Question about Toshiba Satellite 5205-S503 Notebook
No network connectivity, missing drivers
I just did a clean install of XP Pro on a toshiba satellite 5205-s503 laptop.
Went to Toshba for the drivers and got most of what I needed using another machine. The device manager indicates missing drivers for the Ethernet controller and the USB controller. Nothing from Toshiba will correct this problem and as the unit will not access the internet, it can't go look for drivers.
So as a work around, I tried to install an old trendnet TE100-PC16R pcmcia ethernet card but it will not install on XP. So much for that idea.
The computer almost connects to the router using the onboard cat 5 connector, but comes up with a "limited or no connectivity" due to the fact that the router did not assign an IP to the laptop. I tried assigning a static address to the laptop and used two good Dns's but still no luck accessing the internet.
Ron
  • mottly513 May 11, 2010
    Thanks to pontelemon
    I already have the dhcp enabled on the router. Have other wireless
    devices that work with no problem. Linksys G Mimo router.
    And, I have already tried that Toshiba driver to no avail. So, another workaround,
    I connected a USB network adapter to get the laptop online.
    That has worked. I then tried to do an "update driver" on the Ether controller, again no luck. But the system found the proper dirvers
    for the USB controller so, that is no longer an issue.
    This is an interesting challenge.
    Any more ideas.
  • 538 Answers
Enable DHCP on the router.
And try this driver:
http://cdgenp01.csd.toshiba.com/content/support/downloads/s240ethx.exe
Posted on Apr 14, 2009
My satellite 5205-s503 wont turn on, the power light just blinks
Try plugging it into a different outlet. If that doesn't work, test your ac adapter. Check the voltage for 19.5v.
Jan 26, 2014 | Toshiba Satellite 5205-S503 Notebook
Upon bootup attempt there is no itial beep, comes up w/ hdp1password= on display and monitor displays toshiba splashscreen...?
The hard disk has a password on it. If you haven't activated yourself then it went active on its own, a sign that the disk electronic board is dying. This can't be fixed, the hard disk is practically dead so take it out of your laptop before it damages something else. Then put in a new one and reinstall Windows.
Dec 08, 2010 | Toshiba Satellite 5205-S503 Notebook
I Forgot My Laptop TOSHIBA Satelite 5205-S705 BIOS password. So it,s Locked Permenently, and when i typed any passwords i used the system will be shutting down after 3 trials. Finally am unable to found...
Please open your laptop and in motherboard there is one mini cell is attached and it remove half and hour and then attached the cell in motherboard and then start your laptop it will be unlock your bios passward.
Nov 06, 2010 | Toshiba Satellite 5205-S503 Notebook
Forget password bios toshiba satlite 5205
To reset the BIOS read the information from this link.
In case of your Toshiba Satellite laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
Oct 20, 2010 | Toshiba Satellite 5205-S503 Notebook
My acer netbook screen is always dim even when it is plugged into the wall
adjust brightness settings on most acer laptops u hold the FN key and press one of ur arrow keys quite often the left and right for brightness up and down hope this helps
Mar 11, 2010 | Toshiba Satellite 5205-S503 Notebook
I want to restore my toshiba satellite 5205-s503 to factory settings. please help. i tried the whole pressing f8 repeatedly thing and there are no options to restore the computer to factory settings.
You will need the restore cds that came with your laptop. Insert the restore cd in your dvd drive and restart your computer. When the message "Press any key to boot from cd" press enter.
Then follow the on screen instructions to restore your computer.
Regards,
nicolasiac
Feb 12, 2010 | Toshiba Satellite 5205-S503 Notebook
Toshiba satellite 5005-S504 boots over and over and over non stop
It sounds like the hard drive is dying. I had a computer do the same thing and it turned out to be the hard drive. You should still be able to access the bios though. Try hittind either delete or F1 as soon as your toshiba screen appears.
Jul 10, 2009 | Toshiba Satellite 5005-S504 Notebook
5205-s503
Its a little lengthly to explain so I pasted the website that talks about what to do with a Hard Drive Password Lock. Good luck and let me know if you have any questions. Rate this with 4 diamonds before logging off..here is the website:
http://www.computing.net/answers/security/hard-drive-password/14916.html
Mar 07, 2009 | Toshiba Satellite 5205-S503 Notebook
Assembly manual
I wasnt able to find a manual but keep in mind all the toshiba screw holes should be labeled by length of the screw in MM. That should at least help with the ones on the outside of the case. The ones that hold the motherboard in have arrows next to them.
Hope this helps!
Dec 30, 2007 | Computers & Internet
Toshiba Satellite 5205-S503 Notebook Logo
233 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
