Question about Garden
I have a Cub Cadet LT 1024 Series 1000 riding mower. It has been starting hard and it is not the battery. Now it tried to start and when I tried a second time to start it there was no sound at all. I'm wondering if the starter needs replaced.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 109 Answers
Try lifting the hood on the mower and turning the flywheel, back & forth by hand, this will release the starter gear from the flywheel.
It could be the starter, but I would load test the battery first.
Posted on Apr 16, 2009
I bought a 1024 1000 Cad Cadet from a good friend but when the mower is on it is very loud, and sounds like a tin bucket. They bought this mower in 2006. What could be the problem?
Posted on May 04, 2009
Will a model OEM 190-621 snowblower fit on a cub cadet LT 1024
Have you tried the cub cadet forum? If not, give it a click:
http://onlycubcadets.net/forum/forumdisplay.php?f=42
Nov 21, 2014 | Cub Cadet Riding Lawn Garden Tractor 25hp...
Cub cadet 1000 series LTX 1040 riding lawn mower
Check the pully alignments with a straight edge. Make sure the belt is tight.
May 19, 2013 | Cub Cadet Lawn Mower V belt Replaces CUB...
Cub cadet riding mower wont start... parking brake feels loose wont turn over
see if the rod fell off there is a safety switch on the clutch/brake pedals if the rod doesn't move all the way the switch will not make the connection
Jun 03, 2012 | Cub Cadet 42 And 54 Inch Blade Operator's...
I have a cub cadet series 1000 LT 1024 need to replace drive belt, how do i get the pto clutch off?
You donot get PTO of to change the belt. if you want to take the pto
clutch Need to turn the opesit way left
May 31, 2012 | Cub Cadet Garden
Need a transmission belt diagram for cub cadet 1000 series
hi there
pauly46 here
i can only suppose its a LT 1018 up ward
here is web site for that model
http://www.partstree.com/parts/?lc=cub_cadet&mn=LT1018+Tractor&dn=0125100003
or you can go to here and choose from this web site area list
http://www.partstree.com/parts/?lc=cub_cadet&mh=12
choose your model from list , then go to drive system
view belt diagram ,
you could save a copy or print them straight off web page
cheers hope it helps
pauly46
Apr 30, 2011 | Cub Cadet Garden
I have a Cub cadet LT 1024 which will not start. The solenoid clicks like it is trying and lights will come on but that is only reaction. Battery is brand new and hooked up properly.
solenoid clicks, only tess you the coil is working inside the solenoid. disconnect cable from battery to starter. with ohm meter check for continuty across main terminals of solenoid while holding key to start. if no continuity, solenoid is defective.
Apr 29, 2010 | Oregon Scientific Electric PTO Clutch for...
Cub Cadet LT 1045 - Not starting, the engine does not turn.
remove the starter...use jumper cables to "run the starter manually...red to big lug, black to body (anywhere is fine) should torque hard at initial run and continue to run smooth...if it buzzes or vibrates, it's bad...replace...
Apr 10, 2010 | Cub Cadet Street Sign- tractor lawn riding...
I have a LT 1024 series 1000 Cub Cadet lawn mower. The PTO shuts off when I'm mowing the lawn. It will run ok if I use the cruse control. I was told it might be a motion switch. Where is this motion switch...
There should be 3 safety switches on the mower. 1 will be under the seat, causing the engine to die if you were to fall off the machine while in gear. 1 is in the transmission to be sure the machine is in neutral when you go to start it, and one will be on the blades to insure they are not engaged when you go to start it. You will not want to bypass this switch, rather get it replaced as it is very important that this safety feature is working should you slip off the seat or accidentally get off the machine when it's in gear.
Feb 17, 2010 | Cub Cadet Street Sign- tractor lawn riding...
I need an owners manual for a cub cadet riding mower. series 1000. model 1042 Lt. serial # 3430203833. thank you
Go to following site http://manuals.mtdproducts.com/mtd/public/list.jsp?BrandCode=10051 Then type in model LT1042 and check your serial no. again as I could not get it to come u.
Mar 31, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
420 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
