Question about Maytag MER6772 Gemini Electric Kitchen Range
Noise while in clean mode
I put my bottom oven on clean mode and it is making a loud vibrating noise. Model - MER6770AAB Gemini I immediately cancelled the cleaning. What should I do?
  • lyda_faye Apr 14, 2009
    No it doesn"t make noise when it bakes.
  • 242 Answers
Sounds like the fan is hitting something or the blade is loose.
does it make the sound on a covection bake or speed bake?
Posted on Apr 14, 2009
  • Phil Brantley
    Phil Brantley Apr 15, 2009
    since there is no fan or any other moving parts in this model it must be the current through the element/system , in self clean both elements run at MAX to burn everything inside unit and some elements may be a lilttle noisey. you may be able to tell which one it is lower or upper by listening with the door open and selecting bake then broil.
    Let me know if you have any questions.
    Phil
Purchased microwave in 2005, just stopped heating and now its making a loud noise
if the loud noise is like a vibrating noise then it sounds like the high voltage diode.
Mar 23, 2010 | Kenmore 63252 Microwave Oven
Maytag gemini model MER6770AAB - F1-2 error
Check the sensor for correct ohm reading. If it is good, replace the control. It should read 1143 at 100 degrees
Sep 18, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Spining makes noise and machine vibrates a lot
its a simple solution just remove the brown colour clamp at the bottom of the machine with a screw driver
Jun 03, 2009 | Whirlpool Washing Machines
Some panel in my Neff electric oven is making a loud vibration noise on fan mode. The vibration noise stops if the top part of the front surround (with door open) is pushed in. There is no vibration on...
Update: after using the oven with the grill instead of the fan, the problem sorted itself. With the heating and cooling, obviously some panel had not settled correctly and was causing the vibration. It hasn't happened again so far.
May 19, 2009 | Neff Ovens
Loud noise like tray vibrating. does not cook.
Call GE answer center 1-800-626-2000 ask for tech help, Have your Model # orr your data plate ready.
May 09, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Fan making loud noise
Hi
does the noise start as soon as you turn the fan oven on?
does the noise stop as you turn off?
just depending what make and model you have there is two fans
in it 1 is the fan motor inside oven at back and other
is the cooling fan which is at top of oven .you just need
to find out which one it is and just replace . then should be back to normal
regards dan
Mar 19, 2009 | Belling XOU174 Electric Single Oven
Loud noise
If you mean a loud buzz that cuts on and off as the oven works, it is probably the outer metal cover vibrating as the magnetron powers up and down. Try holding/ pushing/ poking the metal cover while the oven is working, if the noise abates or goes away, this is the problem.
You may get relief by simply tightening the screws securing the cover, if not, maybe a little careful insertion of a thin strip of cardboard or similar, at the point the vibration occurs, may dampen it. Good luck.
Jan 18, 2008 | Sharp R-254 Microwave Oven
Maytag gemini MER6770AAB
im guessing they locked after a self clean mode. what your gonna have to do is replace the door latch.
Jan 23, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Maytag MER6772 Gemini Electric Kitchen Range Logo
136 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
