The control panel is blank and I cannot find a diagram of the appropriate cables
We just had Konica 8020 copier dontated to our school. The contol panel is dark and the manual says to try reconnecting the "interface cable." There is no diagram of the interface cable, what it looks like or where it should be connected.
    President:
  • Office Equip... Master
  • 990 Answers
Hello sir; There have a dial on the control panel either on leftend or rightend of the control panel. just twist it ,going to appear on normal.
Posted on Apr 14, 2009
Konica minolta c654 control panel not turning on i change the control panel + cable + MFP + PRCB + SSD + DC POWER supply and the panel still not turning on
WOW!!! Did you check with a volt meter if the 120 was coming into the machine at the DC power supply, check the noise filters. Which power supply? Recommend ensuring 120VAC from the wall outlet is good. Surge protector is good. It also might be the fuser unit magnetic coil control. These class of copier uses a magnetic field to produce the heat. So when you replace the fuser a good part of that assembly stays with the machine. Which cable?
Feb 27, 2015 | Konica Minolta Office Equipment & Supplies
Konica 8020 3c50
if the code is C-3C50 you have a big problem!!!!!!!!!!!!
Sir/Mam,
You hit a serious code, noting can be done, this code requires a tech to come out and remove a chip inside the machine, which is then sent to Konica Minolta, then on to the US SECRET SERVICE since someone attempted to counter fit US currency!!!!!!!!!!!, until the US Secret Service determines what was done the machine stays inoperative , once what happen is determined tech will come out reinstall the chip reload firmware, and .NEVER EVER PLACE ANY CURRENCY ON A COPIER all the machine now a day have Bank Note chips..
You machine is also a legacy Konica machine so I don't know what Konica Minolta technician will do.
Apr 05, 2014 | Konica Minolta Office Equipment & Supplies
Replacing picca fuse on Konica color 8020 fuser unit
Not recommended because the fuser unit has reached end of life, that is why its displaying the indication,
Feb 05, 2014 | Konica Minolta Office Equipment & Supplies
Blank screen
control panel may need to be replaced have a tech come or it could be a control board, or the firmware is bad.
Jan 28, 2014 | Konica Minolta Office Equipment & Supplies
KONICA 8020 ERROR CODE 31C-M
yes this is a fiery issue, i am not familiar with them but i would think that its a pcb issue, the firey fan probly overheated the cpu and now its bad. its not nessisary to use the fiery is it?? i would use it without it.
Nov 28, 2011 | Konica Minolta Office Equipment & Supplies
Free manual
You can download your manual from Konica here.
Apr 05, 2009 | Konica Minolta Office Equipment & Supplies
Scaning
i down loaded the manual.
thanks
Can you give me step by step instructions on how to install the finisher for my konica minolta 8020. I bought the copier and decided to get the finisher and cannot figure out how to set it up.
Listen before I devolve my secret are you a dealer or an end-user, I am a konica dealer and I would hate to take food out of my dealers mouth cause an end-user refuses to call a dealer for help, and where is your machine located.
Mar 06, 2009 | Office Equipment & Supplies
Connecting my computer directly to konica 8020
You can hook the copier directly to your computer using a USB cable.  You can purchase one at any computer store.
Oct 20, 2008 | Office Equipment & Supplies
Konica 8020 color copier: image transfer roller unit needs to be replaced , Replaced but it is not able to recognise the change
Because you have to go into service mode and clear the counter.
Utility then meter count then stop00 stop01. then touch counters then touch life clear the transfer roller.
Sep 08, 2008 | Konica Office Equipment & Supplies
41 people viewed this question
k24674
jasbo
jasbo
