Question about Texas Instruments TI-30XA Calculator
Ln inverse function
I am using a Texas instrument calculator model TI-30Xa , could you please let me know how to type the ln inverse function?
thanks
sumudu
I want to get 250 tan 35 i dont know how?can u tell me plz
Posted on Apr 15, 2009
How to fix error mesage on TI-30Xa. Every time I press LOG an error sign comes up. how do i fix this?
To take the log of a number, enter the number then press the LOG button, then the =. To take the log of a negative number, enter the negative number using the +/- key just to the right of the decimal point. To calculate the negative of a log, calculate the log and then negate it using +/-. To calculate the antilog (inverse logarithm), press 2nd then LOG.
Bear in mind that LOG is the common (base-10) logarithm. For the natural (base-e) logarithm, use the LN key to its right.
Nov 07, 2011 | Texas Instruments TI-30XA Calculator
Hi, how do i calculate log^-1(-2) on my ti-30xa? thank u.
The inverse of the log function is the power function.
For log in base 10 that inverse is 10 to a power of
More generally, let b be the base of the logarithm. If y=log_b (x) then x=b^y
For your case log=log_10, to calculate the inverse you perform 10^(-2)=0.01=1/100
On calculators the log in base 10 and its inverse share the same physical key. One is accessed directly, the other is the shifted key function.
Sep 09, 2011 | Texas Instruments TI-30XA Calculator
Hi, how do i calculate log^-1 on my ti-30xa? for example, in order to calculate log^-1(-2), what do i do? thank you.
The inverse of the common log function is the power function with base 10 (10^). It shares the same physical key as the log. You acees the function by pressing [2nd] [log]
I'm using the original TI-30 SOL calculator. Is there any way to do inverse sine or cosine?
Of course. Just press the INV key before pressing the appropriate trig function key. For example, to calculate the inverse sine, press INV then sin.
Apr 05, 2011 | Texas Instruments TI-30XA Calculator
I want to know how to enter basic logs into the calculator: Example. Log3^9=2 How can you enter this into the calculator?
The 30XA only has logarithm functions for base e and base 10. However, you can calculate the logarithm to any base by using the relationship logb x = log x / log b = ln x / ln b
To calculate log3 of 9, press
9 LOG / 3 LOG =
or
9 LN / 3 LN =
Apr 03, 2011 | Texas Instruments TI-30XA Calculator
What button do you push on the TI-86 calculator to do the inv log function?
For the inverse natural log, press 2nd LN. For the inverse common log, press 2nd LOG.
For example, to calculate the inverse natural log of 2, press 2nd LN 2 ENTER and you'll get about 7.389 .
Jan 25, 2011 | Texas Instruments TI-86 Calculator
Using the correct key combination to determine inverse log
Sorry to contradict you but there are many types of logarithms, the most important ones are
  1. the common logarithms (log in base 10),
  2. the natural logarithms (logarithms in base e)
  3. the binary logarithms (logarithms in base 2)
On calculators, the common logarithms are labeled [LOG], and the natural logarithms are labeled [LN].
The inverse function of the natural log function is the exponential (e^(x)), and the inverse of the log in base ten function is the function ten to the power of. It is called (sometimes) the antilog
Ex:
Question What is the antilog of 3.5678?
Answer The antilog of 3.5678 is 10^(3.5678) = 3696.579068
Verification: log(3696.57908) =3.5678
Hope it helps.
Nov 29, 2009 | Texas Instruments TI-30XA Calculator
CAn't find the inverse log on the calculator
Press "2nd LN" which gives you the exponential (inverse natural log) of 7.41 = 1652.426....
Pressing LN will give you back 7.41
Same procedure to use logs to base 10, use LOG and 2nd LOG
Dec 07, 2008 | Texas Instruments TI-30XA Calculator
Trig functions of the TI-30XA
if the sides of a triangle are 15cm ,16cm, and 17 cm ,then the area of the triangle is what ?
May 09, 2008 | Texas Instruments TI-30XA Calculator
TI-30XA
Use the inverse log key sequences "2nd LN" or "2nd LOG" depending on whether you are using natural logs or logs to base 10
Dec 10, 2007 | Texas Instruments TI-30XA Calculator
Texas Instruments TI-30XA Calculator Logo
294 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
