Question about Toshiba Satellite A205-S4777 Notebook
The power port seems to be broke. the connector will not seat properly. Is it possible to switch out the case?
  • 326 Answers
Most likely you would have to replace the port itself. On most laptops this is soldered to the board, however your model may be connected via cable, which is far more friendly to replace.
Removing the screws from the bottom of the laptop (Checking under any bumpers) and carefully removing and click-tabs holding the top and bottom of the case will allow for better inspection.
Let us know
Good luck
Posted on Apr 14, 2009
Why is my iphone not charging?
This means it's not getting a charge. I've just experienced this problem myself. I followed instructions online regarding cleaning lint from the charging port of the phone. Still no charge. I bought a charging cable that came with a car charger made by Belkin, this worked in the car, also allowed me to charge the phone from the pc, but wouldn't charge from the original plug. So I purchased an original Apple branded lightning cable today and it works. At last. So it turns out that my cable was faulty and another branded cable would not work with the Apple plug. So you need to try a known working Apple cable and plug and failing that clean out the port on the phone as lint is a common problem.
Jan 02, 2015 | Apple iPhone 5S
Why isn't my 2008 pontiac g6 power seat not raising and lowering
start by checking fuse that supplies power to seats
May 27, 2014 | 2000 Toyota Camry
Huskee model 287707 blades wont spin belt not broke or spinning?
check for power and ground at the connector that feeds the clutch this will tell you if its a switch or the clutch itself
May 23, 2012 | Garden
I have a Sears GT 6000 Model # 917.255980 lawn tractor with 18 HP Kohler engine. Problem is it will not start. It set in my garage over the winter ran fine last cutting season. Inatalled new battery it is...
I'm going to throw this quick one at you but there are several problems that can stop the spark reaching the plug. Check the connection at the seat switch. The "connector" has a built in switch in addition to the switch that it plugs into. This is designed to prevent people from unplugging the connector and installing a jumper wire to bypass the seat switch. If this is not making proper connection it will kill the spark. You may also check the pluger switch for the seat as well. Hope this gets you in the right direction.
Feb 18, 2011 | Craftsman Garden
Red power light and reset button on but nothing else boots
Verify that the cpu is properly seated and latch is closed. Check that the power supply connector is properly installed and the power supply works. Double check your connections on the motherboard for the on/off and rest switches are correct. If you do not have the switch connector properly hooked up then you will get no response from the computer when it is pressed. Also check that the screws holding the motherboard to the case are screwed in tightly...the board uses these screws for electrical ground.
Dec 14, 2009 | ASUS Computers & Internet
M2N MX SE Plus Motherboard
Read the labels for the connectors on the motherboard.
Polarity does not matter for the POWER and RESET buttons.
If the lamps for AC-POWER or HARD-DRIVE-ACTIVITY do not light-up when you expect them, then reverse the connector.
Try the PC SPEAKER connection one way, and then shutdown
the computer, reserve the connection, and start the computer.
If the "beep" at start-up is better, leave it as-is.
If the "beep" does not happen, or is quieter/distorted, reverse the connector.
May 21, 2009 | Ultra Products Ultra M923 Full Tower ATX...
Computer cases
an at case doesnt have the extra ports than an atx case has, take for instance an atx motherboard has printer port, comp port, usb and ps2 ports near the top left side, an at motherboard only has an at keyboard connector, all the other things are put in an empty isa/pci slot
Here is a picture of an AT motherboard note top right the keyboard port and the white strip behind that is a 1 row set of pins for the power as the switch is in the power supply and not on the motherboard
http://www.pcbuyerbeware.co.uk/images5and8.htm
And This is an ATX motherboard you can see the 20pin atx power connector, because the motherboard has an electronic switch to control the power.
http://www.nuggetlab.com/comptia_files/equipment/mother_ATX%20Motherboard.jpg
Dec 12, 2008 | Diablotek BLACK ATX CASE W/ 400W PSU...
Need to chat with an agent!
1. make sure not only those are properly seated on the led portion of the the case and on the motherboard..
2. also check your power supply motherboard connector is properly seated on the mother board
3. and make sure your power supply switch is on the right postion (110v/115v North america or 220v/230v Europe)
4. make sure the wall outlet plug is working properly. and properly connected to the back of the powersupply
Dec 04, 2008 | E-Machines eMachines Desktop PC
No vga by pushing port buttons
In order to fully answer your question, a number of needful things must be inspected, reinstalled, confirmed, & tested:
  1. Reset. Try the reset button. You could use a paper clip to reach the reset button through the pin hole in the lower front left of the Zonet KVM unit.
  2. Inspect connectors. Each data/input/power connector/port requires all of its pins to be present & straight for full functionality.
    1. Inspect the entire length of each cable & cord to ensure that each has no damaged area.
    2. Seat each connector in the appropriate port of a computer that will be accessed via the KVM unit.
  3. Electricity. Inspect all affected devices & confirm that each has sufficient, uninterrupted electricity.
    1. It is possible for a Zonet KVM unit to display channel lights without direct power to the unit, but you should confirm that the unit is getting sufficient, uninterrupted electricity-directly through its own power cord. Unplug the KVM power cord & every connector & reseat each one (this performs a power reset on the KVM unit)-making sure that each connector is in the correct location (not just where it originally was). Thus, make sure that the keyboard, video display (monitor), & mouse are on the output side.
    2. Press the power button on your monitor. If it does not turn off the monitor's power status light (Off/On/Standby), then remove the power cord from the monitor & reseat it-to reset the monitor's hardware. If it does not turn on the monitor's power status light, then the monitor is either not getting enough electricity or it has a malfunction which requires troubleshooting & fixing (possibly through a fixya.com thread for that monitor model).
    3. Unlike USB devices, PS/2 devices usually require device connection prior to turning on that device. With that said, connect the keyboard & mouse KVM channel cable connectors to the computers & then turn on those computers that you intend to display through the KVM-connected monitor & then turn on these computers.
    4. Any computer that does not turn on has an issue that requires resolving (just like a monitor that would not turn on).
    5. Sometimes a keyboard/mouse interface issue can be resolved by replacing that interface device.
  4. The KVM Unit. When all else properly connects & performs, what does not properly connect & perform has the issue &, hopefully, that can be repaired without having to replace it.
Nov 09, 2008 | Zonet Computers & Internet
Toshiba Satellite A205-S4777 Notebook Logo
134 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
