Palm m515 frozed up when powered on.
I powered on my palm m 15 and screen frozen also now it won't turn ligh ton nor power off again. Battery is full power and it's currently sitting inthe cradle. I cannot synchrinize either. Totally stuck. PLease help!
Did you install something rare at your palm??? Is your palm Sayin "Fatal Exeption" when you Reset it??? If you install something rare and after that your palm is saying taht you can...
Do a soft reset:
Reset it normally... If after that your palm show again that message you can;
Do a warm Reset:
Pres de up scroll when resseting.. when you so the Palm logo you can stop press the reset botom... There you will see the configuration screen... If it is not more the "fatal exeption" message you can uninstall what is doing the problem... you can hot sync your palm now... after that... do a soft reset and-If you uninstall what is doing the problem- you are not going to saw any more that message... if it is not resulting...
Try to do a Hard Reset
Do a warm reset and copy all you important files or programs to your stick memory...
then when pressing reset botom pres the on-of screen botom.... when you see the palm logo you can stop presing on-of screen botom.
bye.
From paraguay... luis-c
(sorry for my english... im stilll learning)
Posted on Apr 22, 2009
Palm life drive frozen on "palm one "screen
When you see the first screen (the orange one) hold the UP button as the bar moves across the bottom of the screen. Let go right before the screen goes to the silver logo. If it continues and opens Prefs, then you need to delete the program causing it to reboot. If that doesn't work, do a Hard Reset. A Hard Reset will erase everything on your lifedrive, so only do it if you have to. Hold the Power Button while you push the reset button. Continue with the instructions to finish erasing your device.
Feb 17, 2010 | Palm LifeDrive Handheld
T5 is frozen on the "Palm Powered" screen
Remove the battery and let the palm sit for a day, reconnect the battery and do a hard reset. To remove the battery, you need a Torx T5 screwdriver. Carefully remove the cover making a note of the location of all the buttons in the case. The battery is connected by a mini 2 pin connector, just disconnect the battery by gently wiggling the connector and pulling.
Mar 06, 2009 | Palm Tungsten T5 - Multilingual Handheld
Palm T3 frozen, tried restart in hole, nothing?
take the battery off for 15 seconds and put it back again. you need to reboot your Palm at least once a week. goodluck!!!
Jan 31, 2008 | Palm Tungsten T3 Handheld
Frozen screen ( palm powered)
Perform soft reset. If issue persist you may consider full reset
Nov 08, 2007 | Palm Tungsten T Handheld
PDA intermitently powers up then freezes on "Palm Powered" screen
I had the same issue. What you need to do is to hold the power on/off button than press the reset button. The screen turns off (get black) than the will ask you to make a hard reset (which end up deleting all datas). The Palm will power on like the first time you turned it on after you bought it. Than depending which version you have it will possible ask you which language you will like to have as default. After selecting you neet to setup the rest. If this is done you sync it all data will come back :-)
Jul 04, 2007 | Palm Tungsten E Handheld
Palm turns on but will not operate programs
You need to perform hard reset by pressing reset and power button same time.
Nov 20, 2006 | Palm m515 Handheld
223 people viewed this question
 Grubhead
Grubhead
