Question about Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
Will not spray water
Hoover steamvac is only 2 years old, used only 4 times and now will not spray water or solution.
  • 61 Answers
After the last use did you run a FULL tank of HOT water throught he machine to clear the lines and the pump? If not the soap has clogged one of the two. If it is the lines simply remove them (one at a time is less confusing) clear them and all is good. If it is the pump (white L shaped object back left corner of machine as you face it) you will have to go to a local vacuum repair shop and order the part.
Posted on Apr 15, 2009
I have never used the upholstry attachment and now I need it and it won't spray. I followed the instructions - (let it suction for about 15 sec. and then try spray) well that didn't work. It **** and the brushes are rotating so now what?
Posted on Jun 11, 2009
I have found that the plastic hoses from the solution tank to the base have kinked on mine. After replacing them with a more pliable hose, the solution now flows.
Posted on May 17, 2009
How doI hook up furniture/stairs attachment
Hoover Steamvac Spinscrub - How To Attach Hose and ...
? 2:54
https://www.youtube.com/watch?v=XTgoEezUlRs
Mar 13, 2011 - Uploaded by Doug Weeks
... spin tool. Used for stairs and stains etc. hand held. ... Hoover Steamvac Spinscrub - How To Attach Hose and Spin Tool ...Every time I attach the upholstery and then turn the vacuum on, water begins to leak from the bottom.
Hoover SteamVac Connecting Hose & Tools F5915900 ...
? 1:41
https://www.youtube.com/watch?v=heAeez1YlFc
Nov 23, 2011 - Uploaded by HooverVideoGuides
How to properly connect the hose and tools ... Hoover VacuumVideo Guides ... I cant get the water to come out the water isnt coming out the spray part to scrub my furniture ... Get Best Price for Hoover SteamVac Carpet Cleaner here ... for the love of god when not using the hand tool where on the machine ...
Hoover SteamVac Connecting Hose & Tools F5912900 ...
? 1:41
https://www.youtube.com/watch?v=fPU9pXgNo98
How to properly connect the hose and tools ... Hoover SteamVac Connecting Hose & Tools F5912900 F5914900 F591... ... Hoover Vacuum Video Guides .... Hoover Steamvac Spinscrub - How ToAttach Hose and Spin Tool ...
Jan 09, 2016 | HOOVER COMPANY Steamvac Deluxe
Clean inside of brushes
Greetings from GoVacuum,
The Hoover SteamVac's are notorious for this exact problem. There are several things that can be causing this probelm.
First, what you'll need to do is take the brush block out of the machine. To do this there are 4 clips on the brush block. You will need to turn the machine upside down, and pull down on the brush block to where it won't pull out any farther. There are 4 clips, 2 on top, and 2 on the rear of the brushes. (See picture, I have circled one of the clips in red). Simply press these clips at the same time, and pull the brush block out of the machine. I'd say that 60% of the time that I see this problem, the main issue is that the brushes just need to be cleaned. If you have pets in the home, a lot of the time the pet hair will just be lodged inside the brushes, will prevent them from spinning. Use a pressurized water hose (garden hose2_bing.gif with spray nozzle is ideal) and spray each brush with water to dislodge any pet hair. You should be able to get these brushes spinning when you spray them. Spray each brush until the brushes are spinning pretty fast. Re-insert the brushes into the machine, and test to see if the cleaning has fixed your problem. If your brushes still wont spin, you may need to replace the brush block itself. Check the model number on your SteamVac which will be located on the back of the Steamvac on a stick with model information. GoVacuum.com does carry ALL of the SteamVac Brush Blocks on our site if you need to buy a new brush block.
Here's a picture on how you can remove these clips;
If this does not fix your problem, there are a few other problems that could be causing this.
Feel free to call me, or email me if you have any questions about your SteamVac, I'm more then happy to diagnose the problem overthe phone / email.
