterling Plumbing 1500D-31S VISTA PIVOT SHOWER DOOR
Sterling shower faucet
I replaced the cartridge in a sterling faucet. And after the water is still cold when in the hot position. Can you please advise what might be the next step. This is a single handle Sterling faucet.
Thank you
  • knearhoof256 Apr 15, 2009
    this is a Sterling shower faucett and i replaced the cartrige and still no hot water can you help
  • Anonymous Mar 23, 2014
    replaced my cartridge and now I have no water at all...
  • 10,865 Answers
The problem is that the supply lines feeding that faucet are reversed. That is the cold supply line is feeding the hot side of the faucet and the hot supply line is feeding the cold side.
The fix is to reverse the supply lines where ever they can be most easliy accessed.
Posted on Apr 14, 2009
I have a Sterling tub & shower faucet that is about 25 years old that is leaking. I have replaced the seats & stems but it still continues to leak a small steady stream out of the tub spout. The...
Your fixture body may be corroded beyond repair. Since you've replaced all the rebuildable parts, I'd suggest you get a plumber to check it but expect that you'll need to replace the faucet. Get a modern "cartridge" (Delta, Moen or Kohler) fixture that can be easily repaired indefinitely.
Oct 28, 2017 | Sterling Plumbing
Have a two handle Sterling shower stall. The shower head is leaking from the cold water inlet. Believe need a replacement stem. Have changed the O ring but has not stopped the leaking. Is there any...
The part # you supplied is for a shower door and has no bearing to your question. There is no relationship. However, I can say there is no adjustment for any two handle shower stem or even single handle stem. Very rarely will just replacing an "O" ring stop a drip unless it it from through the stem itself and comes out under the handle. When in doubt replace the whole stem...shortcuts will only exasperate the problem. There are no shortcuts in plumbing.
Oct 24, 2010 | Sterling Plumbing 1500D-31S VISTA PIVOT...
No cold water from Moen 2253 tub/shower valve, when i turn handle to cold I get hot water, when handle is turn to hot i get hot water
Here is a quick check to see if the cartridge may be at fault allowing the cold and hot to mix. Turn off the hot water supply, with hot water supply off turn faucet on. Turn to the hot and cold sides, If you have only cold water then your faucet cartridge is at fault or the cartridge housing is worn. Shut all supply valves and remove cartridge and inspect housing for signs of wear. If wear is visible a new shower valve is needes. If none visible replace cartridge. I have included a link of a PDF file an exploded parts list. I hope this helps in solving your problem. Please rate if the answer helps in any way. Good Luck and have a great week. Jeff
Apr 05, 2010 | Moen & One Handle Tub & Shower Faucet
Problem with Sterling stem.when transfered to shower,still leaks
You did not tighten the stem enough, allowing the seat to rise just above the cavity where it will sit. You may also have scaling in this area preventing the seat from sitting flush.
Feb 03, 2010 | Sterling Plumbing 1500D-31S VISTA PIVOT...
Very little pressure/flow rate at all hot tap outlets
where the cold water goes into the hot water heater (marked cold) there should be a "shut off" valve, close it then open it,...sounds like there is something stuck inside "before" all taps,.meaning your taps are fine,...things can get stuck in that one shut-off,....if this does nothing to rectify problem write me back with type of hot water heater,...boiler (tankless) or a tank,...electric or indirect from boiler
Jan 03, 2010 | Sterling Plumbing 1500D-36S "VISTA PIVOT"...
Parts for sterling shower faucet
http://www.sterlingplumbing.com/contact.strl
The above link is the contact info for Sterling Plumbing Company. You can contact them and they will either be able to mail the parts out to you directly or tell you where you will be able to find repair parts.
Apr 17, 2009 | Sterling Plumbing 1500D-31S VISTA PIVOT...
Sterling One levr faucet
The problem is that the supply lines coming into that shower faucet have been installed wrong. In other words, the cold is on the left side and the hot on the right side, just the opposite of what it should be. This is an easy fix if you can get to the pipes feeding the shower.
Apr 14, 2009 | Sterling Plumbing 1500D-31S VISTA PIVOT...
Sterling Plumbing 1500D-31S VISTA PIVOT SHOWER DOOR Logo
445 people viewed this question
Top Sterling Plumbing Home Experts
john h
Mike
Rabbit Brains
Rabbit Brains
Are you a Sterling Plumbing Home Expert? Answer questions, earn points and help others
