Critical driver and sofware problems
Hard to start up pc and heavy problems with applications
  • 13,433 Answers
Can you tell me more about the problems?
I would suggest to do a clean up with ccleaner http://www.ccleaner.com/
Also uninstall programs that you no longer use from start -> control panel -> uninstall programs or Add or remove programs.
Please tell me more about the problems.
Posted on Apr 14, 2009
The Toshiba user's guide and support app on windows 8 start screen is not working. it says critical error
Windows 8 sucks. Have had so many issues with it myself. Sounds like the load may be corrupted, the easy is call Toshiba tech support, the hard is reformat the hardrive and reload windows but I would suggest Windows 7 over 8 any day.
Sep 23, 2014 | Toshiba Satellite Computers & Internet
SOFWARE SAMSUNG DRIVER FOR HX-MU032DC
Your computer should recognize the drive when it's plugged into the USB port. There is no driver . If the PC can't find and assign a drive letter to it then look at a bad wire between the hard drive and the USB port.
Jul 16, 2014 | Samsung G2 Portable External HX-MU032DC/...
Busco el sofware de mi camara web manhattan Q.C PASSED
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Aug 14, 2011 | Manhattan Mini WEBCam
Hi, This is the message my pc displays when I try to install an operating system: Windows failed to start. A recent hardcore or sofware change might be the cause. Tofix the problem: 1 insert your...
Hi! Welcome to www.fixya.com.
First of all, you have to change the boot sequence to CD/DVD drive on BIOS. so go restar pc and hit f1 or f2 then go to boot options to change it. hit f10 to save and exit. restart again and put the recovery disc. when it says press any key just keep on hitting enter until it says window is loading files: follow this webiste : http://www.windowsreinstall.com/
Hope this resolution fix the problem on your computer. Thanks for contacting Fixya. God bless. Bye for now.
Jul 18, 2011 | HP Compaq d530 SFF PC Desktop
Why are my Display settings lost on start-up or reboot?
It's possible you are using the wrong drivers. I would re-install the software application that came with the card. If you right click on my computer, then left click on manage. Look for device manager and click on it. Look to see if the video card has a yellow exclamation mark on it. If it does then it's definitely the drivers. Re-install the sofware application for the video card. If you don't have the drivers go here ----------> http://www.nodevice.com/driver/Radeon_7000/get34927.html
Good Luck!
Dec 10, 2010 | ATI RADEON 7000 PCI Graphic Card
Dell XP restart problem
This error comes due to 1. RAM problem or 2.Hard disk problem or 3.Software/device driver problem or some times 4.Virus problem.
First you run the system in safe mode (pressing F8 at booting) - restore the system (start-programs - accessories - system tools - system restore). PC will be restarted and if it runs well then fine. If not again run in safe mode- uninstall few softwares or utilities, clear the temporary files, few drivers - restart the PC it may run well. If it does not run in safe mode the problem may be due to virus or critical RAM problem (main suspects, as the error may be for different reason). Now you format the hard disk and install your applications and drivers one by one and restart and check whether the problem repeats. Failure with the step you should change the RAM. With all failures - motherboard should be repaired and you have to give to the service center.
Jun 13, 2010 | Dell Inspiron 6400 Notebook
Computer freezes after about 5 minutes of turning
Looks like the Laptop is running some backend program which could be either a service, an application running at the stealth mode, or a driver program that seems to seize the Memmory resource allocated to the Kernal. Did you try check the system log by going to Start - Run - eventvwr.exe wherein you will find two heives namely Application and system. On the second start try to go through this event viewer which is opened as i said before and find out if you can locate any memmory related critical error or any application related critical error which lead it to a hung state and a restart registered later.
If you cant find that please boot in a safe mode and see if this is happening. It should not happen ideally speaking. Still if this is happening, try to restore the OS or run the repair disk of Acer Aspire. This should resolve the issue. Still if you cant resolve this issue its surely due to a hardware problem. I would advice you to go ahead tappering the chances of problems starting from an OS monitoring to Hardware Troubleshooting as per the steps i have explained here. Good Luck.
Feb 14, 2010 | Acer Aspire 5610-4648 Notebook
How to get sofware to install creative webcam in my pc.
I have lost my CD to install software .Can you help me , how do I install it it's a Creative Labs INC VF0080
Jan 23, 2009 | Creative Labs Creative Webcam
Critical component is either missing or cannot start
Have you tried a soft reset or hard reset yet P ? How about a ROM update ? Seem like one of your applications on the Ipaq is having a conflict so try to remove them 1 by 1 and pinpoint the exact culprit Did you have the programs installed on the main Ipaq memory or a SD card if you have one ?
Sep 11, 2005 | HP iPAQ RX3100 Pocket PC
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
