What about the heater. the a/c and heater share the same fan motor. If there is no force in the heater as well it may the the fan is not turning at full speed. should be able to hear the fan as well as feel the air from the ducts. another possibility is a blocked duct way. If you can hear the fan blowing full speed check the duct for obstructions.
SOURCE: heat comes on with ac cooling
what type of unit do you have fleet wood monaco ? useually this is a bad ground problem in a trailor motor home useually low voltage dc problem
SOURCE: No cool air!
if it starts blowing when you turn up the thermostat, but dont get any cold air most likely the coolant leaked of, call a repair person
SOURCE: dometic Duo Therm AC Brisk Air 13k btu not blowing cold air
you can buy a saddle valve, this is a valve you screw in. I am assuming you have the correct freon as where you purchased your freon they should sell the saddle valve. Hope this helped
Testimonial: "my first problem was solved thank you"
