Question about Refrigerators
Avanti FF82 refrigerator leaking water
I have an Avanti #FF82 refrigerator that leaks water.  Leak comes from a ''vent'' on top part of the refrigerator section.
catriver
  • 878 Answers
SOURCE: internal water leak Amana AT5518SW
King, you probably have a defrost drain port that is frozen over. When the unit goes into defrost it's running through the air damper instead of going out the drain line. Therefore you get water into the refrigerator section. You can verify this by removing the evaporator cover in the freezer and checking the drain hole. You can clear it by running hot water into it. You will have to remove all the built up ice from water that did not drain in that area...Catriver..post back.
Posted on Nov 13, 2006
SOURCE: frigidaire refrigerator leaking water inside refrigerator
There is a plastic panel inside the frigidaire looking at the underside of the freezer inside the refrigerator compartment which holds the thermostate dial and the light fixture. remove the four 1/4 in hex head screws holding the assembly. pull the panel toward the front. you will expose the drain hose connection you can let it dangle from the plug wires or remove the panel completely, I worked with mine in place. look at the back funnel shape drain. just in front of that see a rectangular styroform collar which should be snug fit to match the underside. clean and dry all. there is a divider between the two funnel compartments, mine was separated between the plastic and the styroform. I used kitchen and bath tub caulking to seal the gap. and a little around the rectangle shape that fits to the underside. plug the wire back in if disconnected. reassemble the panel. that may fix it. good luck.
Posted on Jun 17, 2008
aborcass
  • 2651 Answers
SOURCE: Amana 18 Top freezer Refrigerator-leaking water in refrigerator
the middle insulation hasbecome water logged, forma faulty defrost tube, so, every time trhe unit defrost, 2 maybe 3 times a day it will spill water inti the vents, andin to the refrig, the only correct way to fix is to have the enitre center drain block replaced, part not that expensive but labor to install may be, ohter then nussincence, not really affecting machines workings
Posted on Jan 11, 2009
aasc
  • 1606 Answers
SOURCE: water leaks from top mounted freezer area into the refrigerator
Remove the food from the freezer and the icemaker if equiped . Remove the air tower at the rear of the freezer section and remove the rear panel inside the freezer . Using a hair dryer to the drip pan , below the coils ( probably ice ) , starting at the center , defrost until you see the drain hole . Keep defrosting the hole ( hot water helps ) until water starts to flow down . Using a short piece of hose , insert it into the drain hole and blow . This should blow out any debris inside the drain hole . I would use a short piece of solid ALUMINUM wire ( 14-16 guage about 8 " long ) striped of all insulation , and insert it into the hole as far as possible , without any force . Wrap the other end about 1--1 1/2 turns around the black tube ( defrost heater ) above the hole . When the heater comes on , heat will transfer to the aluminum wire and keep the drain from freezing up again . Reasemble back panel , air tower , and , icemaker . Reinstall the food and its FIXYA'd .
Posted on Sep 02, 2009
Testimonial: "Thanks for the suggestion. "
  • 16 Answers
SOURCE: Kenmore refrigerator water leaking down into
pluged drain in freezer
Posted on Sep 08, 2009
Motor runs not chilling. Contacted Avanti, they said I need to use a local service person but none are available.
You said the compressor is running? Right? Check for the temperature of the suction line to compressor (line going to compressor from the evaporator coil) - it should be cold. The other line going to evaporator should be nice and hot.
If suction line is not cold, then the unit may have a gas leak and needs to be regassed. However, you need to first locate the leak, repair it, evacuate the system to make sure the fix is good and then refill with appropriate refrigerant. U will need to get a shrader valve to tap into the suction line, a leak detector, leak repair tools, vacuum pump, and refrigerant with manifold.
Oct 23, 2015 | Avanti WC681BG Wine Cooler
Avanti w1092f front load washer leaking water from the botton
Look under and around the door and drum seals for debris. Had a coin in the seal once, took it out leak stopped.
Nov 27, 2011 | Avanti W1092F Front Load Washer
I have an Avanti refrigerator ff82. I hear the motor running but the the neither the freezer nor the fridge is getting cold.
If the compressor is running , it is likely that the freon or refrigerant may have leaked out. If you do not refrigeration, call a repairman.
Dec 17, 2010 | Refrigerators
Kitchen Aid KTRC22EK leak inside refridgerator
It sounds like the drain for the defrost water is pluged. You can remove the back panel inside the freezer(ice maker will have to coe out first) and access the drain in the rear center of the freezer. Check the drain. It can be defrsted with a hair dryer(shut off the referigerator first) good luck, snugglepants
Nov 03, 2009 | KitchenAid KTRS22EL Top Freezer...
Oil appears to be leaking from my Avanti Wine Chiller
Is it cooling ok?Where did you find the oil? If is not cooling and you see an oil spot inside or outside where the compresor is that means there's a refrigerant leak.
May 01, 2009 | Avanti WC3200BG Wine Cooler
Have an avanti refrigerator model #FF82. and the door to the chiller room, which is under the freezer, needs to be replaced. How do I go about replacing this door?
Hi, I have an Avanti refrigerator model FF82 and there are no shelves inside. Are there spare parts available. There is only a chiller room and 1 bin on the bottom. Thanks
Apr 26, 2008 | Refrigerators
Coolent leak Avanti model 489
this requires skill in refrigeration depending on size of leak how old is the unit and how large the leak avanti is a great company if less than five years o0ld they will replace unit get in touch with if older than them
Dec 31, 2007 | Refrigerators
Avanti water cooler
check the switch at back if it is working, check the motor compresor touch the top of the motor comp, if working, the possible problem is the freon, touch the condenser at the back of the unit if hot the freon is working, if no hot, load a freon, ok
Sep 28, 2007 | Avanti (WDE79BSS)
My washing machine keeps leaking from the bottom
There are many possible cause of a leak. If it is set to portable make sure that the faucet is off after the cycle. You also need to make sure that you are not over loading the washing machine. Please refer to owners manual how much is the capacity your washing machine can take. Drain lines is also a possibility for this leak as well as the intake inlet. If it's leaking in the center most likely the bearing have broke off and you might need a new center seal. This job requires a professional to be replaced. My advice for Avanti users is to return it and buy something else that is trusted and branded for quality and performance.
Apr 26, 2007 | Avanti W851 Top Load Washer
Refrigerators Logo
587 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
