Question about Kenwood Sirius KDC-MP925 CD Player
Kenwood MP925 cant get to work
After about 1 year of use, the deck does not close correctly. After powering on, it goes down, up and off. A few weeks back this started and after 3 or four times it would come on and work. Now it just keeps powereing off. I've seen the same problem posted here and elsewhere many times, yet I have not found a solution. Any suggestions short of throwing it off a bridge would be greatly appreciated.
  • jaymadhavan May 11, 2010
    is this give you no display
  • 752 Answers
The ribbon cable to the face plate needs replaced. It's an easy fix and any shop that does car audio repairs will likely have them in stock (mine does). Every shop has their own rates but my shop charges around $65-75 to fix that problem. Call around and ask. The bad part is: J84-0153-05 FLEX-RIBBON CABLE FROM FACE TO MAIN PCB
Posted on Sep 22, 2007
Kenwood KDC-W7027 will not go home all the way
Chances are, there is either a bad gear or a bad position sensor lever. More than likely it will be the lever. Both parts are inside of the deck itself
Dec 11, 2012 | Kenwood KDC-W7027 CD Player
The radio opens with lights and lsights go out and immediately closes. Keeps opening and closing with no sounds. After doing so for a bout a year... radio came on. However did not come back on when I...
It sounds like it could be a bad ribbon cable. There are two ribbon cables in the deck, so it could be either one, or both. There is also a face position sensor lever inside the deck that goes bad.
Jul 22, 2011 | Kenwood KDC-MP822 CD Player
I just bought a Kenwood KDC-MP438U I installed all the wires right, power is to the deck because it accepts a cd. the deck face doesn't light up. I called in at Kenwood and they had me test it directly to...
Check your Ground Wire inside the Truck and Check the Illumination Wire. I Think on Kenwood the Illumination Wire goes with the Power Wire. If they still will not work, You might want to get a Wiring Harness from Schoche.com Please Rate My Response! Thanks!
Jan 30, 2009 | Kenwood KDC-MP438U Car CD/ MP3 Player
Kenwood UD-551M hi-fi stereo ...problem
power problem of power amplifier .
if you can open the cover we can give try to solve this problem.
nuwan
Sep 02, 2008 | Kenwood CT 401 Hi-Fi Stereo Dual Cassette...
Cq-vd6503u
i took it back they had it on for four days straight no problems they said so i guess i am going to check my wiring to see if it fixes it
Mar 19, 2008 | Panasonic CQ-VD6503U Car DVD Player
Toc code keeps comeing up on my kenwood kdc x5589
Hi, toc error means that the laser is struggling to read the Table of Contents which tells the unit where all the information is on the disc, it may be something as simple as the lens needs cleaning or something as complicated as the laser needs replacing, but you could try running a cd disc cleaner through it first. Good luck......
Jan 24, 2008 | Kenwood eXcelon KDC-X559 CD Player
Car Stereo Volume Goes Up and Down Erratically
prolly buy a truck and a amp from this century
Oct 05, 2007 | Car Audio & Video
No power to the cd receiver.
There is a fuse both in the back of the deck...and in your fuse panel... Refer to your service manual for the car to find the correct fuse for the audion system. and Refer to your service manual for your deck to see what im talking about...all the fuses Ive seen just plug into the back of the deck.
Mar 29, 2007 | Kenwood KDC-V7017 CD Player
Initialization Problem
Hi, I'm not an expert but if you phone 0113 202 1040 a company called unicar - they have a specialist repairs department that may be able to help you. regards
Nov 12, 2006 | Kenwood Sirius KDC-MP925 CD Player
Kenwood Sirius KDC-MP925 CD Player Logo
110 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
