Question about Sony KV-32FX60 TV
Sony FAQ Troubleshooter does not help enough
Mt Sony Trinitron KV32FS13 turns on, (without picture or sound); for a few seconds only the Timer/Stand by light blinks. Intermitent beeps are heard, then the set goes of again. I tried the recomended steps: 1) Checked that the Cable feed was hood on properly, 2) Simultaneously pressed the reset and power bottons on the remote, 3) Unpluged the power cord for one minute then reconnected it. 4)The remote control works ok.
Number of blinks denotes specific problem each number assigned to where fault is but do not know codes anymore, try going into tt menu if it lets you and check error codes.
Posted on May 03, 2008
    Genius:
  • 1,153 Answers
You have a power supply short. Are the tubes lit in back of set? If so you have filament and no high voltage. This could because a Horizontal output, or Vertical output bad. Will need someone who knows about soldering and unsoldering.
Posted on Sep 13, 2007
SOURCE:
Our Trinitron KD-27FS170 Tv will not turn on. It sounds like it is turning on/off but no picture or sound. The Stand-by/Timer red light is flashing 4 times, pause, then 4 times, etc.
This typically means you have a bad capacitor, you can inspect for any swollen or bulging capacitors however unless familiar with desoldering boards best leave it to a repair technician.
Jan 13, 2015 | Sony FD Trinitron WEGA KD-27FS170 TV
Sony Trinitron Stand By/timer light continous blinking - cannot get picture to come on or how do I turn off the stand by/timer off so the TV picture can come on
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Type in this key phrase " my service table today " in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site. The search result might display about 20 Nos of related posts. Press the "All posts" at the bottom of the list, then you can select them one by one.
Jun 15, 2017 | Sony FD Trinitron WEGA KV-32FS210 32" TV
My sony trinitron xbr tv turns on stays on a few seconds then powers off by its self and it gives 5 red blinks from stand-by
This is according to the sony service manual
Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Sounds like a failure in the C Board or AKB Circuit.
Best to take it in to a service center.
May 30, 2011 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony Model KV32FS13, blinking lights.
check the horizontal output of your tv set,if short you need to replace it.
Dec 09, 2008 | Sony KV-32FS13 TV
Sony kv32fs13 No Picture or sound stand by light flashing
try to resolder back the pcb some part is loose connection
Dec 08, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron KV-32fs120 Does Not Turn On
i have a unvirasal remote how do iget the codes for it
Sep 29, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
2000 Sony Trinatron #KV-36FV26
IF--- You have 3 video ics located on CRT broad # TDA6111Q ,if only one of them is shorted set will not come on these ics will kill the high voltage, there for keeping set off.
May 18, 2008 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Tv wont turn back on
Hii.... first I like to know the chassis of yor KV27FS100..
sound like problem with regulated parts block.....and can more helpfull if you count the blinking of the LED....sony have selft diagnostic at the LED Blinking.....
I hope hear from you soon....
Thank's
[Vrya]
e-mail : [email protected]
Feb 23, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Re: Sony KV-24FS120
your problem in system control ic section related to stand by pin check ckt related to stand by section in remote ic check power to system ic loose coniact in remote or system ic thanks
Sep 09, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Tv flashing stand by / timer
Sony tv's have a myriad of problems that prohibit the High Voltage from activating. The flashing red light indicates the standby circuits are functioning correctly. You problem lies in the H>V section.A shorted horizontal output transistor or even poor connections on the horizontal drive transformer could cause this problem. To properly diagonose this problem,it must go to a service facility that is familiar with Sony servicing. Usually Sony repairs are not cheap. It is imperative that only Sony original parts are used. Scrivitron
Jun 20, 2007 | Sony FD Trinitron WEGA KV-32FS320 32" TV
Sony KV-32FX60 TV Logo
138 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
