Computer Will Not Boot
I turn on my computer then it goes to a screen saying safe mode safe mode with networking safe mode with command prompt last known good configuration and start windows normally ive clicked everyone of them then a blue screen comes up and goes away real quick then it goes back to starting over with the same screen
  • M Nelson
    M Nelson May 11, 2010
    How old is the PC?
    What OS...Vista?
    Did you add any hardware l8ly?
    Any other bits of info that might help us identify the problem?
  • 326 Answers
You will need to do either an in-place upgrade of your Widows OS
Or
Use a System Restore Disk.
Let us know what happened prior to these issues so we can give you a better estimate of the necessary steps to get you on your feet.
Good luck
Posted on Apr 14, 2009
I'm forgot my password to login
If you are not able to boot your computer in normal mode or supposed your notebook is infected with Trojans or malware, you are able to get rid of them with Safe Mode. Furthermore, it is easier and safer to bypass Windows 7 logon password in Safe Mode when lost or forgot Windows password.
For Windows 7, there are 3 different types of safe mode, Safe Mode, Safe Mode with Networking and Safe Mode with Command Prompt. The following guide is about how to bypass Windows login password with Safe Mode with Command Prompt. With command in safe mode, you can reset Windows password. Details are as follow:
Step 1: Start or restart your Windows 7 computer.
Step 2: Press F8 to enter Advanced Boot Options before the Windows 7 loading screen appears.
Step 3: Choose Safe Mode with Command Prompt in the coming screen, and then press Enter.
Step 4: Wait for Windows 7 files to load until Windows login screen comes up.
Step 5: Log in with an administrator account until you see login screen.
Step 6: A Command Prompt appears. Type net user in the Command Prompt and then hit Enter. All Windows user accounts will be listed for you.
Step 7: Type "net user iSunshare 12345" and hit Enter.
reset-windows-password-with-cmd.png Step 8: The new password has been successfully reset when the command is completed successfully.
Step 9: Log on your PC with the new password.
Aug 21, 2014 | Computers & Internet
Safe mode in lennovo g500
When you start your computer. Hit the F8 key, and then a prompt will come up to boot in Safe Mode, Safe Mode with Networking, and Safe Mode in Command Prompt. Make your choice.
Apr 08, 2014 | Lenovo Essential G500 Laptop Computer -...
I am stuck in Safe mode with command prompt on my Dell 620 laptop windows xp every time I type a command it says it is not recognized as an internal or external command, operable program, or batch file....
try restarting the laptop and before anything pops up on the screen hit the f8 key and the boot menu comes up then start in last configuration that worked and see if it helps
Sep 30, 2013 | Dell LATITUDE Computers & Internet
I had to launch start up repair and the battery died half way through... The laptop now says "Computer build error. File exception failed to find c:/ (etc)" and it won't turn on, just...
Step 1:
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. Select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive You should have no input while chkdsk utility is in progress any input might further damage your computer also Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file. Type the following command and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
Feb 07, 2013 | Computers & Internet
Recovery 32 type mismatch message
Step 1:
Enable VGA mode
Reboot
Feb 03, 2013 | Acer Aspire 4720 Notebook
When i boot my computer, it displays JPRGI is compressed. what does this mean
disk error which generally means your disk has failed. You need to get your data off it if it is not backed up. You will have to replace the disk.
A local computer shop might, just might, be able to install it into a second computer and read the data.
Enable VGA mode
Reboot
Jan 25, 2013 | Dell OptiPlex 360 Desktop Computer
Whenever I try to start my laptop, it runs a check of the C drive and then, afterwards, I can't get to my desktop without getting a blue sreen saying there is a problem with my C drive.
To use a Safe Boot option, follow these steps:
  1. Restart your computer and start pressing the F8 key on your keyboard. On a computer that is configured for booting to multiple operating systems, you can press the F8 key when the Boot Menu appears.
