Question about Select Brands Matsonic mATX 800Mhz s775 P4, VGA/Audio/Lan DDR400 SATA RAID 0, 1, 3PCI 1 8X AGP, 8X USB2.0(BRAND NE... (MSP4M800M) Motherboard
Raid none define
I have this PC for about 2 years, recently I installed an extra 512MB RAM on the second slot to a total of 1GB but when I start up, I have this problem of no Raid, hence unable to use my SATA hard disk to boot up anymore, when using restart button, the PC went into safe mode. How can I resolve this problem? Thanks.
  • 150 Answers
Try getting into your BIOS (usually F2 key at first screen, could also be F10 or Del) and check if your hard drive is in RAID or IDE mode. SATA drives can be run in either. Although it is somewhat odd that a simple mem upgrade could case a raid problem.
Posted on Sep 13, 2007
SOURCE:
IBM T23 wont turn on after adding new RAM
Hi - according to memory suppliers your T23 has the following memory capacity / requirements:
  • IBM ThinkPad T23 maximum RAM capacity: 1GB
  • Your IBM has Two (2) memory slots or sockets
  • Module upgrade PIN count is: 144-PIN
  • The memory speed is: SDRAM 133MHz, PC133
  • The laptop DIMM type for the ThinkPad T23 is: SODIMM, SO-DIMM, Small Outline DIMM
  • Non ECC
If you are meeting these requirements, you may have a defective module.
Also, according to Lenovo's page on the machine:
Memory
The system has 128MB or 256MB of memory standard and can be configured for up to 1GB of addressable memory. Memory options up to 512MB SDRAM SO DIMMs each can be added in the two available slots for memory expansion. The standard 128MB of memory is expandable up to 640MB and the 256MB of memory is expandable up to 768 MB of addressable memory with 64, 128, 256, or 512MB SO DIMMs without removing the 128MB SO DIMM that is standard in one of the internal slots for memory. For customers that need the maximum 1GB to which memory can be expanded, it is necessary to replace the 128MB or 256MB card with a 512MB card plus add another 512MB card in the extra slot. Only 133MHz DIMM memory can be used in this system. The use of 100MHz DIMM memory is not supported in the T23 systems.
This means yo can trouble shoot the 512MB modules individually by installing one of the original 128MB modules and one of the new 512MB modules (for a total system memory of 640MB). If it does not boot, try again with the other 512MB module. This will help you identify a defective module that may be preventing the machine from booting.
I hope this helps & good luck!
Sep 28, 2012 | IBM ThinkPad T23 Notebook
How to install memory to my Acer Aspire 570 G Notebook PC
Most laptops have a panel on the bottom of the laptop that provides access to the RAM memory slot/s. Remove this panel to reveal the RAM slot, Insert a RAM module that is the same make and model as the original one.
If your laptop has a single 512Mb RAM module then add another 512Mb of RAM to increase the total RAM to 1Gb.
Feb 24, 2012 | Acer Aspire Notebook PC
214-Dimm Config Warning
Just had same problem. Found a solution:
I have an old HP Compaq dc5000MT. It has 4 RAM slots
Here's what DIDN'T work:
1gb + 1gb + 512mb + 512mb
1gb + 512mb + 512mb + 1gb
512mb + 1gb + 1gb + 512mb
Here's what DID work:
1gb + 512mb + 1gb + 512mb
I'm sure that:
512mb + 1gb + 512mb + 1gb would probably work as well.
From my guess they're are 2 "channels" (slots 1&2 are channel 1, slots 3&4 are channel 2) and you have to keep the amount of RAM balanced on both slots and in the same order.
Another thing to note with the old XP OS. IT ONLY WORKS WITH 3GB or RAM. MAX. So 1 + 1 + 1 + 1 (4gb) WILL NOT WORK... PERIOD for XP. Vista, 7, 8 etc. allows you to use a ton more ram + readyboost. They need all the help they can get though since they are major resource hogs.
Aug 15, 2011 | HP Compaq d530c PC Desktop
What is the max ram speed my pc can take
According to some research, your desktop has 4 RAM slots available. The total maximum RAM your desktop can hold is 2GB (2048MB). Furthermore, each slot can hold a maximum of 1GB (1024) but cannot exceed the 2GB total.
