Question about Dell Inspiron 4100 Notebook
I can receive emails but when i try send or even reply a screen pops up with a coded line which it asks me to recreate in a box however when i try to do this my computer freezes up and it will not allow me to enter the code. The code is suppose to help eliminate span. Can you help me.
Can receive but cannot send on my tablet
Help! I Can't Send E-mails From My Tablet! - WorldStart
www.worldstart.com/help-i-cant-send-e-mails-from-my-tablet/
Jan 22, 2015 - I can't send emails or replies or forward from my Tablet how can I put this back ... The instructions below are for Android, but similar steps could also ... stable Internet connection when you're trying to send and receive e-mails?
POP3 email receives but won't send. - Android Forums at ...
forums.androidcentral.com > ... > Verizon Galaxy S3
Oct 17, 2012 - 25 posts - ‎17 authors
I configured the email app using my own server for incoming mail (pop), .... I canconnect to the Internet and receive mail, but I cannot send mail. Why can't I send outgoing messages on my email account?
Oct 22, 2014
On my LG G3 why can't I send an email from the email ...
Oct 20, 2014
Can't Send MMS Messages
Oct 6, 2013
Can't send e-mail from phone
May 17, 2012
More results from forums.androidcentral.com
Can't send SMS text but can receive and c
Jan 20, 2016 | Le Pan II 9.7" Tablet PC
I cannot reply to an email but am able to send emails out if they are originated by me
try saving it as new first, then try replying to it I have had this happen if the person I am replying to has blocked me; not your case if you are able to get through with a new email.
Mar 08, 2015 | Microsoft Windows 7 Home Premium 64BIT...
How do I send email to be sure the recipient receives it?
Send yourself a Cc to make sure the email got sent.
In the body of the mail ask for a reply, even if they only press Replay (explain why.)
If the address is not valid you should by rights receive a Failure message.
Dec 14, 2014 | Computers & Internet
I receive emails on my mac and some I forward to friends,but their unable to open them youtube etc and ask I send again but when I try I cannot open either. Please Help
Hi Richard. Thers a good chance you have mail preferences setup to compose new emails in "plain text". And/Or, "Use the same message format as the original message", meaning if you reply to someone who sent you an email that is in Rich Text Format, then your reply will be in Rich Text Format but, if they send you an email in Plain Text Format, then your reply, and possibly any forwarding will be sent in Plain Text also.
For website addresses to be "clickable links" in mail, you need to ensure all emails you send, forward, or reply are in Rich Text Format.
go to Mail... Preferences... then select the Composing tab and ensure Message Format is set to "Rich Text".
Further below in the same tab you will see "Responding" and a tick box for Use the same message format as the original message (Respond using Rich or Plain Text).
If you always want to respond or forward in Rich Text only and every time, then deselect that option.
All links should work and be clickable from then onwards.
You can highlight a non working website link in the email body, right click, then select "Link" then "Add Link" to make it clickable but, you will receive a notification about converting this message to rich text format?"
Basically, the links will not be clickable if you are setup to compose new emails in Plain Text. Nor will any replies or forwards you send that are changing to Plain Text to match the format received by you from others.
Always end, reply and forward in Rich Text Format
Hope that helps.
Regards
Paul
25295420-oyfl2tub33bpl2bhga1p2n43-3-0.png 25295420-oyfl2tub33bpl2bhga1p2n43-3-2.png 25295420-oyfl2tub33bpl2bhga1p2n43-3-5.png
Nov 24, 2014 | Apple iMac 24" Desktop
I am unable to get into my email. A box pops up stating
I've recieved the same verification code,but the one I got worked
here is a phone number to try & see if yahoo support can help
Phone: 866-562-7219
Sep 02, 2012 | Yahoo Mail
I am not able to send or receive any mail on my yahoo account.
How do you access your Yahoo mail? Is it via the browser (www.yahoo.com) or via MS Outlook?
If you're having a problem of sending/receiving emails while using the web browser, you may want to delete old and unnecessary emails. You could have reached the storage limit of your email account.
But if your using an Outlook, you need to double-check the account settings. Make sure that you have the correct user name, password, incoming and outgoing servers, incoming and outgoing ports.
If you setup your email account using the POP protocol, you may use these server ports:
Incoming: 110 or 995
Outgoing: 25 or 2525, or 587, or 465 (SSL)
For IMAP:
Incoming: 143 or 993
If the same problem occur, you may try to delete your account and recreate it. Please bear in mind that if you deleted your account and recreated it, some emails may no longer appear or get downloaded.
Thank you and good luck!
Dec 13, 2010 | Yahoo Mail
No email can not be sent or compuse or reply
After deleting and recreating an account in Mail, you might not be able to send emails even if you can receive them. When you try to send a message, this alert may appear:
"Cannot send message using the server smtp.xxxxx.com"
This happens if the Simple Mail Transport Protocol (SMTP) server, used for outgoing messages, was incorrectly entered with the first account even if it was correctly entered for the replacement account.
Products Affected Mail
Resolution You should first verify that the network connection you're using is the correct one for the ISP that you want mail to communicate with.
  1. Open Mail.
  2. From the Mail menu, choose Preferences
  3. Click Accounts.
  4. On the Outgoing Mail Server (SMTP) pop-up menu, choose Edit Server List.
  5. Delete all entries for the SMTP server that is mentioned in the error, and click Done.
  6. Configure the current SMTP server by clicking Server Setting.
    Note: If you need to use multiple SMTP servers for multiple Mail accounts, see this document.
  7. Send a test message to your email address.
Jun 02, 2009 | Yahoo Mail
Unable to receive emails on my POP/IMAP account, but i can send emails (i am on MTN nigeria's Blackberry internet services) firewall is not blocking, its showing 3g blackberry signs as well.
As i understand that you are not able to receive emails from the organization's email id,
-So first check if the inbox in the organization's email id is more than 900 emails,if so than delete or move the mails to other folder other than inbox.
-Check the memory in the blackberry handset also.
-If still not working then login to blackberry.com website (ie..ServiceProvider.blackberry.com) and then delete the organization's email account and then recreate the organization's email account and then click on service book and then click on send service book...And then you will be receiving the service book on the handset and then save it and then you will be able to receive the emails from organization's email account also.
May 22, 2009 | RIM BlackBerry Bold 9000 Smartphone
Vista Windows Email problem
Hey,
I recommend you remove your email account from windows mail, and recreate it.
Thanks,
Ekse
Aug 30, 2008 | Computers & Internet
I can send emails but the recipient does not receive them, any of them. What is the problem?
wrong email address or (mis spelt / typed it)
changed email address.
recepient get your your mail in spam box?
can you contact sender and ask them to send you a email and click reply , see if that works ?.
riz.
Apr 20, 2008 | Computers & Internet
Dell Inspiron 4100 Notebook Logo
20 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
