Error 50 code, have replaced fuser and checked connections
I have a Brother HL-8e printer. the error code 50 shows on the screen. I have replaced the fuser and checked the connections and the error code 50 still come on. Is the next step to replace the DC controller board and if so where can I find one? Roger Anderson
I am not sure this will stay fixed but after i cleaned the pcb's and checked the connections and let the unit sit overnight the printer works just fine. If this does not stay fixed I will contact you again.
Thank you,
Posted on Apr 15, 2009
How do I replace the fuser in a Brother 2460?
This is a technical procedure. But if you are up for it follow the links below which should give you enough details presuming that you have purchased a new fuser unit.
http://depot.hrblock.com/technologyservices/DownloadFiles/Brother2460NFuserReplacementManual.pdf
How to fix fuser error Brother HL 2460 printer
Jan 15, 2015 | Brother HL 2460 Laser Printer
HL-5250 report shows fuser and laser life at 0% and PF kit 1 at 12%
The fuser is a separate component to the drum and toner in this printer. It has a much longer life than them but will run out eventually. Sadly a fuser unit is not a commercially available consumable for this printer either. I would recommend contatcing a printer technicain or Brother directly for a quote on replacing this part.
Apr 12, 2013 | Brother HL 5250DN Laser Printer
Error fuser unit hl-5350Dn
The fuser unit is located at the rear side of the printer.
Fuser unit error indicates one/more of the following.
1. The fuser roller/film life is over. Replace with new one
2. The fuser film is torn. Replace with new one.
3. Fuser heater is burnt. Replace the heater.
4. Fuser thermal sensor is open. Replace it.
sonsunny
Jun 28, 2011 | Brother HL 5250DN Laser Printer
Error code 50
Error Code E50. This printer error code flashes when the fuser unit of your Brother multifunction printer gets damaged. When this happens, it is a signal that you must replace your printer's fuser unit
Mar 15, 2011 | Brother Multi-Function Center MFC-240C...
I have a hl 7050 printer. Recently on the screen mention "Error E52". What does it mean?
That error means the fuser has gone out, could be a dead lamp, or temperature sensors. Chances are you need a new fuser if you have 50,000 or more prints on this machine. www.precisionroller.com will have a new fuser.
Jan 28, 2010 | Brother HL 7050 Laser Printer
My printer Brother HL-6050DN show ERROR E50. How can I fix it?
Oct 21, 2009 | Brother HL 6050 Laser Printer
Error 50 display
Likely, your fuser is bad. However, there can be a problem with little pcb (circuit board) that sits almost under the fuser. Check the P2 connector and see if it is loose on the pcb. It can have cold solder joints that will also cause this error.
Oct 01, 2009 | Brother HL 2460 Laser Printer
Brother HL 2460 has E- 50 error code
you shold change the logic board to slove this problem
Dec 30, 2008 | Brother HL 2460N Laser Printer
Error 50
Error 50 is a fuser unit fault code. You can take apart the fuser unit and see if the fuser lamp is functional. Also check some of the other thermal parts on the fuser. If everything checks out, you will probably have to replace the thermistor. You will need to see if it will be cost effective to replace the necessary parts (Brother parts are not cheap), or to buy a new printer. Hope this helps. Good luck.
Jun 19, 2007 | Brother HL 1430 Laser Printer
214 people viewed this question
jasbo
jasbo
