Question about Dell Inspiron 1150 Latitude D600 14.1 LCD Display-LP141X14 CD-ROM Drive
Won't start from standby
When i hit the power button my computer started to load then windows said going into standby mode, it shut down and now it won't start. i have tried removing the power cord and battery and that was no help.
    Champion:
  • 208 Answers
Sounds like charger is bad or dc jack plug broke inside on motherboard.
if u can get battery charged on another same type laptop then put back in it should start.
Posted on Nov 03, 2007
SOURCE:
Power light blinking on nv53a gateway
Your Gateway laptop comes with a series of LED lights that alert you to the state of your computer. You'll notice there are blue, purple and red lights that either blink or display solidly. Each light, blinking or solid, has a different meaning. The blue blinking light on your laptop indicates that it is in Standby mode. Your laptop goes into Standby when you close its lid without shutting down the computer. To turn this light off, you'll need to take the computer out of Standby mode, and if you want to ensure that the blinking blue light does not return, shut down the computer after each use.
Open the lid of your Gateway laptop and press the power button. Once Windows loads, enter your password if required. The blue light will no longer be blinking because the computer is no longer in Standby mode. Shut the laptop off when you finish using it rather than simply closing the lid to stop the blue light from blinking again. Click "Start" from your Windows desktop and click "Shut down." Change your computer's power settings to keep if from going into Standby mode when you close the lid if you'd rather not shut down your computer every time you use it. Click "Start" and click "Control Panel." Click "System and Security" and then click "Power Options." Click "Choose what closing the lid does" from the list of options on the left side of the window. Select "Hibernate" from the drop-down lists under "On Battery" and "Plugged In." Click "Save Changes." Your laptop will now bypass Standby mode when you close the lid and it will enter Hibernate mode instead. Hope it helps.
Jan 23, 2013 | Gateway MT6730 Notebook PC
Enable Hibernation in Windows 7 Starter on Samsung N150
Sleep mode on a Windows 7 PC saves power without you having to turn your computer off and without losing any work. This option cuts the power to your monitor, powers down the hard drive and pauses all functions until you awaken the computer from hibernation. Whether you have a laptop, desktop or workstation, putting your computer into sleep mode will lower your electric bill and save money! Click the "Start" button in the lower left corner of your desktop. In the lower right corner of the Start menu, next to the "Shut Down" button, is a button labeled with a small, right-pointing arrow. Mouse over the arrow. The Shut Down menu appears. Point at "Sleep" and click on this option. Your Windows 7 computer goes into sleep mode. Wake your computer from sleep mode by jiggling the mouse. There may be a delay of a few seconds before your hardware powers on. All of your open programs are still open and your work is intact, just as you left it before the computer entered sleep mode. Configure your Windows 7 PC to go into sleep mode automatically when it is not used for a certain amount of time. Click "Start" and select "Control Panel." Click "System and Security." Click "Power Options." A menu opens. Click on "Choose when the computer sleeps" and select the number of minutes of inactivity. You can also set a separate time interval to put your monitor into sleep mode. If you set both to 10 minutes, then your PC and monitor will automatically go into sleep mode after 10 minutes of inactivity Your Computer in sleep mode b> First, save all of your work. Information in computer memory is not saved while your computer is on standby. From the Start menu, select Settings, then Control Panel, then Power Management. Click Standby Beside When I Push the Power Button. Push the Power button. b> Automatically Putting Your Computer on Standby b> Save all work before leaving your computer. From the Start menu, select Settings, then Control Panel. Double-click Power Management. Set the times that you want your system to go on standby, to shut off the monitor and to shut off the hard disks. Click OK. Your computer will go on standby according to the schedule you have entered. b> Putting Your Computer in Hibernation b> From the Start menu, select Settings, then Control Panel. Double-click Power Settings. Click on the Advanced tab. At the When I Push the Power Button On My Computer screen, click Hibernate. Click the Power button. Hope this helps.
Jan 16, 2013 | Samsung N150 Series Netbook
Won't go into sleep mode
Which operating system ?
A menu opens.
Hope this helps.
