Question about Belkin (F5D7230-4) Router (587009)
Bitcomet and Belkin router
I have a bitcomet downloader and its always shown on his status''your listed port is bloced" and in my status light always showing a yellow light which means blocked and it said ''please check your Firewall and NAT configuration.''
I have BELKIN Wireles cableDSL Router F5D7230.
I need best solution.
  • samgangee May 11, 2010
    sounds like u need to get into the settings of ur router and forward the ports properly to ur computer, if u have the manueal to ur router then look up the section on port forwarding
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 93 Answers
To fix this issue all you have to do is,You should open the bitcomet downloader portnumbers on the belkin router,you need to open default page by typing 192.168.2.1 in address bar.
And also i would like suggest you to disable firewall on router and check for firmware update... It may be quiet difficult for you to do all this.please call tollfree number"belkin" and ask them to change these settings which i have mentioned.and it will definitely work.....
.....Hope this is help full for you
Posted on May 31, 2009
Bitcomet listen port is blocked
You need to forward the specific port bit comet uses to listen,in your
router.To do this follow the below steps.
1) Go to this page http://portforward.com/
2) Scroll down the page and search for your modem/Router and
click on it.
3) Select the aplication from the list,in this case Bitcomet.
4) Now follow the step-by-step guide on this page to successfully forward your bit comet port.
Once you have done that restart your bitcomet and the listen port should now turn green indicating that it is open and functioning properly.Hope it helped.
Nov 21, 2010 | BitComet
Just connected talktalk router to pc but when i go onto bitcomet to download music,i seem to be blocked.do i still need a modem.
R U the Administrator of the WRT54G Router If not then ask to ur Administrator to unblock the site preference
then go to the WRT54G Router configuration page & Check for Access Restriction>Internet Access Policy
modification.
Apr 13, 2010 | Linksys Wireless-G WRT54G Router
Listen Port of TCP: 2869 (Blocked by Firewall/Router) how do i change nat router settings?im blocked when usin bitcomet software
try to disable ur firewall setting, enable nat, and rip
try set port forwarding to port 65535, dont forget to set bitcomet port 65535 too
Oct 08, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Need a port opened to speed up downloads
Hi. It really depends on what type of modem or router you are using to open up ports. Also if you are using an application for downloading such as Bitcomet, you need to find out what port or listening port is currently configured on Bitcomet. for example, the listening port on Bitcomet is 4545, then you have to open port 4545 on your router or modem.
You also need to make sure that your modem or router has port forwarding features..
you may also visit this link for instructions on how to forward or open ports to different types of routers...
May 10, 2009 | Computers & Internet
Yellow light with bitcomet 1.10 using xp and netgear dg834g
go to your router setting and try to disable all firewall, if still not work, check your port forwarding setting, it could went wrong, different router have different name for port forward. must set bitcoment port ..let say 65535 and set port in router 65535.
Mar 28, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Listenning port bit comet
BitComet requires you to be able to receive incoming connections. If you're behind a NAT router but don't have port forwarding configured properly, incoming connections will be stopped by your router (won't get to your computer).You need to configure port forwarding, so your router knows that the incoming connections are for BitComet and will be allowed through (= forwarded) to your computer.
There are several versions of your router:
DSL-2640B, DSL-2640Bv2,...
Go here, scroll (almost all the way down) and find your router model.
On the next page, skip the advertisement (upper right corner) and look for BitComet.
Simply follow the instructions on that page - they are precise and correct.
In general: You can use ANY port, but I would prefer a listen port between 49152 and 65534 because they're classed as "Dynamic and/or Private Ports" by IANA, so nothing else should be using them by default and they're not the standard ones blocked by ISP's or trackers, but - as I said - you can enter any other port you wish.
If you have any more questions, just come back and let me know - I'm happy to help.
Good luck & thanks for rating!
Mar 13, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Cant get a green light in bitcomet
You might follow these instructions
http://portforward.com/english/routers/port_forwarding/Belkin/F5D9230-4/BitComet.htm
(although the creation of a static IP is not necessary) if you don't make it then you might have to change the IP you forward the port to depending on whether your computer's IP changes. (you can check that under the network page you find in control panel by highlighting the network you're connected to and looking in the bottom right corner of the window) (or by opening cmd through run and typing ipconfig).
Oct 13, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
PORT FORWARDING
you can check a site for speed site to help. http://www.speedtest.net/
last option call the survive provider
Aug 13, 2008 | Belkin (F5D8231-4) Wireless Router...
Belkin N1 Connecting to Internet
I AM USEING BITCOMET ,AND IM HAVING PROBLEMS FINDING A PORT WHICH WILL ALLOW MY DOWNLOADS TO BE QUICKER. HOW DO I SOLVE THIS PROBLEM?
Jun 20, 2008 | Belkin (F5D8231-4) Wireless Router...
Belkin (F5D7230-4) Router (587009) Logo
427 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