This means you can theoretically install 2 x 1GB RAM DIMMS in 2 RAM slots or 4 x 512MB RAM DIMMS. Both will meet the desktops 2GB limitation.
The RAM specifications for your desktop are as follows:
RAM Limit: 2GB (2048MB) RAM Slot Type: SO-DIMM RAM Type: DDR1 (not DDR2 or DDR3) RAM Speed: PC3200/DDR400 ECC Type: Non-ECC
TIP: The RAM is DDR which means that while you can install them as singles (single-channel mode), the system will see a speed benefit from installing them as matched pairs (dual-channel mode).
Aug 14, 2010 | Sony VAIO VGC-RB34G PC Desktop
Beeping noise after installed memory on ecs motherboard L4S5MG
Some older computers, like mine, have a maximum memory they can handle. This one happens to be 1 gig, but yours may be less. Do you have an older computer? Yup, you do. As seen here, the maximum supported ram is 256. I'm sorry. Please rate.
http://www.dealtime.com/xPF-E-Machines-eMonster-500a-EMONSTER500A
Jun 18, 2009 | E-Machines eMonster 550 PC Desktop
Adding memory, new total not recognized: IBM Thinkpad R51e-1844
Ram should always be paired. Same type, speed and size in each slot. You may have 1 SIMM/DIMM/DDR that has 2 sides of chips and the other with 1 which will do exactly what you state. RAM reads across the chips simultaneously. So if you have a different one in each slot it can go bonkers and do goofy stuff on you.
Jun 14, 2009 | IBM ThinkPad R51 Notebook
Computer will not work with extra 1gb ram
It sound like you have incompatible memory. Try taking out the original 256 and test with the 1 gig. Keep in mind some PC requires memory to be paired. If you only have one, 1gig memory chip you might need to get another. I would try removing the 256 first. The specification of the motherboard would also tell you the memory usage.
Let me know if this helps!!
Joe
Mar 25, 2009 | Dell Dimension 1100 PC Desktop
Upgrading ram
Hi reisrui, yes it is odd. (It's not the first time I have seen this.)
According to you're manual on page 6, under Specifications. The manual say's you can run up to a Max speed of PC3200 400MHz, 1GB in slot one. In slot 2 you can run a Max of 1GB of PC2700 333MHz in slot 2. Every motherboard I have come across that can run two different speeds of memory. The system will reduce the Max speed to the lower MHz memory speed. If you currently are using 512MB PC3200 400MHz in slot 1 & add 1GB of PC3200 400MHz into slot 2 for a total of 1.5GB of memory. The motherboard will ruduce the total memory over all speed to PC2700 333MHz. Motherboards alway run at the lower memory speed if two different speeds are presant.
I can’t be 100% sure of the 1GB of PC3200 400MHz into slot 2, will run at all! Or if it will be reduce down to 333MHz. I am sure you can run 2GB of PC2700 333MHz, 1GB of memory per slot in you're board for a total of 2GB.
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
May 27, 2008 | Asrock 775VM800 Motherboard
Open Questions:
SBCglOBaL TecHNicAL SuPPoRt */+1^855+536+5666NuMbER ^+%, ARIZONA It doesn't matters that which kind of problem faced through the users,the support 1*855*536*5666 team that has been appointed for Sbcglobal is quite intelligent and impressive in solving the technical difficulties belongs to different categories.For contacting the technical team users needs to do the instant connectivity over the help number 1*855*536*5666 that has been given on the website.First the users would be accessed through the experts by the help of the remote access technique that is quite convenient for the detection of the respective issue.The technique that would be used to solve the technical problem depends upon the criticality of the problem.One user can have more than one email account. May be user wants to close any one and thus want to have all the contacts in another existing account. It is not difficult to have the contacts transfer from one account to another 1*855*536*5666 one. Sbcglobal email users can call our anytime to get connected with one of our highly trained technicians who are available round the clock to offer most smart solutions to any issues. Not just this, our team of technical support 1*855*536*5666 also offers 100% reliable technical resolutions through SBC yahoo DSL support number and . Our email specialists have been highly trained and are totally adept in offering the best solutions for just about any SBC customer care related tech support issue that you may be facing. This is called as Import/ Export.