  2. Select an option when the Windows Advanced Options menu appears, and then press ENTER.
  3. When the Boot menu appears again, and the words "Safe Mode" appear in blue at the bottom, select the installation that you want to start, and then press ENTER.
Description of Safe Boot options
  • Safe Mode (SAFEBOOT_OPTION=Minimal): This option uses a minimal set of device drivers and services to start Windows.
  • Safe Mode with Networking (SAFEBOOT_OPTION=Network): This option uses a minimal set of device drivers and services to start Windows together with the drivers that you must have to load networking.
  • Safe Mode with Command Prompt (SAFEBOOT_OPTION=Minimal(AlternateShell)): This option is the same as Safe mode, except that Cmd.exe starts instead of Windows Explorer.
  • Enable VGA Mode: This option starts Windows in 640 x 480 mode by using the current video driver (not Vga.sys). This mode is useful if the display is configured for a setting that the monitor cannot display.
    Note Safe mode and Safe mode with Networking load the Vga.sys driver instead.
  • Last Known Good Configuration: This option starts Windows by using the previous good configuration.
  • Directory Service Restore Mode: This mode is valid only for Windows-based domain controllers. This mode performs a directory service repair.
  • Debugging Mode: This option turns on debug mode in Windows. Debugging information can be sent across a serial cable to another computer that is running a debugger. This mode is configured to use COM2.
  • Enable Boot Logging: This option turns on logging when the computer is started with any of the Safe Boot options except Last Known Good Configuration. The Boot Logging text is recorded in the Ntbtlog.txt file in the %SystemRoot% folder.
  • Starts Windows Normally: This option starts Windows in its normal mode.
  • Reboot: This option restarts the computer.
  • Return to OS Choices Menu: On a computer that is configured to starting to more than one operating system, this option returns to the Boot menu.
An environment variable is set when you use one of the Safe Boot options. The environment variable is SAFEBOOT_OPTION. This variable is set to either Network or to Minimal.
The default Microsoft VGA driver is used for display at 640 x 480 resolution and in 16 colors. You must log on in all modes by a domain or by the local Security Accounts Manager, depending on which Safe Boot mode you select.
Use the System File Checker tool (SFC.exe) to determine which file is causing the issue, and then replace the file. To do this, follow these steps:
  1. Open an elevated command prompt. To do this, click Start, click All Programs, click Accessories, right-click Command Prompt, and then click Run as administrator. If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
  2. Type the following command, and then press ENTER: sfc /scannowThe sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
To determine which files could not be repaired by the System File Checker tool, follow these steps:
  2. Type the following command, and then press ENTER: findstr /C:"[SR] Cannot repair member file" %windir%\logs\cbs\cbs.log >sfcdetails.txtNote The Sfcdetails.txt file contains details from every time that the System File Checker tool has been run on the computer. The file includes information about files that were not repaired by the System File Checker tool. Verify the date and time entries to determine the problem files that were found the last time that you ran the System File Checker tool.
  3. Type the following command, and then press ENTER: edit sfcdetails.txtThe Sfcdetails.txt file uses the following format: Date/Time SFC detail
This information was obtained from Support.microsoft.com
Oct 04, 2010 | Gateway E-475M Notebook
How do you put windows into safe mode?
Power on or Restart your computer, keep tapping F8 on the keyboard while it boots up. After few seconds, you'll be taken to the "Advanced Boot Options" with "Safe Mode" in the lists. Use the Up-Down arrow keys to highlight the "Safe Mode" and press enter on the keyboard to confirm the selected boot options. Black Screen with white texts will be displayed on the display, wait for few seconds until you see the windows logon Screen. You'll also see a confirmation message box asking you to confirm to boot into Safe Mode, click "yes" or "Ok" and proceed forward. There now you are in the Safe Mode.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 26, 2010 | Computers & Internet
Laptop Will Not Boot
chose start windows normaly
Apr 14, 2009 | Acer Aspire One PC Notebook
Computers & Internet Logo
75 people viewed this question
David Payne
David Payne
