Question about HP Pavilion zd7010us PC Notebook
Screen gets dim at times.
My screen seems to get dim at times. brighter in the center and fades to the outer edges. example the bottom bar where start menue , time and other programs are faint. Used to be brighter so I could look at it in a glance. Now I have to look hard to tell the time.
  • 538 Answers
Backlight is going bad.
Either bulb or whole LCD needs replacement.
But, first start with new/good Inverter Board.
Posted on Apr 14, 2009
What is the reason for my E701i-A3 failure? All boards were replaced, worked for a minute, and then had the same "fade to black" failure as the first time.
Your back light controller board or the ballasts for them may be bad if they weren't incorporated into the power supply board.
Dec 05, 2016 | Televison & Video
Even with brighter headlight bulb still don't seem like there very bright any ideas on my 93 Saturn sl
Dim headlights are often a result of the hazing of teh outer plastic or glass shell that protects the headlight. Try a polishing kit.
Look here for an example: 3M Lens Renewal Kit
View the video here:
Dec 23, 2014 | Cars & Trucks
How to remove screen protector from a hitachi 50ux52b
The entire screen comes off from the front.
Remove front speaker grill (should pull off)
Behind it at the bottom of the screen are a row of screws that secure the screen with frame to the cabinet.
the entire unit pulls out (bottom right and left first) and when free lifts up to pull off.
With the entire frame and screens off--you have to take the inner screens out first---careful to note which is facing forward and upwards---you can put them in backwards or upside down--will not work right.
Most of the Hitachi's the two inner screens are taped together along the edges but if not you have to be real CAREFUL- THE thin outer one is easily shattered or damaged.
You may have to take the frame apart to get the other (outer one) out as it is usually in a slot or track.
Screens have to go back in at exactly same direction and position as when you started.
The inner ones usually are held in place with strips of plastic or metal secured with screws--careful not to strip the holes out with a screw gun.
Clear one is (outer) only protective but does have an anti-glare coating so that can be an issue--picture will be brighter.
for questions or information press the "make a comment button" on this page.
Mar 25, 2012 | Hitachi Televison & Video
Picture is lighter outer edges
Does it happen on every input? Play a dvd, is it the same. If you, you need a repair. Contact the manufacturer for an authorized servicer.
Jul 30, 2010 | Sony Grand WEGA KDP-57WS655 57" Rear...
I have black spots on my monitor screen that seem to multiplying.
The black dot will just grow until the rest of the screen fades.
It is pixels dieing in the monitor
Jul 22, 2009 | Computers & Internet
Timing marks for a daewoo nubira cdx
on bottom pulley there is a mark on the outer edge. line this up with the peg in the lower plastic cover.
on both top cam gear pulleys, there are punch indentations on them. get a straight edge like a mettle rule. place it through the bolts central and line the two cam pulleys to the outer making sure the rule is in line with the indents and the bolt centers. fit belt then recheck. DO NOT START ENGINE YET.remove all spark plugs. turn engine over by hand with a bar and socket to bottom pulley. DO NOT BE TEMPTED TO TURN OVER BY STARTER MOTOR. as this will bend most of your valves. if the engine turns over one complete revolution. then refit all the spark plugs and start engine.
Jun 05, 2009 | 2000 Daewoo Nubira
Line down middle of screen. TV is brand new fresh out of the box.
It is a bad unit. If it's new, get it replaced, there is no repair for this problem. Hope this helps.
May 31, 2009 | LG 50PX5D 50 in. Plasma HDTV
Rear Projection TV -- Bright spot with yellow edges on TV screen
if it is a panasonic pt-50lc14 then you will need a new bulb. you can find them online, do a yahoo or nextag search for the ty-la 1000 bulb and you can find them for around $100...
Mar 11, 2009 | Panasonic PT-50LC14 50" Rear Projection...
HP Pavilion zd7010us PC Notebook Logo
211 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
