Question about Samsung HCN4226W 42" Rear Projection HDTV-Ready Television
Perfect Focus not working
I had a convergence problem which was fixed by a Samsung Technical service center and cost me $367.00. The perfect Focus function keeps giving me a message "Sensor Data no Found". Technican tried to fix the grids at my home and then said the TV needed new part. They say the part is no longer available. Samsung says TV had 2 versions and that Version 1 is okay but Version 2 not. What is needed to fix the perfect focus problem? Techical center said part $290.00 is not avaliable. What part is it that I need?
I have a hcn 4226 w,and I have replaced the bourd complete with the ci's.....cost me $ 104.39 with shipping and handling included.
Repairman wanted 350.00 + Took me no more then 2 minutes to change TV works great again,but has what almost looks like a drop of pink dye was dropped in the middle of the screen at the top ,and misses the screen a bit then has ran with a small spot at the end of that. Can anyone help me with this.
Thanks.
Posted on Jun 22, 2009
  • 60 Answers
I know this post is old, but for others, I apparently pulled out the connector from the sensors to the CG module when I took the front panel off. The module is the silver box, third box from left.
Plugged it back in, and the perfect focus now works.
-dan
Posted on May 17, 2009
    Sergeant:
    Champion:
  • 375 Answers
Enter your service mode by pressing mute-1-8-3- a cross hatch pattern should apear,when it does and it looks alright press and hold the enter key the ,it will say data write then press the focus key the set will align your sensors and retuen to the cross hatch pattern ,tune off set and turn back on and try the magic focus ,should work.
Posted on Sep 13, 2007
Green & Blue Ghosting Convergance problem
Odds are real good that the cooling fluid in the green and blue picture tube assemblies has become contaminated. You can tell by looking down into the lenses with a flash light. Funny thing is the red never gets contaminated because whatever organism is causing the problem can't survive in red light. BTW this may still not solve all of your convergence problems but when the colors are so badly diffused the convergence sensors for flash focus can't lock onto the beam landing.
Jun 01, 2009 | Samsung HCL473W 47" Rear Projection...
Samsung Projection TV - Yellow White Level and Auto Focus Failure
perfect focus is based on service mode convergence. FActory setting as it were. the set needs to converged in service mode then these values stored then it should work
Jan 03, 2008 | Samsung PCL541R 54" Rear Projection...
"Perfect Focus" problem on Samsung HCN4727W
You have a bad sensor, a bad digital convergence board, or the new board is not working correctly. I would start by swaping out the convergence board or exchange it for another one. Good Luck
Nov 08, 2007 | Televison & Video
Convergence perfect focus not working and double vision
The problem you have is the 2 STK - 392 convergence integrated circuits need replacing the cost in the UK is about £150.
SUPER8
Nov 26, 2008 | Televison & Video
Auto focus
you will need a service tech to alien the convergence in the service mode then perform the perfect focus in the service mode to lock this setting in memory.
Jun 21, 2008 | Samsung HCN5527W 55" Rear Projection...
My samsung projection tv #pcl5415r don't want to perform perfect focus adjustments
perfect focus functions are based on service mode setup...or factory settings. if the alignment of these setting are loss then the unit wont perfect focus. does the unit have a complete loss of convergence. a complete loss of convergence indicate possible failure of convergence amps.
Red lines, Help??
when you replace the convergence amp board. u usally have to go into setup. or service mode and manualy converge the set. these settings are what perfect focus basis it reconvegence on. sort of the factory settings. these faint lines may also be a red crt overdriving too
Jan 03, 2008 | Samsung HCN5527W 55" Rear Projection...
Perfect Focus 2
Use a site like servicemanuals.com and get the service literature for your make/model.Do NOT perform factory reset procedure-that is reserved for when certain parts are changed.You will need the access sequence,adjust info and add to memory step for servicer convergence.Keep in mind--you may have defective convergence IC's.If so,you will have difficulty w/alignment.Use OEM or better IC's no generics!! They won't hold up.
Sep 27, 2007 | Samsung HCN5527W 55" Rear Projection...
Perfect Focus
Perfect "FOCUS" is a misnomer.Convergence is the real issue.Enter servicer mode--perform accurate convergence alignment procedure--activate perfect focus as last step to 100% alignment.If you have a High-Definition source,check procedure for that.
Reverse fisheye!!
you are going to need to replace the convergence board assembly. It is available at http://www.samsungparts.com/part_detail.asp?catalog%5Fname=Parts+and+Accessories&product%5Fid=BP95%2D00142P&search%5Fmodel=HCN653W. Also get the service manual, as you will need to do some touchup convergence and reset the perfect focus setup again If you have the technical ability. If you do, great! If you do not, these service menu alighnments can mess up your set, so take no shortcuts. Good Luck
Mar 29, 2007 | Samsung HCN653W 65" Rear Projection...
Samsung HCN4226W 42" Rear Projection HDTV-Ready Television Logo
687 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
