Question about Refrigerators
Freezer is cold and refrigerator is hot. Frigidaire 18.4 cubic feet pn 240208009
  • 1 more comment
  • joediver Apr 14, 2009
    yes and has heavy frost in freezor
    removed freezor back panel and foun loose single black wire at connector could this be the heating element
  • Phil Brantley
    Phil Brantley May 11, 2010
    Does the fan run in the freezer?
  • 242 Answers
You have a defrost problem , unplug unit , empty freezer and remove the back panel the ice is on , with a hair dryer or similar item defrost the entire cooling coil until no ice is present , you have to get the ice out of the foam pieces that shoot air down to the refrigerator , there will be water leaking in that section as well put a towel in the lower section.
after getting the ice out of everything you will have about a week until it does this again.
things to check- your heating element under the cooling coil , you can ohm it out with a meter or look for signs of it burning up.
the terminator- its located in the freezer where the freon lines come in , it clips on the freon line , its 1 inch round , make sure its not blown or the wires have not came out.
and then your defrost timer , it is usually where the settings are in the fresh food department , you can click it into defrost and see if it runs the heater to test.
Let me know if you have any questions
Phil
Posted on Apr 14, 2009
  • Phil Brantley
    Phil Brantley Apr 14, 2009
    You got it with no parts good job!
    Make sure to get all the ice out or it will continue to build.
    Phil
How many cubic feet in model FRT18SJGW2?
Katy,
It is going to be in the neighborhood of 18 cubic feet. Most manufacturers will put the cubic foot size in the model number but it can be a little smaller and it could go a little higher like 18.2 or 18.3 cubic feet and they would still call it an 18. Hope this helps!
Jun 26, 2015 | Frigidaire Refrigerators
What size (cubic feet) is the Frigidaire Freezer Model # FFU17FC4CW0
I am going to guess that it is going to be around 17 cubic feet since that number is in the model number, at least that is how current models are labeled. Here is a link to a copy of the owners manual if you need it.
FFU17FC4CW0 FRIGIDAIRE FREEZER Manual
Here is another link to a page where I looked up the age of your unit and it will give you an idea where to look that up as well.
Appliance411 Service How old is my appliance Age finder date of... Hope this helps!
Feb 18, 2015 | Frigidaire Freezers
How many cubic feet is a Frigidaire frt21tng 0
Hello;
My name is Peter. I am a retired field service refrigeration technician.
The cubic feet is in your model number. In your case it is a nominal 21 cubic feet. It can be 21.2 cubic feet.
Sep 04, 2014 | Frigidaire Refrigerators
What is the cu ft of Model FRT21IL4FW3 Freezer space?
Easiest solution is to measure the inside dimensions in inches, tall, width and depth. Then multiply the three dimensions t x w x d = cubic inches. To get cubic feet then divide the above answer by 1728 and the result is cubic feet..
For instance if the fridge is 60 inches tall x 24 inches wide x 18 inches deep; the answer is 60 x 24 x 18 = 25,929 cubic inches... 25,920 divided by 1728 = 15 cubic feet.
Jul 12, 2014 | GE GSH25JSTSS Stainless Steel Side by Side...
How many cubic feet is lffu1465dw5?
Good Afternoon Friend,
I understand you want to know how many cubic feet your Frigidaire freezer, model# LFFU1465DW5. Per the specification manual, your freezer is 13.7 cubic feet. Hope this is helpful.
-Best Regards-
WP
Jun 19, 2014 | Frigidaire Freezers
WHAT IS THE CUBIC FT?
Good Morning Friend,
I understand you are looking for the cubic footage on your Frigidaire refrigerator, model# FRT15GB4. Per the specifications manual, your appliance is 14.8 cubic feet. I ask that you please follow up with a comment on the post, at your convenience, to advise of further questions. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire FRT15G4B Top Freezer...
I need to know the cubic ft of my old Whirlpool fridge. The model# ET18JKXDW01. Serial# 18TFA95. Thank you.
The first two numbers in the model number says what the cubic feet is, its 18 cubic feet
Gene
Aug 10, 2011 | Magic Chef CTF2125 Top Freezer...
FRIGIDAIRE MODEL FRT18B1BWO WONDERING HOW MANY CUBIC FEET THE REFIRGERATOR IS
Good day,
The total cubic feet are usually coded in the model number. In your case it would be 18 cubic feet.
Oct 19, 2010 | Refrigerators
How many cubic inches? Frigidaire GAllery Powersource Pluse FRS26zgh purchased 6/00
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote that tells you how to figure out how big your refrigerator and/or your freezer is...
New Refrigerator Size or Refrigerator Cubic Feet
Heatman101
Sep 10, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Refrigerator not cold enough
yes, if theres a warranty on it, call the place you bought it and have them send out a service tech. you should not have to pay anything.
Apr 22, 2009 | Frigidaire FRT17G4B Top Freezer...
Refrigerators Logo
192 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
