2006 Toyota Prius Logo
Service park assist system warning
My prius ran fine right up till the last time I drove it and parked it in my driveway. that was 30 minutes ago. The car was still off as I was sitting in the backseat waiting for someone when I wanted to roll down the window. From the backseat I pushed the power button once, without pressing the brake and the power windows operated fine BUT NOW the car will not start. It seems like an alternate power continues to run. I can hear a soft whir under the front of the hood although the car is not on and the power window still operate. The only warning light that is on is the check engine light and the parking light is blinking. I can tell I am draining the battery.
3 Related Answers
Anonymous
  • Posted on Aug 25, 2009
SOURCE: 96 tercel won't let me shift out of PARK
I have that problem too, there is a little square cap on the shift consloe, its about 1/2 inch square if you pry that cap off with a screwdriver ..there is a small white button in the hole. That button is an emergency manual release for the shifter. If you push in and hold that button down you can manually get the shifter out of park.
ministock48
Bobby Memory
  • 258 Answers
  • Posted on Oct 19, 2009
SOURCE: The rear parking lights are out on my 2007 Prius.
the fuse box should be under the dash on the drivers side and the label may just say "tail" for the rear tail lights if you don't see it there look under the hood in the fuse box there for the same label
Anonymous
  • Posted on Jan 05, 2011
SOURCE: 2003 Prius Hybrid System Warning Light
My Toyota Prius hybrid warning light has come on three times in eight years. If I turn the car off for 20 minutes, the hybrid light is off but the check engine light is on. After a while, the check engine light goes off. I think this problem is related to moisture somehow entering the hybrid vent on the driver's side. All three times this has happened, the weather was wet. Kevin Cardiff
Reset battery light
Maybe the alternator is draining the battery. Have the alternator tested
2008 Mercury Mountaineer electrical issues
This is a devious problem which could lie anywhere. So many things not functioning would perhaps be a ground problem. Maybe take some extra care in cleaning the battery terminals, check if the ground wire is connected to the chassis. Do you have rodents in your area? Maybe they nibbled some wire somewhere?
2004 Jetta starts to buck while driving as soon as ESP light goes on.
It's your Electronic Stability System. It may be malfunctioning because of the cold temperature or triggered by another malfunctioning system. You need to take it in for a diagnostic investigation.
2helpful
2005 UPLANDER-CHARGING SYSTEM FAILURE CAME ON WARNING ON..BUT MENU SAID ALL WAS FINE WITH BATTERY...
Take it back to the dealer and have it fixed, the charging system does have a fault.
03 Trailblazer Power Loss and Brake warning and ABS lights appear
You need the system scanned with a special tool to see what faults are present in memory
2answers
My 1999 yukon wont start i changed master air flow
Fuel pumps are real common to go out on those vehicles
Check Engine light
It sound like you are having a electrical problem.You need to check your electrical/ignition system,not all electrical problem the diagnostic machine can read.
9helpful
5answers
Top Toyota Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you a Toyota Expert? Answer questions, earn points and help others
