Question about HP PSC 2410 All-In-One InkJet Printer
Busy or hourglass object appears in screen. Won't work
I am getting an hourglass figure on my hp psc 2410 showing that the printer/scanner is busy and it will not print, scan or copy. How do I fix this? I have fixed it before but just by turning the machine off and on or playing around with it.
  • Anonymous Apr 27, 2009
    I have the same problem. How do you fix it? It did it one other time but seemed to fix itself
  • 700 Answers
If there still pending job to print. Cancel all printing job until all printing job is clear. Then power off the printer and then power on again to refresh its print que.
Hope this one helps
Posted on Apr 28, 2009
My hp psc 2410 all in one can't start. it diplay shows busy massage and scanner make machenical nose
the scanner bulb assembly is unable to come to its starting position. this assembly rides on a metal spindle, rub some oil on it so that the slide becomes smoother. to reach it you will first have to remove the glass. turn the scanner upside down & prise it open with a flat screwdriver applying pressure at the rear end to separate the top & bottom half.
Dec 29, 2010 | HP PSC 2410 All-In-One InkJet Printer
Screen on hp psc 2410 shows picture of hour glass
I too have this problem and I have found how to correct it. It worked for me and hopfully it will work for you and others. Turn off your printer. Open the scanner cover. Turn your computer back on. That is what I did and it fixed it for me for now. Please send me an E-Mail if it fixed it for you. I have a sneaky suspecion that it just started working again and me opening the scanner cover was not the fix. Thanks, Wayne
May 23, 2010 | HP PSC 2410 All-In-One InkJet Printer
When I turn on my 2410 printer the hourglass stays on endlessly.
try uninstalling and reinstalling
Don't forget to rank the advice!
http://www.aa1consulting.com
Jul 27, 2009 | HP PSC 2410 All-In-One InkJet Printer
Loud motor sound and green blinking ON light....!!!!
clean the cartridge rails and move the cartridge by hand if possible the full length of the rail, turn off, then on to reset. Hope that fixes it for ya
Jun 20, 2009 | HP PSC 2410 All-In-One InkJet Printer
Printer wont work! Hp Psc 2410 All In One
I had the same problem and following a suggestion on another forum, http://www.fixyourownprinter.com/forums/printer/42155#2, I cleaned the bottom of the glass and it now works better than it ever did before. Taking it to pieces is a little tricky but not impossible.
Jun 11, 2008 | HP PSC 2410 All-In-One InkJet Printer
Printer won't work
nine times otu of ten the power hit damage the dc controller borde.
Apr 01, 2008 | HP PSC 2410 All-In-One InkJet Printer
Machine won't boot up
I found this suggestion on line and it worked. After turning on my hp psc 2410 photosmart all in one, it just started making a peculiar sound and wouldn't boot up. It was useless. What I did to correct the problem (as per suggestion from cdpena@sbcglobal.net) was to hold the cancel button down before I turned the printer on and hold it down through the start up process. The thing works now. The problem may have been caused by a power outage. Thanks cdpena@sbcglobal.net. I almost bought another printer.
Sep 04, 2006 | HP PSC 2410 All-In-One InkJet Printer
Unit wont start up after power failure
Answer on fixyourownprinter.com. Search there to see how to lubricate rod under scanner glass. Common fault. Mine responded instantly starting up fine after rod lubrication which stops scanner initialisation routine and leaves you looking at hourglass.
Jul 30, 2006 | HP PSC 2510 All-In-One InkJet Printer
HP PSC 2410 All-In-One InkJet Printer Logo
611 people viewed this question
Seeker5211
Seeker5211
