Question about Lexmark X5470 All-In-One InkJet Printer
My printer keeps on jamming, says I need to re-align the paper, which i've done but the paper won't feed through. Someone please help. Thank you! Anna
My printer is jamming whenever I try to print. It seems to get stuck on the right hand side of the fees. It says to re-align the paper which I do but it still gets stuck. Please help. Thank you! Anna
  • 37 Answers
Try cleaning all the rollers with 90% rubbing alcohol, as well as any tight spaces on the printer... Use Q tips. Also inspect rubber rollers for wear and replace any worn ones (they're not expensive).
You may also have some paper jammed deep in there. taking the printer apart and cleaning everything with rubbing alcohol should solve that.
Posted on Apr 19, 2009
Canon pixma ip1900 paper jam
Hi
Here's a few things you can try :-
1. Blow it out with canned air. make sure there are no bits of paper or dust in the paper feed area and in the front access area that could be causing the jam.
2. Verify that the cartridge carriage moves to the service area when the front door is opened (as if to change tanks)
3. Verify that the timing belt, drive belt, gearing and rollers all look normal.
4. Take the network out of play when doing the initial troubleshooting
5. With the computer off, unplug the printer's power cord and USB cord for about 3-5 min
6. Completely uninstall the printer's driver and software. Then reinstall the printer's drivers only.
Retry after each step.
Also if your Canon printer has fax capabilities, and you are getting a false paper jam error, the problem is easy to fix.
Open the scanner lid.
You will see a white strip on the left, under the lid.
There are also two small, white tabs near this strip.
Gently pull on each tab. You should feel a small "click" on the tab that is jammed.
This fixes the problem.
I suspect that when previously scanning something like a book page, one of these tabs got pushed the wrong way.
Hope it will help.Also you can get back to me if you need further assistance.
Thankyou.
Dec 05, 2011 | Canon PIXMA Office Equipment & Supplies
Please help with cannon PIXMA MP150 printer problem, when trying to print, It reads that paper is jammed but I've checked several times and no paper is jammed. Printer will not print due to this...
Hello and Welcome to FixYa!
Paper jam means their may be small bit paper jam in side
, actually there are some "micro sensors" that detect a paper jam. There will be tiny piece of paper inside those sensors, thus tripping the sensor and paper jammed keeps coming up.
To solve this first of all Open printer cover and check to make sure no paper or foreign objects obstructing the printer feeder
, If you become sure that now really there is no paper, dust or foreign objects then Turn the printer off, and disconnect the AC power-cable. Open the printer cover & now give the printer a "blow-job" by compressed air.
If still problem exist then best & final option is to just contact to any Canon Printers service provider.
I hope this solution helps you
Thank you for using FixYa!
Aug 04, 2011 | Canon PIXMA MP150 All-In-One InkJet...
I've had my brother mfc-7440n for over 2 years and it's been working great until this past week. Now, it has a paper jam every single time I try to print anything, causing me to have to remove the...
85% of paper jams are caused by worn rollers . The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease. If you plan to keep your printer,
Replace the pick-up and feed rollers.
Metal Tab Separation- Pull out your paper tray and examine either end where the paper sits in. If any of the corners are held down by metal tabs, this is your paper feed system. Chances are, you only have one rubber roller or one set of rollers arranged along side of each other. Reach in where the tray goes and feel up. You should feel some rollers. They might be completely round, or they might be shaped like a half moon. Clean whichever part of them you can with the solution, and this should stop your paper jams. It might be necessary to turn them, but don't force them if they don't move freely.
Pickup Roller and Separation Pad-
If your printer uses this paper feed system, you should see a small piece of flat or slightly curved rubber or cork. It would be towards the end of the paper tray, or deep inside the paper loading cavity on top loaders. This 'separation pad' rubs against the paper feed roller, so if you find the pad, you've found the roller. Clean it and your jams should stop.
Three Roller Paper Separation System- Pull your paper tray out, and look for a roller on either end of it. If you find one, clean it. Then look inside the printer where that roller would rest with the paper tray inserted. You'll find another paper roller there. Clean this one also. Finally, look further back or closer to the front of your printer (depending on which way your paper feeds) to find another roller or set of rollers. Clean all of these, and your paper jams will go away
Jul 10, 2011 | Brother MFC-7440N Laser Printer
Paper feed issues when there is no Paper jam. All the rollers move when the printer tries to feed paper. It'll feed about and inch and a half of paper and then stop showing a Paper Jam.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 19, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
Printer keeps on jamming paper
Dear all,
I will try to help you. Paper jam error may be caused by some possibilities. So, please notice this indication:
  • If the printer status is READY immediately after Power ON then Paper Jam Error message appears while feeding the paper: Sheet Feeder Unit is faulty or any other material (such as broken paper) present inside paper path blocking paper end to reach paper feed sensor.
  • If Paper Jam Error messages appears immediately after Power ON: Paper feed sensor or logic board is faulty
Corrective action:
  • Remove the material from paper path
  • Replace Sheet Feeder Unit
  • Replace Paper Feed Sensor / Logic Board
Please rate me as Fixya if you find this useful for you. Thanks.
Source:
Canon Inkjet Printer Forum
Re
Sep 01, 2008 | Canon Pixma iP2600 Photo InkJet Printer
Carriage Jam
Carriage jams that constantly occur are due to something in the path of the paper or a dirty feed roller. I would inspect it very carefully for any type of ware on the rollers or sticky rollers or anything that could interfere with the path of the paper. Could be at one point someone tried to print labels and one got stuck in there and was never cleaned properly.
Another thing could be something broke off and the feed guide is out of alignment.
Jul 13, 2008 | HP Officejet 7210 All-In-One InkJet...
Lexmark X5470 All-In-One InkJet Printer Logo
142 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
