Question about Dryers
Clothes dryer wont heat up
I already changed the heating unit at the back it was very easy o though that was easy but it still wont heat up
  • marksneyd81 Apr 15, 2009
    the element is getting power dont know about the high limit thermostat where would it be and how do you fix it or change it?
  • Phil Brantley
    Phil Brantley May 11, 2010
    have you checked or changed the fuse on the element or the high limit t-stat?
  • 242 Answers
On the element case left side there are 2 componets the upper is the high limit fuse which will open the heater wire when high temp is reached for saftey , it should ohm out with a meter , if you dont have a meter bypass this fuse by tieing the 2 wires together and then try running the dryer and check for heat.
the lower componet is the high limit t-stat which should be working but if the fuse above it has went out you should replace the fuse and this t-stat , they come in a kit together here is the part number , they are easy to find online.
279769
Posted on Apr 15, 2009
  • 116 Answers
Is there an over temp switch bad? or power to element?
My dryer ia crosley and wont heat,the clothes wont dry,she activate but dont heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;'
Jul 22, 2011 | Dryers
My maytag gas dryer model MGD5600TQO wont heat, changed thermostat already, what next, everything else works.
heatman101
Jul 11, 2011 | Dryers
My samsung clothes dryer wont heat up.
heatman101
Apr 03, 2011 | Dryers
My dryer wont heat up and dry clothes
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 20, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My Maytag Clothes Dryer quit heating?
unplug the unit and take the back off.
Apr 13, 2009 | Dryers
After one 80 minute drying cycle, the clothes are still just as wet and the dryer lint in the lint screen is wet. It takes 3 cylces to dry clothes. I've already replaced the heating element. The dryer vent...
Depending on the make and model, you should have a temperature sensor somewhere on the heating element box. That may be malfunctioning. They are usually less that $10 USD and replacement is real easy. Simply unbolt the old one, pull the two wire from it, put the wires on the new one and rebolt it to the heater unit.
Mar 29, 2009 | Dryers
Kenmore heavy duty clothes dryer will not heat
REMOVE THE BACK AND CHECK THE HEATER FUSE AND THE HEATING ELEMENT-MIKE
Feb 25, 2009 | Kenmore Dryers
Hi I am trying to clean my drain unsder my washer. I do not know how to pull the cover off.?? It appears I need special alan wrenchs for two little screws..?? any ideas??
Though the idea of repairing a clothes dryer can be pretty intimidating, the truth is that some types of repairs are surprisingly easy. Yes, dryers appear to be built like huge, impervious metal boxes, but they are typically pretty easy to open and relatively simple to fix.
As shown at How Clothes Dryers Works, a clothes dryer has a motor that turns a big drum containing the clothes, a heat source for blowing warm air into the drum to dry the clothes, and controls for operating the motor and heat source.
Some dryers have an electric element to do the heating while others utilize a gas flame; the latter must be vented.
Clothes dryer problems generally occur because the heat source doesn't heat properly or the motor fails to turn the drum.
If a gas dryer doesn't dry properly, the first thing to check is the pilot light or igniter--it may not be lighting the burner. The second thing to check is the dryer's vent-if it is clogged with lint, the heating system won't work properly.
Pay attention to basic safety measures when working on a dryer. Always unplug the dryer, and turn off the gas supply to a gas dryer at the appliance shutoff valve.
As with most appliances, maintenance will keep your dryer purring. Clean the lint trap after every load, and clean the vent system once a year.
Dec 13, 2008 | Whirlpool LTE6234D Top Load Stacked...
Dryers Logo
129 people viewed this question
Top Dryers Experts
