SOURCE: mitsubishi ws-55819
Code 22 indicates that your set is in shut down due to what is called Short Protect. The most likely cause is the Converge Ic's drawing too much current and opening one or 2 fuses. Normal repair cost varies by area and servicer. Expect 250 to 350 plus the service call. I normally do this on site.
SOURCE: Stays on for 2 seconds and switches off
A 2-2 code on that unit means over current shutdown. 95% of the time that code indicates defective convergence output IC's.
The convergence amplifiers need to be replaced.
This set may have one big amplfier chip rather than two.
The chip(s) will be on a big aluminum heatsink.
There may be bad resistors related to these chips, as well as one or two fuses that are open.
I've replace many convergence amplifiers.
If you have good soldering skills and ac test fuses and resistors, you can do the repair yourself. Caution that even with the set unplugged, there could still be dangerous voltages present on some components.
Search this site for specific convergence repair related to your set.
