Question about Broan-NuTone N-IS-338BL Accessory Intercom Kitchen Hood
Humm in system
System has a large humm in the volumn control Main speaker as well as the indivual room speakers. Unit is 22 years old and installed when house was built. Model #im3003 Nutone intercom. Thanks, Jay
Called Nutone distributor and found that the unit is guaranteed for life. What a surprise!
Thanks for your web site, I will use you in the future.
Jay
Posted on Apr 15, 2009
I've got a rcs STAV 3880 surround receiver wit ful volumn al the time
Sounds like a shorted audio IC or bad connection in the limiter circuit.
Mar 01, 2014 | RCA Optimus/Stav-3880 Rcvr Parts - Board -...
My Yamaha V2065 receiver shuts off when i increase the volumn
Since it comes working again, immediate solution would be
• to tone down a bit your volume, check the speaker settings
like "small" or " large"
• and see if it subsides,
if not check the main amps integrity and the speaker systems.
Speaker Systems
• These would be connecting each speaker one at a time to find
the cause.
Sep 26, 2012 | Yamaha RX-V2065
Have old labtec cs 1000 speaker system with power control center. separate volume controls do not work. Volumn adjustment with computer sound control only. cannot find instructions for hookup. suggestions?...
There are two sets of inputs in the back. One set will allow control from the front of the unit, and the other from the computer. In That case, the front knobs are disengaged.
Jul 20, 2011 | Computers & Internet
I have a Sony DAV S500 AV system and with certain DVD and with the volumn just over 20 (not really that loud), the system shuts down and PROTECT shows in the message window. I read somewhere on the web...
If the subwoofer and other speakers were included with the system, THAT is what they're designed for. Mixing and matching with other products is usually discouraged if not forbidden.
http://audio.manualsonline.com/search.html?q=Sony+DAV-S500
If the problem returns with connection of the sub it may be defective or on its way out. Internal damage to the voice coil from being overdriven could have melted or worn through the insulation and it would cause intermittent undesired electrical contact or load variation under certain conditions, like high volumes.
If your speaker level settings are unusually boosted for the sub you may be overdriving it.
Feb 07, 2011 | Sony DAV-S500 System
Reconnected after moving pc to another room no volumn
  • just check the volume settings on the system tray, by clicking the speaker icon on the lower right side of the screen
  • set the settings to high volume
  • if the problem persist try to delte and reinstall the sound blaster if have one.
May 28, 2009 | Dell Computers & Internet
Video1, video 2 humm
Replace C602 on dvd board. noise on 10v line causing problem.
Jan 19, 2009 | Sony DAV-FC7 System
Loud humm. I have to keep the volume down when watching the TV.
A humm may be caused by a cable TV grounding problem called a "ground loop." Basically, the grounding for the Cable TV line and the power outlet for the TV are at unequal levels. I had this same humm with both the internal TV speakers and with external speakers (headphones, etc.). The 2 solutions are (1) install a Ground Loop Isolator at the TV, or (2) call the cable company to troubleshoot the problem. I figured the time I saved dealing with the cable company was worth the $50 for the part. I installed the Jensen VRD-1FF which has worked perfectly! Ordered from eBay and saved about $12 over the Jensen Electronics web site price. Hope this helps.
Dec 05, 2008 | Bose Lifestyle 28 System
Yamaha v-663 reciever
Most amps will only power two sets of speakers direcrly hooked to amp (A&B). If you want audio throughout the house, I would recommend a PA system set up with individual room volume controls
May 02, 2008 | Audio Players & Recorders
TV to Home theatre
The center speaker shouldn't be on the surround outputs it should be on the Center output. The surround outputs are for the rear speakers.
Sep 09, 2007 | Audio Players & Recorders
Broan-NuTone N-IS-338BL Accessory Intercom Kitchen Hood Logo
362 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Dan Phillips
Level 1 Expert
Phil Lovisek
Phil Lovisek
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
