Last night my son was riding his taotao 125 he stopped started backing up, while the 4 wheeler was going backwords he slammed in forward and I heard a loud pop then the 4 wheeler would not move forward or reverse.
SOURCE: kx 125 1992 wont start
sounds like the rings are fried and needs a new piston and rings.. for an 80 there about 110 bucks for the whole kit
SOURCE: 2003 yz 125 clutch
This sounds like dirt and grit in the oil is causing the clutch to grab. Change the gearbox oil. Ride the bike for a couple of hours using the clutch often. Now drain the oil again and put in fresh oil. This will flush out the dirt and grit. Use 10w40 motor oil. Stick with the major brands; Pennzoil, Quaker State, Mobil or Shell. Do not use synthetics or oils with "special" additives.
Other possible causes are > a need to adjust the clutch lever for 1/4" free play at end of the lever > warped clutch plates or friction plates > Clutch has been worked on and assembled wrong > low oil level in the gearbox > frozen clutch hub bearing > Incorrect clutch cable being used.
Please post a comment after the double oil change. The 2x oil change is a cheap way to eliminate a possible cause and hey, it isn't gonna hurt anything. If you still have the problem I can help with a clutch rebuild.
SOURCE: cr 125 02 wont start.makes wooosh/bang noise
you may want to check your card settings and the compression itself as the woosh and the bang noise means that the gas is burning, but not completely combusting.
hope this helps.
Testimonial: "foud that the piston and ring failed "
SOURCE: I have older Suzuki ATV 2wd. It won't start, the
you probably have a bad neutral switch, if it doesn't read neutral the light won't come on and the vehicle won't start unless it's in the neutral position. try push starting it in gear and see what happens.
SOURCE: I have a 2003 yamaha kodiak ATV, reverese indicator light stays
MAKE SURE THAT FORWARD AND REVERSE ARE FULLY ENGAGEING AND DISENGAGING
