Question about Pioneer DVR-107D DVD±RW Burner
SA Explorer 8300HD DVR just installed. Constant whine and noise of hard drive, even when unit is turned off. Is there any way to get it to power down fully without unplugging it? I'm in New York City, with Time Warner Cable. Thanks.
  • Anonymous May 24, 2009
    Hard driver seem to run all the time. I just started doing this last week. Don't know what. Make it stop!
    Problem Solver:
  • 6 Answers
There is a setting you can set to have the hard drive sleep after so much idle time. I don't know if Time Warner has that option enabled though. Check General Settings on the box (press the Settings button twice). Usually the drive will stop after 3-5 minutes of the power being turned off. Listen to see if you can hear it click off. If not, then it might be failing equipment. A bearing in the drive could be going bad, or even the power supply. You can always swap the box and see if that helps. Call them either way and let them know the issue...
Posted on Jun 10, 2009
  • 35 Answers
I had the same problem, it occurred right after windows installed sp2 and my laptop showed no dvd player with any program, I restored my laptop to the previous day before the update and it worked fine again, after that I just let windows update by itself and it has been a week and everything is fine, also in device manager open the dvd + sign and right click your dvd and click update drivers, if that does not work, right click your dvd, and then click delete, and then reboot your computer, laptop whatever and the computer will automatically recognize the player on startup and it will install again and hopefully that will get your drivers updated, do not worry about deleting the dvd player, it will reinstall all by itself, just have to reboot..thanks
Posted on Jun 02, 2009
Whiny dvr
sounds like the hard drive in the dvr is bad - they're easy to replace though - just follow the steps below.
  1. Step 1 Disconnect your DVR by unplugging any cables connected to it, including the power cable. Remove the screws located on the back of the unit that hold the top cover in place. There are usually two to six of these screws, depending on the model of DVR. Lay these screws in a safe place where they won't get lost, and slide the cover off.
  2. Step 2 Locate the hard drive. This is a rectangular metal unit that measures 3 1/2 inches wide. It is usually located away from the other hardware, often in its own bracket. There will be two to four screws holding it in place. Remove these, disconnect the cables connected to the drive, and slide it out of the system.
  3. Step 3 Check the label of the drive to see if it is IDE or SATA. It will say which one of the two interfaces it uses. Any replacement desktop hard drive of the same interface type will work in your DVR. Avoid using a laptop drive, because they won't fit and aren't designed for the high-stress environment of video streaming.
  4. Step 4 Place the new drive into the brackets, and replace the screws that were removed from the old one. Plug the data and power cables into this drive. They will insert the same way they came out of the old one. Once the drive has been installed, put the cover back on the DVR unit, and replace the screws. Hook the DVR back up to the television, and it will be ready to record.
Sep 12, 2009 | Cyberhome DVR 1600 DVD Recorder
Fan and hard-drive run all night and make lots of noise, keeping me up. I am not recording anything at these times, and it is not doing it's normal updates, it just runs and runs, like it has share-ware...
it seriously sounds like a bad ball baring in the psu, possibly needs maintenance or replacement if it;ls a whining sound like metal on metal then its ball bearings but also can make several other sounds, like clicking and even tapping, while uncommon for fan bearings and hard drive to go bad at sometime it's possable. but the prob seems to be fan related
Aug 20, 2009 | RCA DVR40 DIRECTV DVR with TiVo
Rear end whining
if you have a constant whine that raises pitch the faster you go, you have improper backlash adjustment in the differential (rear end), if you have a whooping noise that whoops faster as you drive faster then you have a bad wheel bearing, both can be the result of low fluid level in the rear end.
Apr 09, 2009 | 1999 Ford Explorer
I have a scientific atlanta explorer 8300hd dvr that I want to offload the recordings to either an external hard drive or a pc or laptop''
The 8300DVR has a feature built in for outputting redcordings to a VCR. To output to a PC you will need a TVTuner card with RCA inputs. Pinnacle offers several products including a Hard Drive backup. You will follow these instructions below, the VCR will be your computer.
Copy a Recording to a VCR Tape
1. Connect the VCR to the OUT 2 connection on the back of the Explorer DVR.
See page 12 for more information.
2. Make sure that a tape is in your VCR and that the VCR is set to record.
3. Press List . The Recorded List
screen appears.
4. Press Move Up or Move Down
to highlight the recording you want
to copy to the VCR. Make sure to select
a program that is not currently being
recorded.
5. Press Select . The Recorded
Program Options screen appears.
6. Press Move Up to highlight “Copy
to VCR.”
7. Press Select . The Copy to VCR
screen appears.
8. Make sure your VCR is properly connected
to your DVR outputs, and press
Record on your VCR.
9. Press Start copy A . The recording
begins copying to VCR tape. The
Recorded List displays the VCR symbol
for the recording that is copying to
VCR.
Note: You can watch the copying in
progress through the PIP.
Mar 31, 2009 | Televison & Video
Download movies from explorer 8300 hdc dvr to computer to burn
Not gonna happen. SA uses a proprietary file system. The USB is only designed for a keyboard or mouse when in a special diagnostics mode. The best you can do is use an eSata drive to the port on the back. IF you have the Mystro software on the box (most do) it won't even allow you to move programs to the storage drive until the box's drive is mostly full. Even then, I'm not sure that it gives you the option to choose what you want to offload.
You are best off buying a DVD burner (stand alone unit) or output the video to your PC. and re-encoding it to the file you want. Alternately, wait for the Series 4 TiVo with tru2way.
Sorry to be the bearer of bad news.
Mar 11, 2009 | Pioneer DVR-107D DVD±RW Burner
Constant whine when driving and wheels lock/skid in sharp turns
One way to track down the noise; since sound travels through metal its hard to pinpoint when driving in the car.
Jack all four wheels off the ground securely (preferably a lift) and run the car with the wheels spinning. Then, without dying, listen for the noise. The dealer can do it for you as well. But sounds like a bad differential.
Mar 06, 2009 | 1990 Subaru Legacy
Set top box and remote control
My remote wasn't working until I programmed it to work with itself ... (how odd it wasn't done already).
"CBL" button and ""OK/SEL" held down simulataneously for 3 seconds ... then "001" for the Scientific Atlanta. If the unit turns off, you're in business.
Feb 03, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
200 gb d2 extreme
The whining noise and the low clicking sound are indicate mechnical problem. My recommendation to you is to backup all the important data you have on it ASAP before it will crash and you will not able to do it !!!!
Aug 27, 2007 | LaCie (300950) 400 GB Hard Drive
Pioneer DVR-107D DVD±RW Burner Logo
443 people viewed this question
Top Pioneer Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Computer Links
David
David
Are you a Pioneer Computer and Internet Expert? Answer questions, earn points and help others
