Question about Fuji FinePix F45FD Digital Camera
Little bit on battery cover broken. So won't close!!!
I accidently dropped my camera on the floor and the little bit on the battery cover the locks it in place has broken off so it won't close. The camera still works but I don't want to tape it in place. (too annoying when need to change SD card) I was just wondering where I'd get a new one from??
  • fashion_girl Apr 14, 2009
    Oh right.
    I'll look into sending it back.
    Thanks for your help
  • 86 Answers
Those parts are not easily attainable. You will need to send it in for servicing. You could also buy a parts camera and try a DIY repair, but that may void the warranty.
Posted on Apr 14, 2009
Canon Powershot A710 IS dont want to turn on. I change the batteries but nothing happens. Yesterday everything was normal. Any ideas?
When this happened after you charged the battery, a few things can be wrong. The worst that could happen, is the battery did not survive the charging session. Other things:
You managed to put the battery in, but the wrong side around. Almost impossible, but I don't know how strong you are.
There is a bit of dust in the battery compartment. Just a little piece of paper can be enough to block the current.
The battery door / cover, is not closed correct. Every battery cover has a switch that is needed to inform the camera that the cover is locked. When the switch does not work, the camera won't switch on.
So my advice: remove the battery, Look if all contacts are clean and shiny. On the battery and in the camera. Check if the battery is really charged, by placing it again on the charger.
After reinserting the battery, check is the battery cover is closed correct.
Jan 27, 2014 | Canon PowerShot Cameras
I can't keep the battery door cover closed on my Nikon coolpix digital camera L.22
I see this message at least 3 times, so it must be important.
Looks like a mechanical problem. But not having the camera in my own hands I have to do some educated guesses.
Could be something broke off. Could be a small chip of plastic or a very small piece of metal. Difficult to repair it yourself. But you also could look if there is something in the battery compartment that should not be there. Could be just a little bit of debris, that is lifting the battery, (not if the battery is behind the lock) or debris in the door, so you can't close the battery compartment complete, and it can't be locked.
If you can't find anything and it looks as if the battery compartment closes correct, and still you only can't lock the door, please visit your dealer or the Nikon service centre closest to you.
Nov 19, 2013 | Nikon COOLPIX Cameras
Powershot sx20 battery cap lock got broken now the cap will no longer close
Use electrical tape for holding the door or you need to visit service center for replacing the complete door.
Aug 07, 2012 | Canon PowerShot SX20 IS Digital Camera
My Canon Powershot SX120is camera was dropped on a high school gym floor. Since then it hasn't turned on. I think the battery connections on the little battery door are damaged, since you can tell...
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Jun 25, 2011 | Canon PowerShot SX120 IS Digital Camera
Broken battery compartment door switch
The switch is a micro switch that is depressed(and not sad :)) by a plastic tag moulded on the battery cover. Once the cover is moved into position and closed, the tag presses on the micro switch closing the switch and thus removing the error message. As with any switch, a switch is simply open or closed, Open = high resistance or O/L, while closed = 0 ohms reistance. You can use a small wire to overcome the switch by soldering the wire to both tags of the switch so it is permenantly 0 ohms. This will send a message to the microprocessor that cover is closed and camera ready for use. Hope this helps.
Twitcha
Sep 28, 2008 | Olympus FE-140 Digital Camera
I dropped my NIKON COOLPIX L10!!
The camera is very probably beyond economical repair (check your house hold insurance for accidental cover though) and I'd advise you to give it a good yank. You will find it sometimes clicks back into place. If its not covered under any insurance you have little to loose.
Jan 20, 2008 | Nikon COOLPIX L3 Digital Camera
Battery cover for cds6300
the molded plastic clips ,when cover is closed and pushed in to lock are broken from camera body both pieces. How and where can it be repair.
Oct 21, 2007 | RCA CDS6300 Digital Camera
I dropped my camera and now the pictures are funny...
What you describe is the symptom of a stuck shutter. The shutter is inside the lens and must close in order for the image sensor to properly record the image. Yours is stuck open, and that is why you see the lines across your images. When a stuck shutter results from an impact it usually requires full disassembly and manual re-setting of the delicate shutter blades. This problem would require professional repair. Unfortunately damage from an impact is not covered by your factory warranty. You can find good repair services on the internet who can service your camera. David Millier Advance Camera Repair
Dec 17, 2006 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Fuji FinePix F45FD Digital Camera Logo
70 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
