Question about Kenmore 95313 Stainless Steel Electric Kitchen Range
My Kenmore electric range has black composite (or is it plastic) handles that are fading to gray. How can I renew them to black?
  • 242 Answers
You can either paint them or replace them.
Phil
Posted on Apr 14, 2009
A plastic handled oven fork fell in under a pan and melted on our nice shiny black stove top and turned to liquid and melted startin a small fire
OOPS try using a hair dryer to soften the plastic then scrap off the remaining stuff with a razor scrapper .
Mar 05, 2015 | GE Kitchen Ranges
Purchased scratch and dent kenmore electric range model 96419. Did not see when I looked at store that the handle was broken, also the door does not want to stay shut. I close it and the door pushes...
not all scratch and dents are plug and play yours sounds like it was dropped or received a damaging blow you will need to look for door replacement parts and possible alignment of door or body frame
May 30, 2017 | Kenmore 96412 / 96414 / 96419 Electric...
Replacing headlight
Composite Headlights
Most of the vehicles covered by this manual are equipped with composite headlight assemblies. Due to space constraints, no access may be provided to withdraw the bulbs, so the replacement usually requires removal of the composite assembly.
CAUTION The composite headlight assemblies use Halogen bulbs which contain a gas under pressure. Improper handling of the bulb could cause it to shatter into flying glass fragments. To help avoid personal injury, follow the precautions closely.
Exploded view of the composite headlight mounting—1995-97 model shown
Whenever handling a Halogen bulb, ALWAYS follow these precautions:
  • Turn the headlight switch OFF and allow the bulb to cool before changing it. Leave the switch OFF until the change is complete.
  • ALWAYS wear eye protection when changing a halogen bulb.
  • Handle the bulb only by its base. Avoid touching the glass.
  • DO NOT drop or scratch the bulb.
  • Keep dirt and moisture off the bulb.
  • Place the used bulb in the new bulb's carton and dispose of it properly.
  1. Raise the hood and locate the bulb mounting location at the rear of the composite headlamp body.
  2. Disconnect the negative battery cable.
  3. If necessary for access, remove the splash shield or side marker lamp(s).
  4. On some models it may be necessary to remove the side marker lamp.
Unfasten the thumb screws, then ...
  1. If there is enough room to access the plastic base, press in and turn the base 1/4 turn counterclockwise and remove from the metal retaining ring by gently pulling back and away from the headlight. Remove the electrical connector from the bulb by raising the lock tab and pulling the connector down and away from the bulb's plastic base.
  2. If you can't access the bulb from the engine compartment, unfasten the thumb screws, and/or other retainers, then pull the composite headlight assembly forward slightly and disengage the wiring connector. Press in and turn the base 1/4 turn counterclockwise and remove the bulb from the metal retaining ring by gently pulling back and away from the headlight.
... pull the headlight assembly away from the vehicle for access to the bulb and connector
8b6245d.gif \
Remove the retaining ring from the base of the bulb, then ...
... turn the bulb and remove it from the headlight assembly
To install:
  1. Attach the electrical connector on the new bulb's plastic base making sure that the lock tab is in place.
  2. Install the bulb by inserting the smallest tab located on top of the plastic base into the corresponding notch in the metal retaining ring. Turn clockwise 1/4 turn until it stops. The small plastic tab should be at the top of the metal ring.
  3. Install the composite headlight assembly, then secure with the retainers.
  4. Connect the negative battery cable, then check for proper headlight operation.
Jan 10, 2010 | 1997 Buick Skylark
Kenmore Electric Range - Door handle Original bolts installed at the factory came loose and dislodged from the door handle.... no problems but this... i can not screw the handle back myself.. i tried......
We had the same problem. We had some tough epoxy that we squirted into the bolt holes, then screwed the bolts in. It took two of us, one to hold the door together and one to screw in the bolts. We didn't use the oven until the epoxy set, but now we no longer have a problem with the door falling apart every time we open the oven door!
Sep 28, 2009 | Kenmore 96213 Electric Kitchen Range
I have a Republic EZ drop fertilizer spreader. The gray plastic device (2 pieces, one screwed inside the other) up by the push handle that rotates to widen or narrow the slot at the bottom of the...
I have a Republic EZ drop fertilizer spreader. The gray plastic device (2 pieces, one screwed inside the other) up by the push handle that rotates to widen or narrow the slot at the bottom of the fertilizer storage bin when the handle is squeezed is broken. The cable connecting the device to the movable part of the slot is OK. The gray plastic has numbers on it that show through a small square opening in the gray plastic closest to the push handle. Where can I get a replacement part?
May 11, 2009 | Garden
Exterior glass trim on Kenmore Electric Range 880-5981
While waiting for someone else to answer my question, I fiddled around with the door parts. I managed to reassemble them! Here's how:
1. start with the glass panel. Slide the glass panel into the slot at the bottom of the front door frame on the stove.
2. next attach the handle. There are slots on the bottom of the handle that fit into the top of the glass panel. Slide the handle slots into the top of the glass panel.
3. screw the handle onto the oven door using the predrilled holes on the inside face of the oven door.
4. last, attach each of the two side trim strips. Slide the top of each strip into the bottom of the handle on each side of the oven door. Then slightly bend the strip outwards so that they are short enough to fit into the bottom slot of the oven door frame on each side of the glass panel.
Jan 22, 2009 | Kenmore 45062 / 45069 Electric Kitchen...
Door handle fell off
Does your range have an all-plastic handle, a plastic handle with threaded brass inserts or a metal handle?
Dec 22, 2007 | Frigidaire FEF366 Electric Kitchen Range
Kenmore 95313 Stainless Steel Electric Kitchen Range Logo
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