Chris Jones
GoVacuum.com
chris.jones@govacuum.com
1-866-468-2288
Nov 27, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover steamvac won't spray water/cleaning solution
Clogging of the pump that sprays water/cleaning solution is very common in Hoover and Bissell Steam Vacs. Try running a cycle of 1part vinegar or CLR to 3 parts warm, distilled water through the vacuum pumps. The heads get clogged with soap and the water pumps get clogged at the opening of the flash heater due to minerals in hard water. If you want to extend the life of your steam vac, don't use the heater unless you are using distilled water. This can get expensive, so I recommend not using the heater.
Sep 11, 2009 | Hoover F7431-900 SteamVac Vacuum
My hoover steamvac spot doesn't spray
the pump has to prime first ,put water in the solution tank an yurn on and keep the trigger pulled till it sprays.if that don't work take it back
Apr 28, 2009 | Hoover F5505 SteamVac Spot Vacuum
Hoover Steamvac Upholstery Cleaner will not spray water.
In my case when I pulled the trigger on the upholstery hose I barely got a drizzle of water. After looking at the parts online I realized the valve assembly on the spray end of the hose consisted of a black valve housing, with an inner spring and a white plunger part that sprays the water. The white plunger should move noticeably when the trigger is pulled. Since all 3 part of that valve assembly were replaceable I decided to try and take it apart. First I removed the 2 silver screws on the cover of trigger end of the hose and lifted out the valve assemble. The white plunger part was basically frozen in the black valve assembly. Tried pulling the white plunger out by hand wouldn't budge. So I use a pair of plier and pulled the white part out. Sure enough the whole inside was caked with what appeared to be old dried cleaner. I rinsed the spring and the white plunger. There were o-rings on the white plunger, I did not remove them but used an old tooth brush to clean out around them then reassembled. The white plunger now freeing slides a noticeable distance when the trigger is depressed and getting a large V shaped spray pattern. Lesson learned, I will now make sure I run plenty of plain water through the hose to rinse all the cleaner out after using it .
Jan 12, 2009 | Hoover F5832-910 SteamVac Supreme Vacuum
Hoover F5858-910 doesn't spray water
Hello dc42 & osuguy101. I suggest using a cleaning solution, 50/50 vinager/water, in the fluid tank to clean the ports. #2 Unit may have a fluid pump problem. Please update me on results.
Sep 26, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
The attachment to clean furniture will not spray out water this is the first time we have used this just out of box. Also the detergent will not mix with the water
If you can see the cleaning fluid at the nozzel yet the it does not spray than the nozzles are clogged with dried soap. You can soak the the sprayer in a small bucket over night with a cleaning solution like CLR also used to break up hard water stains, dried soap & cloged shower heads. http://www.drugstore.com/qxp81915_333181_sespider/clr/cal__rust__lime_remover.htm
Here is a parts site for your Hoover.
http://www.thehooverstore.com/F5903.html
Jan 19, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Hoover f5520 steamvac duo upright wet washer
Your problem is inside the vacuum hose where they have installed a small coiled hose that carries water to the smaller power head for upholstery. After taking this apart I found the inner smaller coiled hose was broken at 2 different places. A very poor design and poor quality material. The hose looked like it was rotted. This could be from old detergent left in the line or maybe the wrong detergent. A job to get it apart but if you remove the three screws that hold the side plate over the electrical you can block that hose off and the machine will work on floors only as the water to the power head is terminated.
Nov 11, 2007 | Hoover F5520 SteamVac Duo Upright Wet...
Hoover steam cleaner
Is it spraying and sucking up ok? Check the filter inside the dirty water tank, it needs a 1/4 in. gap from the top to the top of the filter. If it isn't spraying out a good stream along the bottom, maybe running a mix of vinegar and water may clean out the lines to help it spray better.
Nov 02, 2007 | Hoover F7431-900 SteamVac Vacuum
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Logo
823 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
