Question about Compaq Armada E500 Notebook
WANT STAY ON
Ok my laptop is a compaq e500 armada it was working very good until sunday 4-12-09 i plug it in this morning and all i got was a little noise where cdrom is and then it when off what can i do? AGATHA MCQUAY
  • rwgately Apr 16, 2009
    After I power on it goes through the boot up and even into my mail box then it will just shut down totally. This happens even with the battery in or out of the unit. Any ideas ?
  • Luis Perez
    Luis Perez May 11, 2010
    does it ges off completeley or just the screen goes black ?
How do i connect crw-785 to compaq armada e500
This e500 has USB1.0 and transfer rate will be slow. If you use Win 98 then install the USB driver (get on web) first. Install software then plug in the USB lead from the crw-785 and don't forget to plug in the DC adaptor for the drive, (e500 USB port does not have enough power to run external drives other than some older thumbdrives).
Feb 24, 2015 | Compaq Armada E500 Notebook
My armada e500 will turn on, do the little compaq sign then just stay on a blank screen and won't do anything further. HELP!!!!
Try draining the flea power first:
1. Remove the battery and ac adapter
2. Press and hold the power button for at least 10sec.
3. Put back the battery and ac adapter
4. Turn on the computer
Check if it will load to windows, if not, there could be a problem with windows. Try startup repair on advanced boot options. Hope this helps.
May 13, 2010 | Compaq Armada E500 Notebook
Armada e500, enter bios, how to?
While the laptop is booting press continuously the f2, f8 and Delete key, until the bios screen or a prompt screen shows up.
Oct 13, 2009 | Compaq Armada E500 Notebook
How to fit memory to laptop compaq armada e500
most hp/compaq laptops will have memory slots located under the keyboard, and sometimes an additional memory slot accessed through a panel on the bottom of the notebook.
In your case, you have 2 memory slots located under the keyboard. Officially, this unit only supports up to 256 mb memory modules for a maximum of 512 MB of memory so if you already have that, be aware that larger capacity memory modules may not work.
Oct 04, 2009 | Compaq Armada E500 Notebook
My usb port of my Compaq Armada E500 Laptop no
the usb port of my hp Compaq Laptop nc6000 no longer works properly. whenever i insert a flash it says usb device not recognized.
Jun 03, 2009 | Compaq Armada E500 Notebook
Compaq armada 500 (touch pad not working)
look at the ribbon/connector again, make sure it's not broken.
Sounds like a broken ribbon or bad connector.
May 23, 2008 | Compaq Armada E500 Notebook
Compaq Armada E500 - Increase Memory
Try one only 256 it should work now. You cannot use a 256 with a 64 it just will not work it is physically impossible. I know with some of those older models and Im picking yours is because you mention you were using 2x64. What you should have done was to buy two x 128 I am possitive your board can only handle 256mb of ram. Try the one only and if it works use that I dont think two of them will work not on that board?? Let me know ok. You might wanna clean your machine out with a software like this and its 30 days trial but has all features till it expires: http://www.tuneup.com. else if you dont want to take my advice on your laptop you can always go here: http://www.compaq.com
Sep 13, 2007 | Compaq Armada E500 Notebook
Compaq Armada E500 Notebook Logo
106 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
