Question about Dell UltraSharp 1905FP LCD Monitor
Dell lcd monitor, turns on but only stays on for about 30sec
The colors look a bit dim as it warms up, then after warm, it shuts off. I power back up only to see the screen for 15-30sec and then it shuts off.
Is it worth fixing? How do I test or get parts? cost?
Glad for any suggestions to find specific issue.
    Habit-Forming:
  • 8 Answers
The problem is your backlight lamp is bad. Your description is of very classic symptoms for the backlight. You can either replace the LCD assembly or monitor or try replacing the backlight bulb itself. You'd have to call around to some repair shops to see what they'd charge to see if it is worth it to you to fix it or replace it. Here is a link to a site online that shows the bulbs and how to replace them if you want.
http://www.ccfldirect.com/?gclid=CPPCiNau9JkCFQkzawodGFudQg
Posted on Apr 16, 2009
Screen on my Dell E172FP monitor suddenly turned a pinkish shade. The startup screen appears normal, as does the main menu for positioning, image and color settings. What did I do wrong?
Did you check all the pins on the VGA cable, the connectors are on tightly?
Does it do the same with another PC?
It stays on and gets normal color after warm up?
Please post back what you find. This is really old monitor.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Dec 30, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
My ViewSonic VX924 flashes the green power light off and on when I try to turn it back on after it has been off for a while. I can get it to work again by disconnecting the power in the back then...
I had several monitors do this. They start blinking on and off for a while until they warm up. It takes longer and longer for them to warm up, then eventually they never stay on and blink forever. In my experience, it has been the capacitors on the power circuit. You can fix it with a little soldering and about $1 worth of capacitors. For photos and a guide, look here: Fix an LCD Monitor
Feb 04, 2010 | ViewSonic VX924 19" LCD Monitor
I have a Dell laptop D505. The laptop powers up but the screen display is very dim. I can't see the image on the monitor. I've tried to manually increase the color/brightness button and nothing changes. ...
Sounds like your inverter or your backlight is failing. The inverter is an easy repair, the backlight can be replaced but it involves taking the LCD panel apart, The backlight comes installed on new screens. I can include a service manual below and possibly a generic guide to backlight replacement....
http://support.dell.com/support/edocs/systems/latd505/sm/display.htm#1052500
http://www.laptoprepair101.com/laptop/2007/01/31/replace-screen-inverter-fix-backlight/
Sep 23, 2009 | Dell Latitude D505 Notebook
Hp flat panel monitor comes on shows logon and then blank screen
Ok, another words, monitor powers up for few seconds and shuts down by itself. If green LED on the front panel turns off as well or stays on?
If stays on, then inverter turns into protection mode because of old backlight lamps.
If it turns off in same time with an image on the screen, then there are some bad electrolytic capacitors in the power supply.
Sep 11, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Unable to get monitor out of power save mode
turn your moniter off waite 30sec back on this should get your screen on. Try this Rigth click on your desk'top >properties
>screen saver, click Power then change the turn of monitor tab
Jan 24, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Mag innovision LT716s monitor
When I turn on my computer the monitor takes a long time to warm up and colors change and vertical lines flash across the screen from right to left before the screen becomes normal again. Now the power light even goes out upon turning on my computer and I have to unplug the video cord and plug it back in to start the screen back up which even takes longer.
Feb 19, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
Dell C400 will not boot using LCD screen when cold
I have seen this problem before, after booting to the external monitor go into the display settings and try setting the resolution to 1024 X 768 and the color settng to 16 bit or preferably 32 bit. If you can do this, then shut down the laptop remove the external monitor and try booting on the LCD display. BPCS
Nov 17, 2007 | Dell Latitude C400 Notebook
Monitor stays dim
Chances are it's not the actual CFL back-light bulbs themselves, but the back-light inverter board. If it was the bulbs you would have not had the "warm up and it get bright" issue. The board IS replaceable, (as well as the bulbs) ViewSonic charges about $36.00 USD for the board when they have them in stock. (out of stock as of yesterday 11/14/2006) It should be covered under warranty if you got longer than one year. (I know the warranty was only one year on MY VA800 but I have seen longer offered since i got mine) Good Luck I hope this helps! El Duderino
Nov 11, 2006 | ViewSonic VA721 17" LCD Monitor
Dell UltraSharp 1905FP LCD Monitor Logo
488 people viewed this question
Alun Cox
