Question about Toshiba 42H81 42" Rear Projection Television
Other inputs not working on rear projection toshiba
My Toshiba rear projection television works when HD colorstream input is on, but all the other choices -- tv, dvd, vcr1, vcr2 (for wii etc) are all scrambled now (wavey lines no picture). Why does one work and all the others suddently not work.
  • 67 Answers
Check for progressive scan and interlaced setting also verify if you have component hook up that it auto maticall chooses your resolution because if your tv is waiting for 1080i and you send 1080p it will not always work and if it expects 1080i and you send it 480i(s-video or rca connection) it may not automatically flip
Posted on Apr 14, 2009
I have a 65 inch toshiba cinema series it's says
if a large rear projection set that just says HD, it likely is HD ready which means it needs a set top box connected to the Colorstream input marked 1080 on the rear of the set--It will only likely be 1080i and not p---owner manual would confirm this.
May 28, 2012 | Toshiba Televison & Video
Video input on the front and back don't work the only one that works is the HD its a toshiba tv model 50h81 can i fix this
if using a box unplug it and set from power and wait, then plug both up and let reboot to see if it helps--if a real problem in the set the cost to repair and the parts that may not even be available end the life of this set..
Apr 16, 2012 | Toshiba 50H81 50" Rear Projection...
I suddenly lost the color on the screen and no manual adjustments seem to work to restore it.
I'm assuming that you have tried all the color temperatures, the full color setting, the full tint range and the correct input/colorstream to no avail. The only thing left that you can do then is to try to reset it - Menu, Picture, Reset button on the remote.
If even this has failed then the defect is in the tuner - you will have to call a repairman to replace it.
Oct 15, 2010 | Toshiba TW40X81 40" Rear Projection...
57H83 57 in. Rear Projection HDTV Television: I have a Toshiba 57H83 and recently purchased the ...
I would suggest to leave your directtv hd/dvr box connected the way It is.
The HD Colorstream 1input on your TV should work just fine.
This TV does not have an HDMI input but you can buy an adapter and connect to DVI/HDCP IN and that might be able to get 1080i video resolution on your TV.
Jun 30, 2017 | Toshiba 57H83 57" Rear Projection HDTV
I have a Toshiab 57H82 HDTV and when I connect my playstation 3 to the colorstream HD 2 input the colors are primarily green. In colorstream HD 1 the ccolors are fine, but its becoming a hassle having to...
If you have the wires switched GEEN,BLUE,RED on one end the color will be wrong. Check that the color off the wires are matched. Try a new cable. I've seen this a lot.
Nov 28, 2009 | Toshiba 57H82 57" Rear Projection...
I've got a toshiba 53hx71 that the screen rolles when the tv is on in the video inputs or the ant inputs. when there is nothing on the tv it has red squigle marks on the black screen. When you watch a...
Most of the time the Hyper Board failing is the cause of this problem. It will eventually get worse where it also affects the HD ins. Unfortunately the Hyper Boards are no longer available from Toshiba and have not been available for quite some time. My suggestion is to coast with it and replace the Set when the HD ins fail.
Sky Assoc
Nov 24, 2009 | Toshiba 53HX71 53" Rear Projection...
I am using ColorStream for my HD inputs, the top and bottom of every HD input is cropped. how do i adjust in colorstream mode?
There should be a wide/screen size/ format button on the TV remote that allows you to make those adjustments.
Nov 11, 2009 | Toshiba 57H81 57" Rear Projection...
Is the 55H70 a ditigtal? also is colorStream HD High Def?
it is hd ready you just need bluray player/hd cable box as long as its from a hd source or upconverting dvd player you will need component cable red blue green.let me know if you need more info.
Aug 16, 2009 | Toshiba 55H70 55" Rear Projection...
The sound does not work on my 50H81 Toshiba rear projection HDTV, when it's in the HD mode. It was working prior to being moved & was hooked up through a Bose surround system. The sound on the TV works...
Check to see if the comp inputs have a red and black audio input. Those must be connected, second go inside the menu and make sure the inputs match..good luck..
Mar 09, 2009 | Toshiba 50H81 50" Rear Projection...
Toshiba 42H81 42" Rear Projection Television Logo
117 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
