Question about Sage Instant Accounts 8.0 (013604ug)
Invalid Path error
I get this error when trying to run Financial reports in Sage Instant Accounting version 10:
C:\PROGRAM FILES\SAGE\ACCOUNTS\REPORTS\\*TB.SRT contains an invalid path
No matter what financial report I try to access I get the same error.
I get this error when trying to run Financial reports in Sage line 50 financial controller verson 10: C:\PROGRAM FILES\SAGE\ACCOUNTS\REPORTS\\*TB.SRT contains an invalid path No matter what financial report I try to access I get the same error including audit trail. My computer is window Vista. Please help me and also let me know how much is it cost for on line chat?
Thank you
from selvi
Posted on Aug 27, 2009
  • selvi989 Aug 27, 2009
    I am not happy with your solution. You must instruct me how to change the directory or path.After paying $12.99 I got only general answer and not in detail.
I am trying to change the financial year end date in Sage Instant Accounts??
You can only do this is Sage 50 but you can get it changed by someone who has Sage 50 with the same version number as your instant. They can back up their data restore your date change the year and then backup and you can restore it on your computer and they can restore their data. NB they must be on exactly the same version.
Dec 11, 2010 | Sage Instant Accounts 8.0 (013604ug)
Hi all I am gettig the following with my sage line 50 v7 'sage report says unable to connect to data sourc, check configuration' I then get a system error coded 2 Its on windows 98 Can anyone...
Try removing Microsoft.net framework 3.5 sp1 from add remove programmes has known conflict with sage. If this does not work then try removing the .net framwork 3.0
Oct 05, 2010 | Sage Instant Financial Suite v8.0 CD Win...
When I try to print reports in the Financial window on Sage Line 50 I get an error message C Prog Files x86|AccRep\*TB.SRT contain invalid path. how do I fix?
find the TB.srt file and copy it into location should solve this. You may also have a problem with profit and loss and balance sheet as these are normally held in same location
Feb 09, 2010 | Sage Instant Accounts 8.0 (013604ug)
C of A with dimension for cost centres
You need to make sure the Accounting program is designed for multiple locations. If it isn't your going to run into headaches trying to trick it into doing so.
Oct 10, 2009 | Sage Instant Financial Suite v8.0 CD Win...
C:\program\SAGE\ACCOUNTS\REPORTS\\*TB.SRT contains an invalid pat
This message usually comes when the target location is not there or is renamed OR the address is wrong. Open My Computer, and go to the address you gave. Look if there is the file named *TB.SRT.
And by the way... the address you gave was "
C:\PROGRAM\\SAGE\ACCOUNTS\REPORTS\\*TB.SRT" BUT I believe that the address should be "C:\PROGRAM\SAGE\ACCOUNTS\REPORTS\*TB.SRT".
It is not possible that the address contains 2 slash (\\) repeatedly. Open the file by going to the My Computer OR by opening the software and by locating the file manually from there.
live chat assistance costs $19.99. And $12.99 for one time e-mail premium support.
If you have a registered product then I would suggest you to visit:
http://support.sage.co.uk/default.aspx?page=1
There you might find a solution at no cost.
Please inform if your problem is solved or not. And please rate if you found the above info useful.
Aug 28, 2009 | Sage Instant Accounts 8.0 (013604ug)
Email Remittances - Report Designer Problem
Sage Line 50 Addpurch Utility
In Sage Line 50 V5, you could only produce remittances for the
supplier accounts you had set up in your Sage Line 50 program.
The information that appeared on your remittances was taken
from the supplier ledger.
In newer versions of Sage Line 50 you can produce remittances for suppliers
who do not have a corresponding supplier record. This allows
you to produce free-format cheques for one-off payments. To
enable you to produce free-format cheques, Sage Line 50 no
longer takes the information for remittances from the supplier
ledger. This means that you can produce remittances whether
there is a corresponding supplier record or not.
If you want to include additional information from your
supplier records on your remittances, for example bank sort
codes and account numbers, you should convert the layouts
you require using this utility.
Note: This utility is installed automatically into your
Sage Line 50 program directory when you install Sage
Line 50.
>> To use the Addpurch utility
1. Open a Command Prompt by clicking on to your Windows Start Button
selecting Run, then type the word COMMAND and click on to OK.
From the command prompt (for example, c:\windows\desktop>) type cd\ and
then press ENTER.
2. At the c:\> prompt type cd "Program Files\Sage Accounts\layouts"
and then press ENTER.
The prompt should now read c:\Program Files\Sage\Accounts\layouts
Note: If your Sage Line 50 program is installed in a different
directory replace the above instruction with your own directory
name. The directory path can be found within your program by
clicking on to Help and then About and choosing the System
Information Tab. Your layouts will be held on the same path
as your data directory.
3. Before you can convert your remittance layout you will
need to save this with a new filename. (maximum of 8 characters).
For example, to rename one of your existing layouts from
the c:\Program Files\Sage\Accounts\layouts prompt type:
copy remita4.sly newrema4.sly
Jul 07, 2009 | Sage Computers & Internet
Font size in Sage Financial Suite
You cant, if you change the windows display font size this will make some of the fonts bigger in Sage but not all and may make some areas of the program unreadable
Sep 10, 2008 | Sage Instant Financial Suite v8.0 CD Win...
Sage line 50 nominal reports.
reinstall ODBC Drivers usually found in your sage data directory
Jan 16, 2008 | Sage Instant Financial Suite v8.0 CD Win...
Computers & Internet Logo
1,952 people viewed this question
Top Sage Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
Clinton Daley
Clinton Daley
Are you a Sage Computer and Internet Expert? Answer questions, earn points and help others