Oct 21, 2019 | Yahoo Computers & Internet
SBCglobal MAil TecHNicAL*/-+* {1-/855/*536/*5666/}#[email protected] SuPPoRt NuMbER CUSTOMER SUPPORT This SbcGlObAl mAiL USA phone number is ranked #2 out of 2 because 7,728 SbcGlObAl mAiL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:855:,:5365666 is to reach the SbcGlObAl mAiL USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, SbcGlObAl mAiL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. SbcGlObAl mAiL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I********** and ways to call or contact SbcGlObAl mAiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling SbcGlObAl mAiL USA Calling SbcGlObAl mAiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from SbcGlObAl mAiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with SbcGlObAl mAiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare SbcGlObAl mAiL USA's phone numbers against each other. Contacting SbcGlObAl mAiL USA in General While I********** is SbcGlObAl mAiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I********** is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach SbcGlObAl mAiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact SbcGlObAl mAiL USA.
Oct 21, 2019 | Best Computers & Internet
#^%*& Amazon Prime rEfUnD pHoNe O*^%{+1++85O++8I2++4OO9*^ USA how to get refund from amazon prime Amazon Prime Refund Phone Number +1-85O-8I2-4OO9. AMAZON PRIME Tech Support Number +1-85O-8I2-4OO9 to resolve all AMAZON PRIME products. End Your Amazon Prime Membership You can end your Prime membership by clicking the End Membership button on this page. Paid members who haven't used their benefits are eligible for a full refund of the current membership period. [1``85O`-8I2`-4OO9``] UsA Amazon Prime Technical SuPpOrT Number +1-85O-8I2-4OO9 to resolve all Amazon Prime products. Amazon Prime is an American multinational company which was founded by Michael Amazon Prime using its company headquarters in Round Rock, United States of America.Contact Amazon Prime for Setup & Installation Amazon Prime Setup Support & Installation Amazon Prime Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere. Facebook is an internet social media and networking website and with Facebook, you'll be able to share something like permitting registered users to create profiles, upload photos and videos, send messages and keep in contact with friends, family, and colleagues. To find out new things and knowledge completely different places beauty we tend to arrange our tour at reasonable costs. Then you'll watch United Airlines, here all of your needs are fulfilled at a minimum rate. Alaska Airlines could be a major USA airline headquartered in SeaTac, Washington, inside the urban center metropolitan space of the state of Washington. it's the fifth largest airline within the u. s. once measured by fleet size, scheduled passengers carried, and variety of destinations served. Walmart is committed to providing you superior customer service and a nice searching expertise. We're happy to retort to your questions about Walmart com connected queries. The best Walmart phone number with a tools for skipping the wait on hold. The customer can Call Walmart com customer service faster by CSPN. Contact Customer Service team to provide a comment or ask a question according to your problems. This is Amazon's best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a Amazon agent. This phone number is Amazon's Best Phone Number because 1,820,712 customers like you used this contact information over the last 18 months and gave us feedback. Common problems addressed by the customer care unit that answers calls to +1-85O-8I2-4OO9 include Return an Order, Missing Delivery, Refund an Order, Dispute a Charge, Can't Login and other customer service issues. The Amazon call center that you call into has employees from Arizona, Washington, North Carolina, India and is open 24 hours, 7 days according to customers. In total, Amazon has 1 phone number. It's not always clear what is the best way to talk to Amazon representatives, so we started compiling this information built from suggestions from the customer community. Please keep sharing your experiences so we can continue to improve this free resource.
Oct 21, 2019 | Amazon Computers & Internet
See all Select Brands Matsonic mATX 800Mhz s775 P4, Questions
Select Brands Matsonic mATX 800Mhz s775 P4, VGA/Audio/Lan DDR400 SATA RAID 0, 1, 3PCI 1 8X AGP, 8X USB2.0(BRAND NE... (MSP4M800M) Motherboard Logo
469 people viewed this question
Top Select Brands Computers & Internet Experts
Ekse
Marvin
Marvin
Are you a Select Brands Computer and Internet Expert? Answer questions, earn points and help others
