Question about Kitchen Ranges
Jenn air cooktop model C202. Lights comes on but will not heat the two burners nor the grill.
SOURCE: jenn-air slide in range/convection
Our 7 year old "Jenn-Air Convection Oven", Canadian Model # SVE47600 also has the same problem with the dimming display. We can barely read the temperature on the oven. Does anyone know what is wrong, how to fix it, and how much it may cost. Thank you!
Posted on Jan 02, 2008
SOURCE: jenn air s136 stove won,t self clean
You've probably already read pages 34 through 37 of the owners manual for this oven. We had this stove in the house we bought and the owner wrote in his own directions, which seem to work fine:
1. Turn knob selector to clean.
2. Turn temp knob to clean.
3. Close and lock door.
4. Push enter button and turn dial clockwise to desired time.
5. Push enter button again.
You've probably already tried this, but just in case I figured I'd pass it along.
Posted on Mar 21, 2008
SOURCE: Jenn-Air 30 in. JGD8130 Gas Cooktop
Yes. Buy a burner module. Sears sells them also most appliance part stores. (I am assuming you have the model with 2 knobs on the grill side) The electric version of burner modules is around $100 Gas should be similar price.
Posted on Jul 07, 2008
SOURCE: jenn air range, model CVG4280B,
I do not know the cause BUT the fan behavior (on for left burners, off for right burners) is by design. The high-speed fan has two switches; 1) the primary switch visible centered between top two knobs, 2) secondary switches integrated with left burner knobs.
Posted on Jul 13, 2008
NephetZ
  • 9 Answers
SOURCE: Oven heats very slowly (Jenn-Air JGS9900BDS).
hi, Could be a bad bake element or a bad temperature sensor. If the element will glow bright red/orange with no hotspots it is OK. Take a volt/ohm meter set for ohms and check the temp sensor. If less than 1050 ohms replace it.
NephetZ
Posted on Jul 08, 2009
Jenn air model 720 0061 manuel
Jenn Air model 720 0061 LP outdoor grill manufactured 12/ 2004 serial DG-002
I have bought this second hand. Would like operating , maintenance, and parts info.
Mar 31, 2014 | Jenn-Air Outdoor Liquid Propane Lp...
Help in locating an electric grill unit insert for Jenn Air C202
You can buy the part that you need on the link below.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=24066&diagram_id=877457#d877457
Good Luck and please rate 4 thumbs up for the free answer.
Jul 12, 2010 | Jenn-Air Cooktops
Right front burner fails to heat (at all) Jenn air
I suspect a faulty element or electrical connection to the element.
Mar 21, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Wire for stove top burners
same place you got the switches,you can usually get the whole harness.
Nov 17, 2008 | Jenn-Air JED8430 Electric Cooktop
Jun 08, 2008 | Jenn-Air JGD8130 Gas Cooktop
Jenn-Air electric stove top - burners/fan won't come on
you may have lost a leg of your 240V service. make sure you have 240 to the appliance and then start chasing down where you lost it. there is no onboard trip or reset on this unit
Apr 20, 2008 | Jenn-Air JED8230 Electric Cooktop
Jenn-Air 30in. Exaust problem
liquid spill and alarm won't go off.
Mar 21, 2008 | Jenn-Air 30 in. CVG4280 Gas Cooktop
Exhaust fan comes on when burner turned on
The left side is set for your grill. There is apparently a switch under the left side top / front of the cooktop. The aeration tray has a prong on one end that fits into a hole in the front end of the burner basin and activates the switch which stops the fan from coming on when using the burners and allows the fan to run when using the grill. Try switching sides with the aeration trays as one might make better contact than the other.
Dec 01, 2007 | Jenn-Air 30 in. CVG4280 Gas Cooktop
Kitchen Ranges Logo
96 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
