Question about Car Audio & Video
AVIC-N1 locked in mute - Car Audio & Video
  • 2 more comments
  • djvollmer Apr 14, 2009
    This may or may not work, and at the moment I don't even have the car, it's in the shop. When I first got it (a 2001 BMW 325Ci from a dealer) the radio worked, but neither the dealer nor I knew it was that sophisticated a radio, just an am/fm/cd player. When I got it home, I looked at the manuals (I have all three) but it still didn't register that this was indeed a nav/dvd/mp3/xm radio as well. I do not have any map data discs or install discs. I can get to some menu functions, but the audio button is greyed out.
    Once I figured out that it had a pop-up nav screen, was when I started having problems, and it has been locked in mute ever since. I'm not quite sure what the parking brake has to do with the mute function. Thanks in advance for your help.
  • djvollmer Apr 16, 2009
    Still no luck. The parking brake is in the center console and there is a blue wire going in that general direction, coming from the hide-away-unit under the drivers seat. That blue wire is then spliced into a yellow wire, then a fuse holder and 2 amp fuse which is marked "battery". I cannot see anything under the dash that would would be green.
  • djvollmer Apr 17, 2009
    Back to the beginning. Pioneer AVIC-N1 locked on mute. I just bought it at a BMW dealer, used, and the am-fm portion worked. I didn't realize it was a nav-dvd-etc. player. Now the system displays a menu, but can't get rid of the mute (lower left corner)function. The menu button brings up three buttons, 1)audio (greyed out), 2)radio and 3)setup. I can find no option to turn the mute function off/sound on. I don't see that it is a hard wire problem. I have the manuals, but not the data/DVD's.
  • djvollmer Apr 18, 2009
    I finally found the problem, as I was not able to get to the "initial setup screen". Once I found that, I could finally make my way around the system, half way anyway, and I now have sound!
    It's still difficult getting to the menu to change time, brightness (basic things), but I'm getting there.
    Thanks for all the help
    Sergeant:
  • 199 Answers
All you gotta do to bypass the N2 is look on the bottom side of the unit you will see a little brown piece of tape or covering once you remove that you will see two soder points all you gotta do is put a wire between these two points BE VERY CAREFUL!!!! and thank your Pioneer rep!!! this was very useful info we;ve tried it on two units so far with no problem. if this works for you all i ask is that you PM me and let me know thanks
Another method............
My brother (who i would say is the F*#@ing man) and i just completed the moving lockout bypass on my AVIC N1. We began by finding the green wire that runs from the head unit to the parking brake. He then cut it before the splice and placed it between the parking brake and the mechanism itself ( the mechanism is a plastic and metal piece that creates a circuit when the parking brake is activated). You will notice a hole in the parking brake lever that lets you access the screw to loosen the mechanism. Take the wire you cut that runs from the AVIC N1, strip the end, and place it between the mechanism and the parking brake itself. Use the screw to tighten the wire between the two and this will complete the circuit and make the head unit think that the parking brake is always on. Therefore you will have control of all the locked out functions while moving such as address search and dvd playback. This took a total of five minutes and is easier than you think. I was running version 1.2 pioneer navi disc and had no problems with all functions. We did a test run and got up to about 55mph and had no problems. I now love my AVIC N1 a million times more. No i will not be using this to distract myself form the task of driving, just to make the unit alot more usable in the real world. I will post pics tomorrow as it is now too dark to do so. Good luck and enjoy!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! You can also help from this site
http://hadriver.org/forums/archive/index.php/f-44-p-15.html
Posted on Apr 17, 2009
  • 1 more comment
  • Aftab Nawaz Apr 17, 2009
    i think your problem in hardware but software work....so you need a check the wiring and other things...may be speaker problem....rate it
    dear if your FM work properly then i surly your problem in hardware it is not linked with DVD
  • Aftab Nawaz Apr 29, 2009
    hi.dear thanks to this.....VERY GOOD YOU ARE LUCKY AND I AM ALSO LUCKY.So if your problem is solve please rate it best
    Scholar:
  • 45 Answers
Dear djvollmer,
Avic-N1's when installed properly will either mute or disable certain functions when the parking brake is not engaged. The idea is that you must be stopped to access these features, not driving and messing with NAV functions at the same time. The system is easily circumvented by most installers and if left un-attended to by the installer it may render many functions useless. Once you make sure that the parking brake safety switch is installed correctly it should fix the mute issue. If not the sytem's remote can toggle the mute on/off. After going through those steps it should be fully functional.
-Dynami
Posted on Apr 15, 2009
  • ???? ???? Apr 17, 2009
    Do you have the remote for the unit? If so try unlocking mute with it. Also you can usually disconnect the brain from the nav unit and the deck should work as normal but with out nav functions. If that works it will indicate that the nav unit is not receiving the signal from the parking brake, or is malfunctioning.
    -Dynami
    Brigadier General:
  • 3,917 Answers
Please try to find the green wire that runs from the head unit to the parking brake. Then cut it before the splice and placed it between the parking brake and the mechanism itself ( the mechanism is a plastic and metal piece that creates a circuit when the parking brake is activated). You will notice a hole in the parking brake lever that lets you access the screw to loosen the mechanism. Take the wire you cut that runs from the AVIC N1, strip the end, and place it between the mechanism and the parking brake itself. Use the screw to tighten the wire between the two and this will complete the circuit and make the head unit think that the parking brake is always on. Therefore you will have control of all the locked out functions while moving such as address search and dvd playback. This took a total of five minutes and is easier than you think. We did a test run and got up to about 55mph and had no problems
OR
thanks
Posted on Apr 14, 2009
  • 19,396 Answers
Check the AVIC-N1 connections to audio system.
