Question about Randell (84111NPCB)
Error of HA on freezer and then begins to lose temp
Our reach in 1 door freezer has an error code of HA listed. It does this every couple of days. Last week, we emptied it out, defrosted it and then brought it back on and it was fine. Now the code is coming back on. Essentially it flashes for a day or so and then begins to lose temp. Ideas on a fix or an override?
Freezer temp is ok ref.temp too hot. fan doesn't seem to be operating
That model is twin cooling. Are you having any error codes on the display? Most models will shut off the fan when you open the door. If there are no error codes the thermistor could be out of range telling the fan not to run. You could try putting the refrigerator into diagnostic mode. You can look that up or reply I could tell you how to do it.
Mar 24, 2016 | Samsung RF217ACRS Bottom Freezer French...
Error message ,HA on display of Arctic Air AF49
http://www.arcticairco.com/docs/reach-in-owners-manual.pdf PAGE NO. 9
Maximum temperature alarm, Outputs unchanged. I think your board needs to be reseted, but dont do it by your self, look for help.
Regards,
May 25, 2015 | Artic Air Arctic Air AF49 Two Door Reach...
The fridge is not cooling. Error ER DH showing on door. Freezer works fine. Was told that the PCB board is to be replaced as well as the defrost module. Cost will be approx $600. Can you advise o
The "Er dH," also known as the Defrost Heater Error message, is displayed when the unit fails to reach 46? F within 2 hours of beginning its defrost cycle. This may be an indication of the defrost heater having broken or the temperature fuse having been pulled out of its slot. Contact customer service if the problem persists after having attempted a system reset.
Quick Fix
  • Unplug the refrigerator for 30 seconds and then plug it back in. Doing this will reset all the codes. Sometimes an error appears by fault. If it does not appear again after restarting, then the refrigerator is fine. If the code appears again, then there is a problem with the defroster.
Defroster Problem
  • The error code itself means that the defroster mode has failed. This means that the defrost mechanism cannot reach 46 degrees Fahrenheit within two hours to defrost ice in the freezer properly. Unplug the refrigerator and move all the items that can spoil into a backup fridge or freezer.
Repair
  • Look in the back top of the freezer. Use a screwdriver to remove the ice maker machine that blocks the back defrost panel. Remove the two side screws and pull away the plastic cover guard. Check the wire. If it is unplugged, then secure it to see if that is the problem. If the plug is connected, then remove it to check for more problems. Look for any faulted wires on the defroster. If it appears that the wires are fine, you need to replace the defroster panel. Contact your local LG dealer for the specific part number
Read more: http://www.ehow.com/info_8705867_lg-refrigerator-error-code-erdh.html#ixzz2udv3MZKA
Feb 28, 2014 | LG LFC21760 Bottom Freezer French Door...
Have a Samsung RF4287HA, sd by sd on top,middle drawer and freezer drawer. My panel shows OF on Refrig temp and OF on Freezer temp????? Tried unplugging and plugging back in, no help. Dusted back, no...
Do a little internet reasearch on your modle and get the error code listings. If that does not give you what you need the get back to me with that error code definition.
Oct 12, 2013 | Samsung RF4287HA
Sub Zero freezer keeps running
What is the model number of your unit?
Oct 21, 2012 | Refrigerators
MY LG FRIG MODEL # LRSC26923TT IS SHOWING ERROR CODE DH
poor defrost - more than one hour since defrost began and temp has not reached 46F. you will likely begin to notice frost forming on back of freezer. pull back cover (frosted area) and ck the temp sensor pack. (there is a sensor pack that contains a bimetal and sensor in one plastic pouch. do not open it but ck at its connection. the orange wires are the sensor 77K-9k ohms and the other two are the bi metal, open or closed, open above 50F.
Sep 17, 2012 | LG LRSC26923T Side by Side Refrigerator
What does E27 on display mean
Bosch washers come with built-in sets of error codes used to diagnose and correct common problems. The E27 code isn't often listed in Bosch manuals but relates to the washer door lock
The E27 error flashes on the washer LCD screen and stops the current load. Unplug your washer for 30 minutes and then plug it back in to reset the code.
Open and close the door two or three times to reset the sensor. Sometimes the door has been closed too hard and the sensor reading fails.
Mar 10, 2011 | Bosch Washing Machines
I have a LRFC 22750 SW   LG bottom freezer with french doors.   I have been getting an error message on the digital read out ER on the refrigerator side and I think DH on the freezer side.   I  unplug...
You will get this error code if a sensor does not reach a certain temperature (+8 C, to be precise)within 2 hours of going into a defrost cycle. Increased frequency probably means the defrost build up is causing your refrigerator to run more, which will bring on the defrost cycle sooner, and the error code to repeat sooner. So, it really looks like your refrigerator is not defrosting. Soon, you will have inadequate cooling. A temporary fix to the poor cooling problem would be to unplug the refrig and open the freezer for a day or so to let it defrost on it's own, but the frost will then begin to build up again, resulting in poor cooling, depending on climate and door openings, possible in less than two weeks. Better look for service soon. If you are in the US, you can try http://us.lgservice.com/index_b2c.jsp to find service using your zip code, or call LG at 800-243-0000.
Feb 01, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Sub zero 700 TR error code 06
Error code six means: from SZ
Refrig. evaporator thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
Erratic temp can be many things such as an open door. Clear the code by holding the bell key for 15-30 seconds or until you hear a tone. Keep an eye on your temps for a couple of days. If it comes back its time to call a service tech. If you are in OC I have the number of the best tech for Sub Zero in all of SoCal. There is more tests that can be done depending on how tech savvy you are.
Jan 21, 2009 | Sub-Zero 700TR
Error Code ER FF
FF is your freezer fan. You may need to defrost the unit.
Feb 28, 2017 | LG French Door Cabinet Depth Refrigerator...
Randell (84111NPCB) Logo
79 people viewed this question
Top Randell Refrigerators Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
Are you a Randell Refrigerator Expert? Answer questions, earn points and help others