Nov 25, 2012 | Dell Factory Refurbished 4700-HH79N81...
Accidentally put my system on standby mode..using XP OS and DIY desktop.now i cannot get out of standby mode..check KB and mouse ok..any shortcut key or other ways i can start up and boot?even my two DVD...
I think you have to shut your computer down completely and reboot. This means that you will lose any work you didn't save before going in standby mode.
If your PC has a 'reset' button (usually located near the power button), press it. Your machine should reboot. If it doesn't or if you don't have one, you can try pressing and holding the power button for about 5 seconds. This should shut down your computer completely. Press the power button once more and it should boot normally, though you might get a warning saying Windows didn't shut down properly. If you get the choice, just choose to boot Windows normally. If pressing and holding the power button doesn't work, try looking for a power switch on the back of your machine. It should be near the power cable. Flip the switch, wait a few seconds and flip it again, then boot your computer as usual. You might get the same message which I mentioned above.
Mar 20, 2011 | Microsoft Computers & Internet
Blue led power light blinks even after shutdown
What operating system are you using? When the power led continues to slowly blink, that means that the laptop is in standby mode and not fully shut down. In Vista, if you hit the power button on the laptop or the power button under the start button, it is configured to go to standby and not shut down. Make sure to hit the arrow all the way to the right and select shutdown from the list of dropdown options.
Aug 28, 2009 | Gateway Computers & Internet
Sleep Mode Lockup on Dell Inspirion 530 w/ Vista
Try hitting the "Windows" key on your keyboard to bring it out of sleep mode. The "Windows" key is generally found on the bottom row of the keyboard, near the Alt and Ctrl keys, and it has no letters on it, just the Windows logo. That key brings my Windows Vista machines out of sleep mode when other keys won't.
As for the power button, anytime you need to force a computer to turn off, you can press and hold the power button to do so. Usually, you need to hold the power button for 5-10 seconds and it will shut down. Use this option with caution, as it turns the computer off without running through the shutdown process and can cause you to lose data.
Hope this helps.
Mar 08, 2009 | HP Media Center m7060n PC Desktop
My acer computer will turn on but wont come out of hibination mode
Some laptops have issues with Windows XPs hibernation mode. To get the computer back up again you should just hold the power button down until it shuts off completely. Some laptops won’t shut off even if you do this. When this happens you have to take the battery out to get it to turn off. Make sure it is not plugged into the wall when you do this otherwise it wont work.
Once you get the computer back running again you may want to disable hibernation if it seems like its going to keep happening. Go to Start, Settings Control Panel or Start, Control Panel and go to the Power Options icon. Change the hibernation section to never. You may want to try standby as an alternative. Standby saves all your running applications and documents into RAM while hibernate saves them to the hard drive. Hibernate uses less power from your battery, but it will take you considerably longer to get the computer back up. If you always plug the computer in then you may want to disable standby and hibernate since you really dint need them while plugged in.
Let me know if this works.
Aug 16, 2008 | Acer Computers & Internet
Boot failure pentium 4
here is a temporary fix, but you may like it as a permanent one. Use the Windows hibernate mode. It actually works every time! Windows makes a "System screen shot" and stores it on hard drive and then powers off. Just be aware that you must ensure enough hard drive space for this. I am using this mode every day now. I think your system is trying to reject the power-saving features selected in Windows or at CMOS settings. Try turning off (or disabling) one feature at a time. I still think hibernate is the way to go. Here is a useful tip: to force hibernate (after it has been enabled) select START-SHUT DOWN and hover over STANDBY button and then hit the SHIFT key. The STANDBY button will turn into the HIBERNATE button. This is a quick way to enter hibernate. Remember to enable SYSTEM RESTORE mode so that if anything goes wrong during this "experiment", you can easily restore Windows system. I also use RESTORE but I also "clean house" once a month by turning it off and Disk scan and defrag and turning it back on.
Jun 24, 2007 | Intel D845WN (KD845WNPAK10) Motherboard
Dell Inspiron 1150 Latitude D600 14.1 LCD Display-LP141X14 CD-ROM Drive Logo
Ekse
Clive
Clive
