Question about Optics
When veiwing always see double image
Double image
  • Anonymous Apr 18, 2009
    There is always a double image, one a little above the other. My best analysis is that the two barrells are out of alignment. I see no way of adjusting. This is a new, unused glass, although opurchased some time ago.
  • 7 Answers
Up close to the eyepieces around the barrels are small screws that you can use to "collaminate" your binocs. The screws aren't meant to be accessed by the owner and most manufacturers cover them up with the material that surrounds the binocs. Of course the binocs in their current state are useless anyhow, so I wouldn't hesitate to peel up the material to look for the screws. If you do it carefully, you can reseat the material anyhow. Then once you locate the small screws, put the binocs on a stand or a table outside. Focus on something far away using one eye. Then using both eyes, you adjust the screw on the other eyepiece while looking through the binocs. Adjust until you get a single image. You can use loctite, or nail polish to "glue" the screw in the final position if it is really loose.
Posted on May 09, 2009
Why is there just a black screen in eye view?
sir,
can play your cassette? if the picture is clear in play back mode,then there may be problem with the image sensor (CCD) in the camera,open the camera, measure the voltage at the CCD board if the voltage is not correct check the fuses on the mother board.
Feb 06, 2016 | Sony Handycam DCR-TRV250 Digital Camcorder
Double image on the first copy only
try to reset your printer. Turn off, remove the power supply from the socket leave it for 30 mins and turn it on again. try one copy at a time
Sep 21, 2007 | Office Equipment & Supplies
4gb micro sd card wont upload or show images
hi buy a card reader cost about $5 dollars on E/BAY plug it into youre mac & put the sd card in & hope it all works ...cheers..
Apr 06, 2017 | PNY Electronics - Others
When I try to veiw the pics on the memory they it has lines going through the pics. ? Ive even tried veiwing the memory card on computer and looks the same.
Hi, Since the lines are on the photos even on the computer that would indicate that there's a problem with the camera's sensor (what records the image) and not the lcd on the back of the camera. The sensor could be replaced but often times the cost of the sensor plus the labour costs more then the camera.
Jun 20, 2011 | Olympus Cameras
I mostly just veiw pictures on my computer and send them via email. The image mode on my camera is set at 4000 X 3000.Which is a size problem when I go to email them . Should I change the setting down on...
Always shoot at the largest size your camera can handle. When it's time to e-mail, just right-click on the picture file and from the menu that pops up, choose e-mail recipient. Another dialogue box will open up and give you the choice to send large, medium or small images. Choose one and your e-mail opens with your picture(s) attached and your originals untouched.
Jan 23, 2011 | Nikon Coolpix S3000 Digital Camera
I put the 1.5 erecting lens in, however, I am getting a tilted veiw not an upside down one without it How do I get the veiw totally upright?
Turn the diagonal, and the image rotates. Using the scope for star gazing it does not matter. Normally an astronomical telescope shows an upside down image--- no up or down in space. The erecting prism is only used for terrestrial viewing as the prisms inside are probably NOT multi-coated.
Sep 28, 2010 | Bushnell 3" Reflector Telescope w/Talking...
Red rainbow on top half of screen and double images
ch the stk 392-120 try to set the conv.or try to auto set conv. if work then ok if not work you and stk392-120 or 150 you need a sevice man for that.
Jun 02, 2009 | JVC AV-48WP30 48" Rear Projection...
Image appears double and slighly off when viewing
I was having a double vision problem with my Barska 10-30X50 zoom, 195FT/100YDS binoculars. One image was always higher than the other. This was tolerable at low zoom, but was further aggravated the more I zoomed in. I found that I could grasp both barrels and twist them in opposite directions (one side up, the other side down) and force the two images to merge--but that was a strain and an unpleasant viewing experience. As an experiment, while looking through the binoculars, I grasped the far end of the right barrel and twisted it on its axis. Nothing happened at first, but after a certain amount of resistance it began to rotate independently of the body. Lo and behold, this shifted the barrel's axis, and the image for that eye moved vertically! I turned it until the two images merged, and now I'm thrilled to say that the problem is solved! I don't have a clue if this would work on any other brand or model, but it's worth a try!
Apr 06, 2009 | Tasco Sonoma 16-840WA-1 (8x40MM) Binocular
Double image
have you done convergence? and is there a auto focus?
Jan 07, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Double Image
It's may be the video cable from the PC. I had the exact same problem with my Epson projector today. Treat y
Oct 06, 2006 | Epson PowerLite 5000 Multimedia Projector
Optics Logo
573 people viewed this question
Top Optics Experts
james laughton
james laughton
ray gallant
Are you an Optic Expert? Answer questions, earn points and help others
