Question about Microsoft Xbox 360 Console
Rrod no fan cd wont eject
When i switch my xbox on the light on the brick goes green then straight back to orange and i get rrod the fan start up for a second then stops i have done the x clamp mod andstill the same any thoughts anyone
Well for the cd not ejecting theres only a couple manual ways to eject it. these can be found at http://support.xbox.com/support/en/us/nxe/kb.aspx?ID=906935&lcid=1033&category=hardware
Posted on Apr 14, 2009
I did an x-clamp replacement after an RROD. I replaced the thermal paste and it went back to working for about a month. I just had the same problem: Unresponsive fans and disc drive. I simply took the thing apart(by now I am pretty good at it) and upon removing the heat sinks, the screws made a little "pop". After repeating the repair process I hand tightened the screws. I put the motherboard back in and powered it up. Green flashing light this time and the fans are working.
Posted on Jul 02, 2013
Dude how did you fix it? i have the same problem
Posted on May 28, 2012
My xbox ix switching on and shows three red rings and after 5 minutes the brick turn orange and it now has two red rings whay do i do to fix it
Thanks for your question. To fix the 3 red lights what you will need to do is stop the heat getting to the GPU and the CPU and to do this you can use a good Xbox 360 Repair guide or of course you can send it in.
Jan 10, 2013 | Microsoft Xbox 360 Console
My xbox 360 had gotten the red ring, so I heated the mother board with a heat gun and then replace the thermal paste, now the power brick is orange/yellow when plugged in, turn on the box it goes green for...
We STRONGLY recommend you not to use heat gun as it can heat other components, when your system have 3 red light and no fan are spinning it means that one of your fuses has gotten damaged and no power can go through your GPU chip.
Thanks
www.1RepairStop.com
We Fix Everything
Aug 31, 2011 | Microsoft Xbox 360 Console
Orange light on brick plug it into my xbox and light goes red and it wont switch on
the 360 has a power fault usually it is drwaing toomuch power for the relay in the brick to switch over, try removing the hdd and any wired controllers you may have in it and see if it will turn on
Jul 01, 2011 | Microsoft Xbox 360 Console
Xbox not coming on what to do
hi, what do you mean by ti wont come on
is it totally dead or do you have any red lights lit up on the power button
check the power brick and when you switch it on at the main it should have an orange light on it then watch the orange light as you press the on button it should turn green to tell you it working or flash red if it has a fault let me know ok.
try unplugging all the leads out of the back of the xbox and switch the power lead off at the mains. then plug all the leads back into the xbox, no the power lead can be a bit funny at times so push it in then try forcing it in a bit further sometimes the connections get weak and you need to push it in further so try this pushing it in as hard as you can.
then switch it on at the mains then try pressing the on button if the on button still wont do anything try pressing the eject button as this will also switch it on and open the disk tray
if its totally dead or you have any red lights lighting up tell me how many then i can assist you further ok
let me know how you get on or if you need further assistance ok
please rate this solution and leave a testimonial as i have pages of unrated posts as users forget to leave a response, thanks
Dec 08, 2010 | Microsoft Xbox 360 Console
My xbox not coming on what to do pls help me
My Ac Adapter i think is broken and my Xbox wont turn on but the AC adapter has a orange light that when i unplug it the orange light still does not go off.
Hi if the main brick has got an orange light then this is telling you the mains lead is working so try doing the following
1 unplug all leads from back of xbox and turn the power brick off at mains
2 plug the power lead back into the xbox, now when you push it in and it stops try pushing it in a little bit further usually they just dont push in far enough and it can be quite tight so make sure you are pushing it in hard enough,
3 now plug the video lead in and try switching it on,
keep an eye on the orange light whilst you switch it on if it comes on then it should continue to work if it dont come on watch the orange light and see it if changes color at the same time your switching it on, it will either flash green or red just once before going back to orange.
let me know what happens ok
Nov 28, 2010 | Microsoft Xbox 360 Console
Xbox wont power on past orange brick light
You need to have the 3 red light fix service. We can fix it for you. We are a listed repair service on this site. Here is a link to our 3 red light service.
http://www.videogamerepairservice.com/catalog/item/5675532/5556610.htm
Dec 08, 2009 | Microsoft Xbox 360 Console
Xbox 360 has orange light on the power brick,no power to console?
Mine has an orange light and works fine. i think that's standby mode. it turns green as soon as the 360 powers up. try replacing the power cord that goes from the 360 back to the power block. It may be faulty.
Nov 21, 2009 | Microsoft Xbox 360 Console
My xbox 360 wont turn on al all(not rrod)
Have you fully unplugged it and as in the mains from the adaptor, adaptor from the 360 etc? then re-plugged it?
If this does not help then i think you may need to visit http://www.xbox.com/en-GB/support
Oct 29, 2009 | Microsoft Xbox 360 Console
3 ROD but power supply constant orange,no green
When someone say that his/her Xbox is having 3 red lightsproblem, It means it needs to be repaired. If you are using Cooler thanit is not a cure but a prevention. You could have used cooler beforeacutally having the problem just to prevent your Xbox. But now you willhave to either get it repaired from Microsoft (in case your Xbox'swarranty is not expired, but one thing to note is that you will have towait for at least 3-4 weeks to get back your Xbox) or you can Fix yourXbox's 3 Flashing red lights problem yourself with the help of DIY Video guide available on Internet. You can fix yourself without any technical knowledge.
Oct 23, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
548 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