It is possible that audio wires are not connected properly , refer to the user manual.
Posted on Apr 16, 2009
Mute function on Pioneer AVIC-N1
You have to isolate yellow-black cabel. This cabel was in contact with earth and it was the reason, why you have Mute on the display.
Apr 14, 2009 | Pioneer AVIC-N1 Car DVD Player
No audio an Avic-n1 and Mute button display
We can fix this and all other AVIC N1 N2 N3 problems.
Please visit www.turbotunes.com for affordable AVIC repairs.
-Steve
Feb 13, 2009 | Pioneer AVIC-N1 In-Dash DVD Multimedia AV...
Display not working
just got a tech bulletin from pioneer in my bulk mail(almost trashed it). they said its a recall on all avicn1 and 2's. the ribbon wire going from unit to screen fails after many cycles. they are issuing free repair.
Notice: Upgraded Flex-Cable for Flip Screen in Navigation Models AVIC-N1 and AVIC-N2 To: January 3, 2007 Dear Valued Customer: Re: Upgraded Flex-Cable for Flip Screen in Navigation Models AVIC-N1 and AVIC-N2 We would like to inform you of a potential service issue with Pioneer's AVIC-N1 and AVIC-N2, inform you of our plans to resolve this service issue, and ask for your help in notifying consumers. If a consumer is not experiencing any issues currently, there is no need for the consumer to take immediate action because the one-time fix to resolve the service issue will be available if an AVIC-N1 and AVIC-N2 later experiences the service issue. _Importantly, the service issue does not pose any health or safety risk._ Pioneer is aware of a potential issue with the flex-cable powering the flip screen to the AVIC-N1 and the AVIC-N2. After a number of power cycles, the cable has been observed to fail and cause the unit to malfunction (symptoms may include, but are not limited to, the flip-screen becoming blank) -- flex-cable failure can only be confirmed by Pioneer; standard service charges may apply for service issues not related to the flex-cable upgrade. This issue may affect almost all AVIC-N1 units and AVIC-N2 units. Please contact Pioneer at the number listed below if you have a question about whether your AVIC-N1 or AVIC-N2 unit is affected by this issue, or if a specific malfunction affecting your AVCI-N1 or AVIC-N2 is related to this issue. To address this issue, Pioneer is providing a one-time cable upgrade to consumers for their AVIC-N1 and AVIC-N2 at no charge to consumers for parts and labor. Pioneer will offer the free upgrade either upon request or automatically if an affected unit is serviced for another reason. Pioneer will exclusively perform the free cable upgrade for all units (i.e., no other service facility should perform the cable upgrade). If you own an AVIC-N1 or AVIC-N2 and you are experiencing the service issue, please contact Pioneer Customer Service toll free at 800-421-1603 to arrange for the cable upgrade. Pioneer service representatives are available Monday through Friday, 9:00 a.m. to 7:30 p.m. (Eastern Time). Customers who have paid for the cable upgrade are eligible for reimbursement of certain service costs if sufficient proof of service can be provided -- please contact Pioneer at the above-listed phone number for more information regarding reimbursement rules. Customers can also review FAQs regarding this service issue. Click here to view the FAQs. We sincerely apologize for any inconvenience this service issue may cause you, and we thank you for your cooperation and continued support of Pioneer. Sincerely, Pioneer Electronics (USA) Inc. *Pioneer Electronics (USA) Inc., 2265 East 220th Street, Long Beach, CA 90810* ------------------------------------------------------------------------
___________________________________________
owner of
Motion Marine & Car Audio
the florida keys
Dec 08, 2008 | Pioneer AVIC-N1 In-Dash DVD Multimedia AV...
Avic-n1
same problem n1/n3 avic series
Aug 11, 2008 | Pioneer AVIC-N1 Car DVD Player
Avic-n1 bypass
Heres a good site that has alot of bypass guides for Pioneer Avic Units
http://underground-secret.com/avic_n1_bypass.html
Pioneer Avic D1, D2, D3, N1, N2, N3, N4, Z1, Z2, Z3, F700BT, F900BT & F90BT.
Aug 03, 2008 | Pioneer AVIC-N1 Car DVD Player
Avic-n1 wiring diagram
www.pioneerelectronics.com should have listings and manuals for their products in downloadable pdf form. Also, try visiting www.avic411.com for all your Pioneer Avic series navigation needs.
Avic n1 dvd is not working properly
Is it always blank? Or only when trying to watch a DVD? What version discs are running?
Apr 08, 2008 | Pioneer AVIC-N1 Car DVD Player
Connecting sunvisor monitor to avic-n1
i think you just need to set up your N1.
check with your user manual :)
Mark
ww.blueice-electronics.co.uk
Nov 23, 2007 | Pioneer AVIC-N1 Car DVD Player
Pioneer avic n1 satellite list
Static from radio only sometimes,Act's like a loose connection. You can thump on dash it stops. But it will come back. I have heard pioneer has had a recall on this anybody know about it. Oh it does not have a loose connection we have double and triple checked.
Nov 08, 2007 | Pioneer AVIC-N1 Car DVD Player
Car Audio & Video Logo
111 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
