Question about RCA P46924 46" Rear Projection Television
Phillips 42" Rear Projection
I have 2 problems the unit is only about 5 years old. The first is the sound initially would cut off and on, however it works full time with the surround sound receiver on. The second problem is the unit would turn off after about an hour of watching. It would come back on and shut off again. My delima is, is the tv worth fixing with these two problems. The quotes I get over the telephone from tv shops ranges from $125 to $700. I can replace the tv for not much more than that.
    Novelist:
    Scholar:
  • 149 Answers
I would strongly suggest to use the funds towards a new TV. It's most of the time a domino effect between service of your set and the next issue. Generally, once there is a problem sometimes it can set off a ray of other problems. I'd suggest to go with a newer technology. Invest in something current like DLP or even LCD flat panels are great due to no burn in, and much more affordable then they used to be. Another thing to be aware of is that by febuary 2009 everything is going to be all digital. What does that mean to you? Or your current rear projection set? It means that you would have to invest in an expensive converter box that would switch the signal from analog to digital in order to get any signal. That is why you see an enormous drop in digital display prices within the past years or so, plus lots of online companies going out of business because they cant afford to compete with electronics anymore. I hope this helps. After seeing plenty of TV issues within my 7yrs of experience in selling digital displays online...I think this is a much better route to go! Take care and good luck!
Posted on Sep 13, 2007
SOURCE:
T.v.says lamp not working
If the display indicates then it is possible that the lamp has failed or that the Power to the lamp is cut off. You will need to check the status of the lamp and also the lamp connectors, the supply from the power.
Check to see if the cooling fan is clogged and so has reset the processor with a error. If so clean the filter to reset.
Jun 30, 2011 | Toshiba TheaterWide 52HM84 52" Rear...
It shut off in 2 seconds of turning the tv on
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors. This may be your problem
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Dec 09, 2010 | Mitsubishi WS-65807 65" Rear Projection...
Philips 42PFL3603 tv sound but no picture.
Hold a flash light to the screen after it goes off and see if you can see a faint picture. Sounds like your backlight might be cutting off. Repair can be expensive but some of the newer units don't require the entire LCD to be replaced.
Sep 27, 2009 | Philips 42PFL3603D/27 42 in. LCD TV
Blurry screen on 50in Hitachi LCD
Sounds like you need a bulb replacement, if you watch tv a lot ave life is about 5 years
Sep 14, 2009 | Hitachi 42V710 42" Rear Projection HDTV
My Sony 54" Grand Wega rear projection TV is 4 years old in Sep. It has started losing picture and sound for a few seconds then comes back on. It is getting more and more frequent. . . like six times in 5...
A spent bulb will cause the whole set to go off. If you have not changed the bulb in all of these years, first you are lucky, and second that is probably the cause of your problem.
Aug 23, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Samsung HCN4226W 42 in. Rear Projection
My 5 year old Samsung HCN4226W is not coming on (no picture and no sound). When pressing the "ON" button, I can hear a "click" like it wants to come on, but nothing happens. HEL
Oct 10, 2008 | Samsung HCN4226W 42" Rear Projection...
Kdf 42 we 655 - does not come on
I have the same problem, was the problem cause by the Lamp inside?
May 31, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Phillips 42" plasma power problem
See if the following solution is relevant for you (it worked for me and was worth it):
http://www.fixya.com/support/t182302-maxent_mx_42vm11_turn
Apr 11, 2008 | Televison & Video
Samsung 42' Rear projection - High freq squeal
solder around pins on flyback transformer,see if this will solve your problem.some flybacks will make this sound, like a ringing noise.
Jan 19, 2008 | Samsung HC-P4241W 42" Rear Projection...
No picture shows
HI THERE, I HAVE A PHILLIPS 42 INCH PLASMA SCREEN TV ITS ABOUT 2 YEARS OLD THE SOUND IS PERFECT BUT THE PICTURE IS DEAD MODEL NO IS 42PF55200/10 I HAVE HAD IT GIVEN TO ME TO SEE IF I CAN REPAIR IT BUT AT THE MOMENT NO SUCH LUCK THANKS JOHN
Dec 30, 2007 | Pioneer PRO-1009W 57" Rear Projection...
RCA P46924 46" Rear Projection Television Logo
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
