Question about Dell Dimension 4600C PC Desktop
Problem with Dell 4600C
I have a Dell 4600C where I can't seem to find the driver for a PCI Simple Communications Device Driver I can't seem to download it anywhere? Where can I find It?
Go To Dell,com
Then Support Put Your service tag number in there If You can't Find it on Your Computer (It Is located in side the front cover) Reboot hit F2 this cmos will come up there you will see the service tag nomber Put That number In the Xervice Tag Box Under Drivers and support.
Best reguards
Larry
Posted on Aug 13, 2011
  • 20 Answers
Dimension 4600C driver
Developer: Dell
Version: 1.16.0
System: Windows XP,Windows 98,Windows ME,Windows 98 SE,Windows NT SP4,Windows Vista,Windows 2000 SP4,Windows 3.11,Windows NT SP3,Windows NT SP2,Windows 95,Windows NT,Windows 2000 SP2,Windows 2000
License: freeware
http://support.dell.com/support/downloads/index.aspx? here you will find your solution
Posted on Apr 14, 2009
Sony vaio vpcy21s1e/p
simple communications controller is likely a modem, sound card, or network card. If your sound was not working, you would know, and similarly with your network. So try sound card drivers next.
Feb 03, 2012 | Computers & Internet
Pci simple communications controller
Hi go to dell site the pci is a modem pug on to the router the pci will go the other usb will be ok if you go on to the dell site and down load the usb ,regards clive
Jan 27, 2012 | Dell Dimension 3100 PC Desktop
PCI Simple Communications controller
Hi, yes you need the right driver, do a google search for the driver, there are many sights where it will be free.
Jul 05, 2010 | Intel Motherboard
Description: PCI Simple Communications
Hello sainz_pm,
This Driver Detective site might be able to help:
http://www.driver-fix.com/updatedrivers.php?t=Pci%20Communication%20Controller%20Download
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Jan 28, 2010 | Gateway BCM94306MP Network Adapter
Motherboard Simple PCI Communications Driver Code 28 for modem
Hello, Mike.
In case you still need this:
To find and install the driver for the simple communications controller:
Go to Device Manager and click on the pci simple communications controller
Go to Properties and then Details. You will see a code like PCI/VEN_8086&DEV_27D8&SUBSYS...
The VEN code means vendor and the DEV code means device: in the example the vendor is 8086 and the device is 27D8.
Once you have the two codes, go to www.pcidatabse.com. Enter the two codes and you should get the name of your hardware.
From there, you can search for a driver download for your hardware.
Hope this helps.
Mar 29, 2009 | Gigabyte GA-7VA Motherboard
Dev Man Errors / drivers
Go to www.support.dell.com and select "I'm looking for drivers and downloads". If you don't have the proper version of Adobe you will be prompted to install it. Once installed return to "drivers and downloads" and enter the "service tag",(serial number) of the 820 laptop. Dell keeps a listing of drivers for every customer's computer they sell.
The PCI device, simple communications controller is your dial-up modem card.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Jul 01, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
i cannot get the sound from the TV tunercard as the PCI simple communications controller in the device manager is showing yellow question mark
Feb 21, 2008 | EliteGroup 741GX-M Motherboard
PCI Simple Communications Controller
Hi, I have a solution. If you go in device manager, click on the pci simple communications controller, go in property and then go in details. You will see a code like per example PCI/VEN_8086&DEV_27D8&SUBSYS...
The VEN code means vendor and the DEV code means device: in my case the vendor is 8086 and the device is 27D8.
Once you have the two codes, go to www.pcidatabase.com. Enter the two codes and you should get the name of your
hardware. From there you can search for a driver download for your hardware.
In my case the pci simple communications controller was a Microsoft UAA Bus HD audio. I also had another pci
device that didn't work properly, using the same method I found out that my pci device was an HSF PCI internal modem with code number CX11252-11. I had a hard time downloading one of the drivers, after 6 or 7 times the download started so be patient if you have the same hardware
NOTE: to access the device manager, go in control panel, then performance and maintenance, system, hardware and finally device manager.
Hopefully this helps you, good luck.
Dec 07, 2007 | Gigabyte GA-7VT600 1394 Motherboard
Dell Dimension 4600C PC Desktop Logo
130 people viewed this question
Alun Cox
